Z4 M Coupe car/key memory - Bimmerfest - BMW Forums
Old 08-14-2006, 09:43 PM
Ron Stygar's Avatar
19,585 Miles
Stopped by my dealer today in respect to coding the CD changer and phone docking cradle. Since both items work fine he recommended to leave it alone. I agreed.
We went on to do car/key memory. They tried to do car key memory when I took delivery of the car (part of PDI) but the system would not connect to the car. This was a M Coupe thing and they fixed it with version 22.
When he initially connected it said to use EDIC.
He was not familar with that and changed the head and it came up fine.
Basically the same as the following pics plus it showed the three flash lane change option.
I asked him to print the list and he said can't be done. He did print out the changes.
Some of the things mentioned in the list didn't make sense to me or him.
I basically had him do the following.
DRL which lights the inside halos.
One momentary turn signal touch = turn signal lane change three flashs.
I prefer the -Firestone five flash.
Lock after unlock without open. Have no idea what that does and neither does he.
I assume that it will relock the car if unlocked without opening the door. Haven't tried it yet.
Automatic door lock when driving off when you reach ~15 MPH.
I prefer the -Firestone method which locked on start and also at some speed.
On the list.
I also asked him to activate alarm but he said that it was already activated. I tried this long ago but no flash. Turns out that it doesn't flash until 1 minute 11 seconds go by.
Easy mods.
ID:	82996   Click image for larger version
Old 08-14-2006, 11:01 PM
Ron Stygar's Avatar
19,585 Miles
Just tried it. If you lock the car and then unlock it without opening a door it will lock again on its own after two minutes.
Old 08-15-2006, 07:23 AM
Canuck BMW's Avatar
Canuck BMW Canuck BMW is offline
Spending Way Too Much
Mein Auto: 02 325i;03 530iA; Z4 3.0
And the alarm does NOT reactivate. I've had this option set on all my BMWs. It's nice if you accidentally hit the remote unlock button by mistake (in your pocket)..too bad the alarm does not reset.
For the auto locking after driving off, I find mine does it at around 5 mph.
Rick (Ottawa, Canada)
2008 - M5 - Interlagos Blue
2003 530iA - T. Silver with M Exec. Pkg
2003 3.0 Z4 - Sterling Grey
Old 08-15-2006, 07:35 AM
Pani Pani is offline
Automotive Hypochondriac
Mein Auto: 2001 M Coupe, 2016 550i
Is the Firestone controller you are referring to the same as the sport mode controller or is it a separate module? The one you are describing is for the Z3 M Coupe correct?
Old 08-15-2006, 07:47 AM
Ron Stygar's Avatar
19,585 Miles
He also does a lane change flasher controller which can be coded for three or five flashes.
Have one in my sold Z3 M coupe and '97 318 ti.
Old 08-15-2006, 07:50 AM
Cliff Cliff is offline
TMS
Mein Auto: 2015 Golf R
Thanks for the info - that will come in handy in a few weeks
2015 VW Golf R: (pic)
Old 08-15-2006, 08:10 AM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
VW defaults this feature to on and it is programmable on all Mk4 and newer cars. I have grown to like it.
Jon Maddux
08 E90 M3 | 06 M Coupe | 01 M coupe | 99 M coupe
http://coupenut.blogspot.com/
http://x5nut.blogspot.com/
Similar Threads
Some Z4 Coupe Pics (ebay) JonM E85 / E86 Z4 (2003-2008) 29 06-22-2006 08:52 AM
Z4 M Coupe Impressions Esteves E85 / E86 Z4 (2003-2008) 13 06-07-2006 12:37 PM
BMW will build Z4 coupe, M model mattm E85 / E86 Z4 (2003-2008) 1 11-25-2005 05:34 PM
Wow! The G35 Coupe looks good! (link inside) Sean Off-Topic 12 03-29-2002 11:48 AM
