Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 11-25-2002, 05:06 PM
2001E46 2001E46 is offline
Mein Auto: 2001 325i
E46 Manual Transmission Fluid Change? Ramps?
I'm looking to change the transmission fluid in my 325i manual. The problem is, I don't want to put the car on jackstands. I would prefer to do this with the front of the car raised on ramps (I'll be changing the engine oil at the same time).
Now I realize you're supposed to have the car completely level when putting in the new fluid because the fill hole is designed to overflow at the point where you have exactly enough fluid in the tranny. This would not agree with my plan to change the fluid with just the front of the car up on ramps.
My plan is to just drain the old fluid, measure the volume, and add exactly the same amount back in. So if I drained 1 quart I would simply add 1 quart of fresh fluid back. I'm hoping that a little more than 1 quart of fluid drains out because the capacity is listed at 1.1 quarts.
One problem I see with this approach is that it may be the case that if you only have the front of the car raised you cannot drain out most of the fluid (the drain hole may not be at the exact "bottom" with the car in this configuration).
Another problem that might occur is if the transmission fluid spills out of the fill hole before being filled to capacity with only the front of the car raised. This would mean I would never be able to get the tranny filled completely.
Has anyone successfully changed their transmission fluid with just the front of the car raised?
Old 11-25-2002, 05:14 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
This is not reasonably possible. The Fill hole is designed to spill out any overfill. If you have the car at an angle, you won't be able to fill it up completely.
Just get a jack and four stands. It's <$100.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 11-25-2002, 07:24 PM
CD-55 CD-55 is offline
Double Bimmers
Mein Auto: 2003 330i & 1988 325is
Why are you changing your fluid?
Here is a pic from the 2001 Owners Manual:
Old 11-25-2002, 07:27 PM
Becuase the BMW fluid sucks, and the car shifts a lot better with redline.
Old 11-25-2002, 07:59 PM
Ausfahrt Ausfahrt is offline
Groccery Getter
Mein Auto: E46 325iT/F10 550
Thumbs down
Lifetime....hmmmmm.....That's almost like saying your underwear is lifetime you dont have to change it ever. Can you imagine wearing that for that long
Old 11-25-2002, 08:19 PM
Double Bimmers
fahrt, what do you know about stinky underwear?
Unlike the engine where the oil cycles through the combustion chamber, the oil in the transmission and differential is COMPLETELY sealed. All that is in there is metal gears and oil. The temperatures are not extremely hot and oil does not react with metal, so that stuff is going to last a VERY long time before it changes in any measurable way. BMW engineers are not smarter than everyone on the Internet, but if the oil needed to be changed within a few years, they would not have published “lifetime” in the manual.
With that in mind, my interpretation of “lifetime” is about 10-years.
Old 11-26-2002, 08:16 AM
KWiK's Avatar
KWiK KWiK is offline
KWiK
Send a message via ICQ to KWiK
Mein Auto: 2010: 328i
My interpretation of "lifetime fluid" is it's just a marketing term used to bring down the annual maintenance cost for competitive comparisons. Do your car a favor and change it at least every 60K miles.
Frequent fluid changes are never a bad thing.
2010 BMW 328i Sports Sedan | Alpine White | Black Dakota Leather | M-Sport Package (18") | Steptronic® | Moonroof | Xenon | Navigation |
http://www.print-kwik.com
Old 11-26-2002, 04:58 PM
I'm changing the fluid to redline atf. Hoping for smoother shifts this way.
Old 11-26-2002, 05:05 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
If you insist on doing this without a lift, use a pair of jackstands and a pair of ramps. You'll get the car ~8" off the ground and if you set the jackstands right, the car will be level enough to make this work.
And has anyone ever heard of using BG SynchroShift in these transmissions?
Old 09-25-2005, 10:01 AM
bruntasm1 bruntasm1 is offline
Mein Auto: 325CI
Woah, this thread is old. Even though that page of the manual says the transmission fluid is "lifetime," the 2001 Service Manual says to "replace transmission fluid" under the Inspection II checklist (around 60k miles).
I would scan it for dramatic effect.
Old 09-25-2005, 11:54 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
The basic thing is, is lifetime teh lifetime of the car or the lifetime of the tranny?
And if it is the lifetime of the tranny, that might be shorter than if you changed the fluids. Inspection 2 would be a reasonable interval.
BTW Nick no longer recommends RedLine. He is using BMW LTF-2 in all cars. I have RedLine MTF in two, LTF-2 in the E46 M3.
Othes have reported good luck with Royal Purple SynchroMax fluid.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 09-25-2005, 07:50 PM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein Auto: a BMW killer
always remove the fill plug first
nothing like dumping the fluid and then having a problem getting the fill plug out
Yesterday's history, tomorrow's a mystery, but today is a gift; that's why it's called the present
Old 09-26-2005, 07:25 AM
Pinecone's Avatar
M Mad
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-29-2005, 05:32 PM
WAM's Avatar
WAM WAM is offline
ober-slacker
Send a message via AIM to WAM
Mein Auto: 325i Sport
Go ahead and change the transmission oil. The same oil that had a recommended replacement interval, suddenly became a "lifetime" fluid. Marketing weenies at work!
I recommend that you change the oil with the car level. The drain and fill plugs are about half way on the side of the transmission casing, so if your car is tilted up, you won't get much out.
I also recommend getting a bottle pump from the auto parts store, they make the job of filling up much easier.
As far as the type of oil is concerned, be advised that there is a yellow sticker on the side of the transmission casing, sort of high up, that states the use of BMW MTF-LT-1 oil, now superceded by BMW MTF-LT-2. I don't know whether this is an ATF oil, but it is sort of a yellow/gold color and I did not want to risk using anything other than OEM oil.
I bought 5 liters for about $120, a while ago from a BMW dealer. My third transmission fluid change is due at 75K miles, coming up in 3K miles.
