Coolant Flush Questions - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 08-24-2006, 09:08 PM
NickD's Avatar
NickD NickD is offline
Send a message via AIM to NickD
Mein Auto: 1999 BMW 328i 5speed
I wanted to change my coolant this weekend, and flush the system. This will be the first time I am doing this on my '99 328i, I have done this on a few other cars.
I was wondering if there were any tips/advice regarding this. Is there a drain plug for the block or only one on the radiator? I have heard BMW's are sensitive and finicky if not bled properly, I had this experience on my old Acura Legend, it would overheat if any amount of air was trapped in the system. So I know to be careful with this. I have BMW coolant and will be mixing it with 50% distilled water. Anything I missed? Thanks.
Old 08-25-2006, 06:38 PM
F1Crazy's Avatar
F1Crazy F1Crazy is offline
racer wannabe
Mein Auto: '14 535iX '12 X5, '03 325
All you need to know: http://www.bmw325i.net/maint_coolant_change.shtml
Old 08-26-2006, 08:23 AM
NickD's Avatar
Wow, that's an incredible DIY how-to. Thanks!
Old 03-28-2010, 01:36 AM
SDpnoy SDpnoy is offline
E46Fanatics
Mein Auto: BMW 330Ci
Originally Posted by F1Crazy View Post
Uh oh. Link does not work anymore. Anyone have an updated link?
Thanks.
Old 07-29-2011, 01:15 PM
SpaceFuzz SpaceFuzz is offline
Mein Auto: 325i
The coolant flush DIY link can still be retrieved via The Wayback machine at archive.org:
http://web.archive.org/web/200904170...t_change.shtml
Old 07-29-2011, 07:46 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
you can also look in the 5 serious diy section. look for cn90's cooling over haul.
The more you complain, the longer God makes you live. SPHOBA #00002
Similar Threads
325i Coolant Flush - Light is still on JuliaMaria E46 (1999 - 2006) 2 08-28-2006 03:20 PM
Coolant change + brake fluid change questions? ron1win X5 E53 (1999 - 2006) 0 01-31-2006 10:25 PM
Coolant Issue X3 2.5l dionysius X3 E83 (2004 - 2010) 1 02-20-2005 12:07 PM
Coolant Temp vs. Oil Temp SONET General BMW Questions 25 11-28-2002 03:42 AM
Coolant question... Cal 3 Series & 4 Series 5 07-05-2002 10:44 AM
