E46 (1999 - 2006)
Old 08-11-2006, 07:33 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP & 04 Honda VFR
Made a clutch stop today...
I drove a car with a clutch stop yesterday and preferred it. Figured I'd make my own.
Prior to trying it, I wanted to make sure that I wouldn't be "riding the clutch." I pushed the pedal in to the point where I was confident the clutch was not at all engaged. I shut off the car and tried to re-start it - it would not start. Perfect- the starter lockout was beyond the engagement point, as it should be.
I found these instructions over on e46fanatics:
http://forum.e46fanatics.com/showthread.php?t=206363
Mine isn't quite that nice because I couldn't find any 'elevator bolts' at my local Orchard Supply Hardware. I did find a bolt with a plastic "knob" on the end of it.... figure I'd give it a shot.
I bought two rubber washers (they were pretty thin) and super-glued them to the end.
I then used my dremel to cut the bolt down until the clutch would go down far enough for the car to start.
The bolt with the knob on it (sorry, I don't remember what the plastic bag said it was called) was 1 1/2" x 3/8 - 16 (I assume "-16") is a measurement of the thread width. Although the BMW uses metric bolts, this fit snugly.
It took me 4 times of trial-and-error to get the bolt short enough. To save you time, I measured it with my micrometer. The stock clutch stop is 26mm long, and my clutch stop is now 44mm long (including the rubber washers).
Initial impressions are good. Worth $5.37.
Old 08-11-2006, 08:19 PM
Mr. The Edge's Avatar
Mr. The Edge Mr. The Edge is offline
Mein Auto: .
cash fletch? i'm impressed.
Belief cannot argue with unbelief, it can only preach to it
To clasp the hands in prayer is the beginning of an uprising against the disorder of the world.
Old 08-11-2006, 08:23 PM
///M3lissa's Avatar
///M3lissa ///M3lissa is offline
\m/ (>.<) \m/
Mein Auto: Duh!
You didn't waste any time did you?
Old 08-11-2006, 11:00 PM
icemanjs4's Avatar
icemanjs4 icemanjs4 is offline
Grinning from ear to ear
Mein Auto: is way too fast
Krisl,
Congrats on the upgrade. I don't think I could drive my E46 without it. It was the best 2.46 I ever spent. (Go figure, on a 40K+ car) lol. It's too bad you couldn't find the elevator bolt and had to keep chopping away. With the elevator bolt (found at any local hardware store, or Lowes - but not at Home Depot for some reason), it's a 2 second job.
Oh well, it took a little longer, but i'll bet it's worth it.
Proud owner of an '05 Silver Gray 330i ZHP with Natural Brown interior
Old 08-12-2006, 09:37 AM
KrisL's Avatar
Ubergeek
Yeah. Not a huge difference because of how I shift. I think I have a mental clutch stop already - I guess I have my brain trained to only depress the pedal to the disengagement point already. The pedal lever only touched my new clutch stop about 25% of the time.
Old 08-12-2006, 09:41 AM
Crawlings Crawlings is offline
Mein Auto: '93 Ranger, yeah...a ford
This may sound like a dumb question. But what exactly is the benefit of this? I realize what it does, but does it make for faster shifting or something else?
Old 08-12-2006, 10:26 AM
KrisL's Avatar
Ubergeek
It just helps clutch feel by eliminating the "dead range" at the bottom of the pedal travel. Some say it helps them shift faster, others say it just helps them shift smoother.
Old 04-21-2008, 01:42 PM
KrisL's Avatar
Ubergeek
Just an update... my syncros weren't happy, so I removed the clutch stop awhile back and went back to the stock unit. I was now able to fully disengage the clutch again, so shifting was once again smooth... and you know what? I don't miss it at all. Like I mentioned before, I guess I had a 'mental/muscle memory' clutch stop already. I'm glad I didn't spend more than a few bucks on it.
Old 04-21-2008, 02:11 PM
jsonli jsonli is offline
Mein Auto: 330ci
+1
I had problems engaging gears with my clutch stop. The foreman at the dealership said something about a pressure plate. A knowledgeable tech at a good local indy shop told me it has to go to the floor too and that i could take off 1/2, half inch at most.
Old 04-21-2008, 05:15 PM
SeanC's Avatar
SeanC SeanC is offline
aka cngzsn
Mein Auto: 330i
I have been using it for about a year now and I don't regret a single day..
Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW 6MT - Sold
Kashmir Beige MetallicSamana BeigePoplar Wood e34 525it ZPP/Auto
HellrotDove Grey e36 ///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT
Old 04-21-2008, 06:18 PM
carsnoceans's Avatar
carsnoceans carsnoceans is offline
Mein Auto: '05 330i ZHP
I stalled twice on red light today. Let the clutch out too quickly thinking that first few inches are dead range... I guess, I did form a habit in last few weeks and now have to unlearn it.
Modified Clutch Stop
Valentine-1 hardwired (DIY)
Zeckhausen CDV
BMWCCA Member #401517
Old 04-21-2008, 06:25 PM
Boile Boile is offline
Mein Auto: .
You just had it set too high.
Try choping it a bit more with your dremel.
Stop the madness: U.S. National Debt Clock
This post is brilliant. Completely spot on and chock full of useful information. Pure genius and original.
- Frank Rizzo
Old 04-21-2008, 06:47 PM
KrisL's Avatar
Ubergeek
For no real benefit again?
Nah.
Old 04-21-2008, 06:50 PM
hockeynut's Avatar
hockeynut hockeynut is offline
Casey!
Mein Auto: '04 330cic
No probs after 20k miles with mine. Love it!
SteveH
"Now I guess I'll have to tell 'em...That I've got no cerebellum" - The Ramones, "Teenage Lobotomy"
Similar Threads
Clutch Stop thr61 E90/E91/E92/E93 (2006 - 2013) 10 08-31-2010 02:39 PM
Thoughts on UUC Clutch Stop Cruzer General BMW 8 04-17-2006 03:06 PM
clutch stop with no CDV removal? swchang General BMW 33 04-28-2004 02:25 PM
