Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 08-26-2006, 05:38 AM
AW328i AW328i is offline
Mein Auto: 2 cars and a truck
Compression ?'s for turbo'd engines.
I have some questions that some of you might be able to answer. If your running only a half bar of boost (7.5 psi) you don't need to lower compression in your engine right? But if you raise it above this level will you have to put new pistons and stuff in or what do you need to do to run a full bar of boost on an engine?
Old 08-29-2006, 08:55 AM
IanBMW IanBMW is offline
The Guru
Send a message via AIM to IanBMW
Mein Auto: 1998 528i, 1988 327i
All depends on the engine. Tell us what you want, and what your working with.....and we can tell you if it will work. Generally you're correct, but then again i say GENERALLY.
Old 08-29-2006, 11:10 AM
What I want to know is what do you need to do to your engine in order to handle high boost!! (8-20 or more psi) And is it possible to do a twin turbo (1small/1large) on the 2.8 E36?
Old 08-29-2006, 08:43 PM
The Guru
Honestly the benifit of TT will not be there for that engine. You need to go buy the book Maximum Boost by Corky Bell. He explains off of it, what you ask is WAY too simplified. So i'll make it simple, it will cost money......anywhere from $5-20k. EOD
Old 08-30-2006, 12:35 PM
Thanx, will check out the book.
Similar Threads
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 05:52 PM
BMW wins International Oscar Awards of Engines... -again K1 General BMW Questions 9 05-27-2004 12:10 PM
New engines for MINI coming late '05 Kaz General BMW Questions 6 01-31-2003 01:44 PM
"Mini engines by Toyota" hts Off-Topic 10 05-14-2002 06:18 AM
Toyota diesel engines in minis Nat Brown Off-Topic 1 05-13-2002 05:51 PM
