Old 08-05-2006, 11:25 PM
Ron Stygar's Avatar
19,585 Miles
Z4 M Coupe underneath pics
Will start with the differential.
Pics are with reinforcement plate heat shield and charcoal canister cover removed.
Castrol SAF-XJ is the correct fluid.
Diff. plugs are one use. Based on some info, doubt that BMW is doing that.
Make sure you bring this up if you have the dealer do it.
Old 08-06-2006, 11:57 AM
IMR IMR is offline
Mein Auto: 2005 X3
Thanks for noticing that, Ron. I recently changed the f/r diff fluid on my X3 and re-used the old plugs. So I checked TIS, and sure enough, it says to use new fill and drain plugs on the X3 too! I doubt techs would know that. No ill effects so far, but it'll get new plugs on the next change.
Old 08-06-2006, 05:56 PM
Ron Stygar's Avatar
19,585 Miles
Tranny Z4 M
The Z4 M uses MTF-LT-2 tranny fluid.
The non M's with the magnesium engines (N52,54) use MTF-LT-3 tranny fluid.
Since MTF-LT-3 is the latest, I suspect some are using MTF-LT-3 on all cars.
I use a Snap on 8mm stubby hex socket.
I also have a Sears.
Snap on measures 8mm
Sears measures 7.9mm
Stubby being shorter makes it easier to torque.
Old 08-06-2006, 10:45 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
Might these plugs fit into the older transmissions?
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 08-06-2006, 10:53 PM
Ron Stygar's Avatar
19,585 Miles
Your plug is a M24 tapered thread.
Z4 one is a 18 mm straight thread.
Old 08-07-2006, 10:59 AM
Mpire's Avatar
The Anti-Rice
Oh well. Such is life.
Old 08-07-2006, 03:40 PM
conorb's Avatar
conorb conorb is offline
Mein Auto: 96 328is; 06 M Coupe
I'm bookmarking this thread so I can print out the photos/pictures for taking into my dealer when it comes time to change all of the fluids after my 1200 mile breakin.
Right now I've got 465 miles. I need to get out more.
conorb
Old 08-07-2006, 05:00 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
ME too, great thread!
Old 08-07-2006, 11:38 PM
Ron Stygar's Avatar
19,585 Miles
CDV: Clutch Delay Valve +
Will add some part numbers etc. soon.
Old 08-08-2006, 07:02 AM
JBgotM JBgotM is offline
Mein Auto: '99 M Roadster
will this clutch bleeder need a slave cylinder tool similar to the MZ3?
Old 08-08-2006, 08:46 AM
Ron Stygar's Avatar
19,585 Miles
That's what it says. Based on the bleeder being at the top, I suspect it won't (especially) if jacked up in the back. Wil try it when I get back from HC.
Old 08-08-2006, 03:37 PM
Don L Don L is offline
Mein Auto: 2002 325 coupe
Hi,
I had my 2006 Z4 coupe in for the new software upgrade today and inquired about the cost of a manual transmission oil change, it has 2000 mi. on it now. Dealer SR quoted $400.00, seams a bit high. Can it be done at home using ramps or do you need to have it level on jack stands?
Don L
2006 Z4 3.0si coupe silver/gray, red, prem, sport, man,
m seats
2002 325Ci orient blue, gray leather, prem, sport pkg, step.
Old 08-08-2006, 07:25 PM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by Don L
Hi,
Don L
What a rip off.
Figure $50 for the fluid.
Flat rate for the change is 4 units which is a half hour.
I did mine on four stands with the car level checked on the drivers side frame rail between the wheels.
Old 11-11-2006, 07:01 AM
Caddyshk Caddyshk is offline
Mein Auto: 2006 Z4MC #LL93158
Did you ever gett the CDV part number Ron? I'm looking to order one from Dave Z.
Dave
Dave Z just emailed me the part #
21-52-1-165-829
2006 Z4 M Coupe
2006 Z4MC - #LL93158
- SuperSprint Race - OE STB - Dave Z Modified CDV - Ground Control Coil Overs - Stoptech lines - Stoptech Pads - RE Clutch Stop - RE Transmission Mounts - LeatherZ M Shift Boot - ZHP Shift Knob
Old 11-11-2006, 08:31 AM
Svezel Svezel is offline
Send a message via MSN to Svezel
Mein Auto: BMW S50B32 M-Roadster
does the z4 have a 2 ears on the diff cover or just single like the z3?
'98 S50B32 M-Roadster
'90 E32 750iA
Old 11-11-2006, 10:18 AM
Ron Stygar's Avatar
19,585 Miles
Dave
21-52-1-165-829
I'll be removing the stock one. No plans on replacing it with a dummy one.
I think that the car shifts fine with it.
I will also be changing the clutch and gas pedal springs (increase).
Come December the car comes apart.
Old 11-11-2006, 10:21 AM
Ron Stygar's Avatar
19,585 Miles
Originally Posted by Svezel View Post
does the z4 have a 2 ears on the diff cover?
Yes.
Old 11-11-2006, 11:39 AM
So you're going without the valve period?
2006 Z4 M Coupe
Old 11-11-2006, 12:11 PM
dwaynemosley's Avatar
dwaynemosley dwaynemosley is offline
Mein Auto: Lots of different stuff
I'd like to know that answer too. I just purchased a dummy one from Dave Z. I've still got to install it, but if it's not needed, I'll just button her up without it.
'10 M3 coupe, Space Gray / Black, DCT
'12 X5d Alpine White
'17 911 Carerra S White
'14 X1 M sport 3.5 Alpine White
'91 M5 Jet Black
'01 M3 Alpine White
Old 11-11-2006, 12:46 PM
cosmos's Avatar
cosmos cosmos is offline
Mein Auto: I keeps what I find
You can go with no valve at all, but going with the Dummy valve has value if there is a warrenty issue with your driveline. You dont want it coming back to you. Just install the dummy one and no one knows the wiser.
"Ah, I love the smell of fresh cosmoline in the morning"
"Motion does Not equal progress"... Cos.
"It's NOT A.D.D., they just do not make anything for my car yet"
Old 11-11-2006, 12:56 PM
Thats what I was thinking too.
2006 Z4 M Coupe
Old 11-12-2006, 01:13 PM
Ron Stygar's Avatar
19,585 Miles
Yes.
Old 11-12-2006, 01:19 PM
Ron Stygar's Avatar
19,585 Miles
I do my own work if possible.
Old 11-12-2006, 06:32 PM
docarut docarut is offline
Mein Auto: 2006 M Coupe, 2007 Forest
Ron-everyone knows you are more talented and fastidious with your car than any BMW Tech. Would you re-install if you need to go to dealer for warranty repair if that ever needs to be done?
Bob
Similar Threads
Advice on Purchasing the new Z4 Coupe fastnfurious E85 / E86 Z4 (2003-2008) 1 07-17-2006 08:21 AM
Z4 M Coupe or M Z4 Coupe? conorb E85 / E86 Z4 (2003-2008) 13 05-16-2006 11:46 PM
Spartanburg newspaper quotes some of us about Z4 Coupe dwaynemosley E85 / E86 Z4 (2003-2008) 38 09-18-2005 09:25 AM
Z4 Coupe: Real or Crock? JonM E36/7 Z3 (1996-2002) 26 10-16-2003 03:38 PM
Silver Grey/Natural Brown Just arrived.. vienna 3 Series & 4 Series 22 04-27-2003 08:46 AM
