Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 01-21-2002, 03:00 PM
johnlew's Avatar
johnlew johnlew is offline
Mein Auto: 330/540/318is/MB190SL
Porter Cable Orbital Polisher
Ok, Rip...I asked this before and forgot your answer
If I buy the orbital buffer from Coast for $115, where do I get the Velcro back plate to accept the various velcro pads? It comes with the standard screw in backplate. Thanks
Old 01-21-2002, 03:35 PM
JD JD is offline
BMW fanatic
Mein Auto: '01 VW GTI
Try here http://www.properautocare.com/porcabackit.html
Also don't forget the to get counter weight to match the larger backing plate.
2001 VW GTI Reflex Silver, Frozen slotted rotors with Porterfield pads, Bilstien sports, H&R race springs, H&R 22mm front sway bar, H&R 5mm rear spacers, Neuspeed upper strut tie bar, Neuspeed 25mm rear sway bar, Audi TT 5 spoke forged wheels with SO3s, Upsolute chip, AEM CAI, Thermal R&D Catback exhaust, Autotech Stage II Drivetrain upgrade w/lightweight clutch, Euro front and rear bumpers
Old 01-21-2002, 03:38 PM
johnlew's Avatar
Thanks, have been to the site, RIP said can get it cheaper. He liked the pads from Griots, but I just got their catalogue and didn't see the back plate sold separately. Also, apparently don't need all the pads in the kit on the site you mention, however, those pads are concave to prevent splattering and griots aren't. I don't know if I need the counterweight if I buy the polisher with the six inch disc. I think you need it if upgrading from a five inch.
Old 01-21-2002, 03:44 PM
JD JD is offline
BMW fanatic
You are correct
Old 01-22-2002, 05:37 AM
Guest84 Guest84 is offline
Account closed at users request
Mein Auto:
John, the PC7424 comes with a 6" polishing foam pad. I bought another one with it (click on the accessories toggle at the 7424 page at coastaltool) for 8.95, then bought the 6"hook and loop pad for 15.95. I already had a red foam pad from Griots that attaches to the 6" hook and loop pad.
In Summary:
PC7424 with 6" foam pad $115
extra 6" foam pad $8.95
6" hook and loop pad $15.75
6" counter weight $1.95
I already had the red foam pad from Griots, so you may want to buy one more foam pad.
I use one of the 6" pads for applying the the polish. The 2nd 6" pad for applying the paint cleaner, and the 3rd red foam pad (griots pad, attached to the hook and loop pad) for applying the wax.
Old 01-22-2002, 11:58 AM
Mein Auto:
Incidently, the white foam pad that comes with the PC is more for "cutting" than it is for a final wax, thats why I use it in the polish phase. Griots red foam pad is a finer pore sponge, and seems softer than the white foam that the PC came with, the Griots foam pad is what I use to apply the wax.
Old 01-25-2002, 09:29 AM
silver-or-blue silver-or-blue is offline
Actually got a silver one
Mein Auto: 2002 M3
Which Backing Pad To Get?
Do you get the 18001 Standard or the 18002 Contour?
Old 01-25-2002, 10:49 AM
Mein Auto:
Standard one here.
Old 01-27-2002, 06:40 PM
johnlew's Avatar
Rip,
I assume the one with the holes in it to diffuse heat. My question...STANDARD or CONTOUR. Will the red GRIOTS pad fit onto the contour? Apparently contour gives more control and less splatter.
Old 01-28-2002, 06:34 AM
Mein Auto:
Originally posted by johnlew
Rip,
I don't know John. Haven't seen nor tried the contoured one. Sorry. I don't have a problem with splattering since I do it properly, that being turning the unit on AFTER the pad is on the surface, and shutting it off BEFORE lifting the pad off the surface.
Similar Threads
What a let down - Griot's clay/polish/wax and porter cable.... trkmedic69 The Detail Department 70 06-02-2008 06:22 PM
porter cable 7334 5" polisher sander 3rd_collective Classifieds 5 06-12-2003 05:19 PM
? best price on Porter Cable orbital polisher (m) sp330i The Detail Department 4 06-17-2002 04:44 PM
ordered Porter Cable -- now what? jblackburn The Detail Department 6 05-31-2002 12:13 PM
Nice article on Porter Cable orbital... johnlew General BMW 21 01-14-2002 12:11 PM
