Old 08-10-2006, 04:04 PM
adisman adisman is offline
Mein Auto: 1997 528i
Exclamation 1997 E39 Radiator Overflow Leak
I have a 1997 528i. I see a slight leak coming from the elbow on the driver's side of the radiator. This is the elbow that is connected to a hose and runs back to the coolant reservoir.
Does anybody know if that is a replaceable part, or do I have to buy a whole new radiator? I found a thread (http://bimmerfest.com/forums/showthr...ghlight=nipple) that suggested the following part, but I found it on OEM-BMW-parts.com and it stated that the part is for Mercedes. It looks like the right part, but I don't want to completely break my part unless I am sure it will work as a replacement.
Anybody have any insight on this problem? Is it a common problem?
Thanks,
Aaron
Old 08-10-2006, 04:44 PM
Jon@TheMshop Jon@TheMshop is offline
Past Sponsor
Send a message via AIM to Jon@TheMshop
Mein Auto: '98 M3 Turbo '07 335i
Thanks,
Aaron
Is your radiator still original from the factory?
Old 08-10-2006, 04:52 PM
yeah, the radiator is original from factory (with plastic sides). here is the link for the part I found, it looks right, but I just am not sure since when I called the dealer he said you have to buy a new radiator.
http://catalog.eautopartscatalog.com...OKAM81VB0U33GY
Also, here is a picture of the part I am talking about. This picture isn't my car, but it looks like someone else had the same problem. Is this design of the radiator overflow hose common to all BMWs??
http://img161.imageshack.us/img161/7...ollapse3dg.jpg
Old 08-10-2006, 05:12 PM
Past Sponsor
If you still have the original radiator from 1997 then I highly recommend replacing the entire radiator. That small piece though is replaceable and I have done it before.
Old 08-10-2006, 05:43 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
...that suggested the following part, but I found it on OEM-BMW-parts.com and it stated that the part is for Mercedes. It looks like the right part, but I don't want to completely break my part unless I am sure it will work as a replacement.
I replied to your other post:
http://bimmerfest.com/forums/showpos...6&postcount=11
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 08-11-2006, 03:25 PM
Talking thanks guys!
I went to the pelicanparts.com website and found that part you were referring to. Hopefully I just had a damaged o-ring or something. Was the part easy to remove? Just a matter of "popping" it out? Do you have any suggestions on methods to replacing that part?
Similar Threads
Instrument panel dead - e39 528i 1997 grunff E39 (1997 - 2003) 8 08-02-2010 08:57 PM
E39 528i 1997 Sukhdeep E39 (1997 - 2003) 12 06-27-2006 05:20 PM
1997 E39 540iA Dinan/Supersprint/OEM Upgrades For Sale--NY bmwe39fan Cars - Private Party 10 02-08-2006 11:59 PM
1997 E39 Timing Chain charmer E39 (1997 - 2003) 3 12-24-2005 05:54 PM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
