Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 03-16-2013, 11:06 AM
Dackelone Dackelone is offline
Mein Auto: 540i v8 manual
Originally Posted by ninetyseven View Post
Can anyone tell me exactly which hand tools are necessary here. I am going to need to buy some more sockets and open end wrenches I guess. Are the 16 mm and 18mm sockets really necessary here?
IF you don't have the proper tools, let a pro do the job. As for which sockets you need... didn't you see/read page one of this thread?
Or even this thread...
http://www.bimmerfest.com/forums/sho...d.php?t=435307
Old 11-03-2013, 09:25 AM
dgdoc dgdoc is offline
Mein Auto: 2001 540i/6spd
I just completed the job on my 2001 540 with 158K miles.
I used the method advocated by several folks of leaving the strut in place, loosening the ball-joint nut so it was flush with the top of the ball joint stud, then used the Harbor-Freight ball-joint tool. I installed the HF tool and started applying pressure. After each increment of tightening, I would stop, and tap the end (on bottom) of the Harbor-Freight tool with a 24 Oz hammer to keep it firmly engaged with the top of the ball joint stud - and also to apply some shock to the stud while under pressure. Repeated this process a couple times and on the 3rd time, *BANG* - Much louder than I thought it would be and it didn't help that my ear was pretty close to all of this. I wasn't using earplugs the first time, but did the 2nd time. Once the ball joint stud had broken free and dropped, it was free to rotate and the nut has locking threads so can't remove without holding the stud. I used a hex-wrench to stop the stud from rotating for the last few threads and removed the nut (using the open-end side of the wrench).
Looking at this part of the job in retrospect, I think it might be easier to drop the strut so you can remove the ball-joint nut while the ball-joint stud is still locked up in the knuckle. Also, would like to use a torque wrench on the ball-joint nut rather than just tightening by feel.
As far torquing the bushing bolt, I jacked up the suspension until the car was barely off the jack stands, then put a torque wrench on the back side where the nut is. To do this, I had to remove a small plastic panel from the back of the fender liner to gain additional access to fit in a 1/2" torque wrench. Before jacking up the suspension, I put a wrench on the bolt side to hold the bolt from rotating. This has to be done before jacking, otherwise the sway bar interferes and makes it very difficult to get the wrench on the bolt head. Also, I did not want to get under the car while the suspension was jacked up -- bad idea!!!. BE SAFE!. I was able to torque the nut (to 81 ft/lbs) from outside the car, without being underneath.
Lowered the suspension and re-installed the sway bar. Also noted that the bushing on the Lemforder Thrust Arms was of a different design. Can see this as well as all the cracking/wear on my original bushing (See pic below) and was really shot. The ball-joint end was also loose.
Drove the car and the slight shimmy when the car/tires were cold is gone. It's much tighter and also seems to track a little better on the highway.
Almost like it was when I picked it up in Munich 13 years ago!!
Old 03-26-2014, 05:42 AM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
Thank you for your DIY it was helpful as was CN90's
My lower factory control arm snapped in half while driving and making a U-turn, granted the Thrust arm bushings were gone, unknown to me at the time, and the vibration I had at highway speeds was misdiagnosed by the alignment shop as a bent wheel which is not bent. The control arm was also bent, which may have been when it was towed and owned by the previous owner. The factory camber and caster is now back to normal.
I also replaced my passenger side upper thrust arm & lower control arm, and was wondering what might be causing this wear on the thrust arms, I know that this sounds crazy, but it looks like some one took a die grinder and ground the control arm in hopes that it would snap while I am driving. I checked the inner wheels and see no scraping marks, which should be there if that was what caused the gouge on the arm. All four control arms I replaced have a BMW logo, and part number on them so they are probably the original upper and lower control arms.
http://www.bimmerfest.com/forums/sho...d.php?t=399580
Jose F. Medeiros
408-256-0649 Google Voice
San Jose, California
http://www.linkedin.com/in/josemedeiros
"There is nothing you can't accomplish if you let another man take the idea"
ID:	430280   Click image for larger version
ID:	430281   Click image for larger version
Old 03-26-2014, 07:59 AM
k.w.crater k.w.crater is offline
e66
Mein Auto: 2003 745li
There's no reason any suspension components
Should look like that, also these grinds look new, no dirt in the grinds.
Sent from my HTC6500LVW using BimmerApp mobile app
Old 03-26-2014, 09:50 AM
I was thinking the same thing, some one must have used a battery powered die grinder. When I had the car aligned in 2010 and it was on the alignment rack I looked at the suspension components and do not recall seeing such markings.
Old 04-03-2014, 08:15 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This is useful information, posted today ...
Originally Posted by rdl View Post
I don't believe one can reliably check thrust arm bushings to eliminate them as suspect.
I had at least one fail yet visual inspection and push/pull by hand and pry bar found no difference side to side. Once I removed them, one side bushing oozed a black oily liquid, the other side didn't. So at least one was in fact bad. With two new t-links my symptoms disappeared.
I then redid the push/pull tests. I found the compliance to be the same, or at least I couldn't tell the difference between before and after. I'd agree that this was not a scientific comparison of old to new or even side to side. OTOH, I've never seen BMW specs of force vs flex vs damping in order to perform an accurate measurement for pass/fail. Or the equipment to perform it.
It seems to me that the only practical avenue is to renew t-links or the bushings if you have the symptoms and no other less expensive suspect cause can be found.
Old 07-24-2014, 06:38 AM
beamza beamza is offline
Mein Auto: 540i sport
I know its an old thread however big thanks to original OP and also others who have chipped in. Here is my take. Yes leave the strut in place. Use an open end spanner and undo the ball joint nut until it goes as far as it can up. Use a small mallet and knock with lightness around the arm near the ball joint. Good chance I will just drop then continue to undo nut and easy out. If it doesn't, here is what I did (as one didn't budge).
Take off the two 18mm bolts on the back of brake calliper and remove and suspend calliper. Undo disk screw with hex attachment and take off disk. Undo the 3-4 10mm nut bolts holding the disk dust guard in place and then using tin snips, make a cut across a thinner part (its easy to cut and also put back without any real negative effect).and open it slightly and slide off hub. This then allows perfect access to the ball joint from the front. Use a ball joint fork tool and knock it in. Then if it still doesn't pop, once the fork is in place, knock down on the fork (small mallet). This should budge the arm no problems. It may not be the perfect solution, but once car was up on jacks and wheel removed it took me about 30 mins each side to replace the arm. Did as others and used jack under wheel to lift car a little off stand each side then tightened control arm up. Car is vey nice after. All the best. Craig
Old 08-18-2014, 08:38 PM
bluebee's Avatar
This is a nice post, which I bring here, so that all may benefit ...
Originally Posted by Fudman View Post
Unlike some other cars, you cannot replace just the ball joints. The ball joints are an integral part of the control arms (called the thrust arm or tension strut (#4) and the control arm or wishbone (#11) on the front suspension [URL="http://www.realoem.com/bmw/showparts.do?model=DT63&mospid=47587&btnr=31_0617&hg=31&fg=05"]). The ball joint cannot be replaced separately. Only the thrust arm or control arm can be replaced when the bushing or ball joint fails. Replacing the front control arm is relatively easy and does not require an alignment (http://www.bimmerfest.com/forums/sho...10&postcount=1). Replacing the thrust arm is a bit more complicated as it requires removal of the lower strut to remove the ball joint. If you do this, you may as well replace your struts, too (depending upon mileage and wear). Also recommend replacing the thrust arms with Meyle HD bushings, which are solid rubber and never leak. The tie rods also have ball joints (an alignment is recommended after replacing the tie rods). The sway bar links also have ball joints and are a common failure point.
Old 11-30-2014, 06:36 PM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
Originally Posted by Hotswimmer View Post
Hey guys, a couple of edits to this write-up. Thanks to CHIVAS for the suggestions.
Regarding the ball joint removal tool: There are a number of different styles of tools, and depending on the one you get, you'll be doing a little bit of trial and error to figure out how best to position it for maximum effect. With some of them, the fit is better if you pry the ball joint boot up and out of the way. I simply used a hammer to lightly tap the bottom of the tool into position over the boot.
It takes a lot of force from the tool to break the ball joint loose. Towards the end, I had a rag wrapped around the wrench to pad it, I was torquing so hard on the tool. Just about the time you're thinking "this is not going to work", it breaks loose. Now here's a "heads-up" - when it finally does, it's with an explosive report like a pistol shot, so be ready for it. I thought I'd broken something when I heard it the first time.
Regarding removal of the large bolts that hold the bushing side of the thrust arm to the frame: The ones on my car slid out very easily, but I've had other guys tell me that theirs took a little more work to remove, and that they had to use pliers. This may be due to water or some other fluid having seeped in and seizing the bolt.
I've used/broken SEVERAL HF type tools as mentioned here--junk. I ordered both of these, and they are IDENTICAL. I used the gear wrench and it worked much better than what I remember of the HF tool. I think the HF tool flexed a lot. The GW one only needed about a dozen or so turns of the screw, and BAM/POP! Worked great. It's much thicker/stronger where it counts and fits perfectly.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 06-07-2015, 01:58 PM
five40 five40 is offline
Mein Auto: 540i6
Originally Posted by 3sons66 View Post
Part Number??? I see at different places "control arms" only that look similar. Nothing for "thrust arms". Thanks a million!
Bumping for an answer to this instead of starting a new thread, I looked through this thread, and elsewhere googling around, but did not find the answers.
I have a shimmy at 50-60 that has started recently. Interestingly enough, this started not too long after a tow truck operator pulled it onto the flatbed by (I believe) the thrust arms. So I suppose it is possible that could have damaged it. Either way, as I have notes that the control arm bushings were replaced ~30k miles ago, my plan after reading about a shimmy at that speed leads me to believe it is probably the thrust arms, so I will replace those first.
So my question is twofold. Is that a good plan? And which one is the thrust arm?
A search of ECS yields nothing for "thrust arm", except for the bushings themselves. But it looks like there are two control arms, I assume one is the part that was replaced by the PO ("control arm bushing"), and one is what is called the thrust arm.
http://www.ecstuning.com/BMW-E39-540....4L/ES2534695/
http://www.ecstuning.com/BMW-E39-540....4L/ES2678535/
It occured to me just now that there are only separate bushings offered for the "thrust arms" and not the "control arms", and that since the po only had bushings replaced at a cost of $64, he must have actually replaced the thrust arms bushings. Either way, given the recent tow incident, I think I will go ahead and replace the whole arms.
Thanks for any help.
Old 06-07-2015, 03:36 PM
The control arms control the alignment and plane of the wheel up/down and side to side. The thrust arm controls motion fore and aft - and this can be tied to controlling shimmy. I've replaced everything on my 540 and the most dramatic change was when I swapped out the thrust arms. Also, even if the previous owner replaced the bushing, you would most likely still have the old ball joint (not serviceable).
So, yes, go ahead and replace the entire thrust arm and see if that fixes your shimmy problem.
Old 06-29-2015, 04:53 PM
b2ke b2ke is offline
Mein Auto: 540/6
Finished today in 5 hours, a messy job. The removal from the steering knuckle wasn't too bad with an identical tool to OP. Costed $25. Removing the bolt from the bushing to subframe side is a bit of a trouble, if you don't position your steering wheel correctly. For me it was about 50 to 75% rotated one direction, I do not remember whether right or left.
You also need to place an allen key into the thrust arm when tightening it into the steering knuckle. The bolt on that end of the thrust arm will rotate along with the bolt.
The hardest part was probably tightening the bushing side of the thrust arm with the car leveled and on weights. I had the car on ramps all around (about 7 inches high) and it was way to low to torque down the bolts. I did the best I could.
Old 07-01-2015, 03:53 PM
pquada pquada is offline
Mein Auto: '00 528i '06 X3
Exclamation
+1
Old 08-19-2016, 02:53 AM
rotskeedy rotskeedy is offline
Mein Auto:
Pi up
Similar Threads
E39 faq chivas E39 (1997 - 2003) 129 Yesterday 12:31 AM
DIY - 528i OIL Change (E39) 6 cyl GOKOOLJAPAN 5 Series DIY 56 12-18-2009 12:08 PM
ATTN: E39 540i Owners - Check these Hoses! (TECH) Schnell5 E39 (1997 - 2003) 13 02-01-2006 05:35 PM
E39 Brake Duct HOW TO ARTICLE Schnell5 5 Series 0 02-18-2005 07:09 PM
