Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series
3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 11-19-2002, 02:40 PM
Magna's Avatar
Magna Magna is offline
Mein Auto: 2004 325xi
how does dealer fix cocked steering wheel?
had an alignment done but now the steering wheel has to turned to the right for the car to go straight. i am bringing it back to dealer to fix problem. will they re-align my car or just adjust the tie rods by sight?
how do they fix a cocked steering wheel, or perhaps my car is actually mis-aligned. in any case, thanks everybody for any info on subject.
Old 11-19-2002, 02:41 PM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Re: how does dealer fix cocked steering wheel?
They'll just take the steering wheel off and re-align that, no need to mess with the tie-rods.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Old 11-19-2002, 02:49 PM
bmw325 bmw325 is offline
Mein Auto: 335i
Re: Re: how does dealer fix cocked steering wheel?
Well-- they could do that-- but that is a bit of a hack
The tie rods should be adjusted equally--and they'll probably need to use the alignment machine to help w/ this-- although you could also do it by trial and error.
I guess it doesn't matter too much-- but BMW did go thorugh the trouble of putting a centering mark on the steering column and the steering wheel- so that it can be mounted in a certain position relative to the lateral position of the rack. I think it might be preferable to have the rack centered perfectly when the car is going straight ahead-- this help "straight-ahead" feel a little bit. I guess for a small margin of error you could fix this problem either way-- it just seems like a "kluge" to move the steering wheel when its the unequal tie rods that are causing the wheel to be off-center. Now, on some cars (like the Dodge Neon), you can only adjust 1 tie rod, so the only way to center the wheel is by moving the steering wheel-- but fortunatley, we don't drive neons. I know, its a splitting hairs and a bit anal-- but this car was designed and built in a very precise manner-- and it just seems to me that the dealer could atleast get everything even--its not that big a deal.
http://nyccarblog.blogspot.com/
Old 11-19-2002, 03:01 PM
bluer1 bluer1 is offline
fahrer
Mein Auto: doesn't have rear fogs!
When I've had it done before on other cars, they've adjusted the tie rods.
Some shops went so far as to center the wheel, then put a "special"
lever wedged between the bottom of the wheel and the floor/seat
to hold it on-center while doing the alignment.
Old 11-19-2002, 03:49 PM
jk330i jk330i is offline
Ripening slushbox drifter
Send a message via AIM to jk330i
Mein Auto: 2002 330i OB
Mine just likes to pull slightly to the right still...
