Old 09-01-2006, 09:07 AM
FrankMB FrankMB is offline
servant to the people
Mein Auto: 03 M3, 02 525i, 01 ML320
Increased Emissions
Well I got a nice little warning this morning "Increased Emissions" with a scary Engine symbol. Car still drives the same (meaning great).... Wonder if its that ****ty Exxon gas I filled up with yesterday. Anyone else got this yet ?
Old 09-01-2006, 11:58 AM
gbelton's Avatar
gbelton gbelton is offline
///M for Motor Sports!
Mein Auto: No More 6 Series
Emission Error
Some of us have seen this before. Run a quick search on the 6 sub forum. It's not a big issue.
Oh, check your gas cap, ,ensure it is tighten properly.
The Tail of The DRAGON, YES!!
2008 Alpine White, Portland Brown ///M5 (SMG)
2008 Alpine White, Fox Red ///M3 (6MT)
2008 Sapphire Black, Black 750Li
Old 06-02-2009, 08:31 PM
AB's Avatar
AB AB is offline
Don't worry, be happy
Mein Auto: '11 Porsche Carrera S
For the record, I just got this error today too. My car would crank but would not turn over. I came back an hour later and it did start up, but I was left with that fault code.
Took it into the dealership today, and they said it was a communications fault that just had to be reset. All is well.
Old 06-03-2009, 10:58 AM
feriors feriors is offline
Mein Auto: 05 645ci
its comes and goes. Most of the time its not a huge deal. Sometimes it triggers from the gas cap or when you put in gas the car doesn't like. When there is something wrong, its usually the thermostat being broken or the o2 sensor out of wack.
Old 06-03-2009, 11:19 AM
AB's Avatar
AB AB is offline
It would just suck if it happened frequently and you would have to travel to the dealership to get the computer reset to erase the fault code and "Service Engine Soon" light.
Old 09-17-2010, 11:00 PM
Marco Moore Marco Moore is offline
Mein Auto: bmw 645 2005
Increased Emissions
i got a bmw 645 2005 and this morning i was driving everything was fine... i have the Increased Emissions light comes on and off all the time so i dont even pay attention to it anymore ... but today i ran out of fuel so i put fuel in a gas station i never use and now the light stays on and the car sheaking ... and making it look like the car about to shut off by it self but it aint... can someone knows what can be the problem ? is it the gas or there is a bigger problem ? my car was never shaking like that
also i did oil change like 2 month ego and everything was fine ...
PLEASE ANYONE ?
Old 09-18-2010, 05:13 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
run out of petrol
Hi one of the first things you could consider is to add a high quality additive to one tank of fuel, I don't mean the cheap rubbish that many sell but something like BG44k I think is the brand name, this will clean up your total fuel system right through to the oxygen sensors in the exhaust system. This stuff is expensive in the UK but lots cheaper in the USA...
As for your car running out of petrol well sadly given the cars age you may have got junk from the bootom of your fuel tank into the fuel filter or further on, it may clear itself with a good long run... this is why it is best never to run out of fuel !!!! easy said but it can happen to anyone !!
Old 09-18-2010, 06:24 AM
davy_b davy_b is offline
Mein Auto: Bmw 645Ci
Is it BG 44k your talking about ???
http://www.bgprod.com/products/fuelair.html
Old 09-18-2010, 06:48 AM
645/333's Avatar
Michael
Bk44
Yes BG44K is the product, thank you for correcting me
I have used this in my 645Ci to positive effect ...
Old 09-18-2010, 07:40 AM
chasz17 chasz17 is offline
Mein Auto: x5 4.4i
If you use top tier gasoline at the right octane consistently, you should not have a problem.
Old 09-18-2010, 11:17 AM
thank you
thank u guys so much ... ill try adding that bg44k lets see if it helps ... it might be the problem couse i was driving my car so many times till there was only 20-15 miles fuel left ...
do i add this bg44k once i put fuel in the car or should i wait till the gas tank is empty and then add the bg44k and then put gas ?
thank you for your time guys ,im gonna let u know if it worked
Old 09-18-2010, 12:12 PM
645/333's Avatar
Michael
Just fill your tank as normal there should be enough space in the tank to add the BG44k, then run the tank down to low again, don't top up when at 1/4tr or 1/2 just use until warning light comes on then refill as usual, dont worry how long it takes to empty the tank as the additive should be okay, I understand that Lexus , Bently etc use this stuff at major services,,,,
Old 09-18-2010, 03:16 PM
one more question im sorry i know im driving u crazy... where do i get this bg44k ? i live in queens new york ... i went to autozone they dont have it and i tried few car garage ...
maybe there is another prodect i can use ? or this one is the best one today for bmw 645 2005 ?
thank u in advance ...
Old 09-18-2010, 03:23 PM
645/333's Avatar
Michael
Suggest you search via their site or try Ebay It is an American product so it is very difficult to find in UK, you should be able to find someone, sorry can't help further
Old 09-18-2010, 06:58 PM
WGMc WGMc is offline
Greg
Mein Auto: 05 645Ci convertible
I had the same increased emissions warning several months ago. Turned out to be some type of sensor or pump in the fuel system. I drove it for a week before scheduling an appointment; the car drove fine with no issues. Mine was covered under CPO.
Old 09-19-2010, 01:45 PM
well i didnt do as u said yet ... i cant get this BG44k anywhere so im still looking ... there is any other prodect i can use ? car was fine till i put gas in a station i never used before (maybe thats the problem ? )
another thing i was driving my car today and now the increased emissions comes on like it used to be and right after that another msg shows on the screen says "engine malfunction" increased engine loads may damage catalytic converter.
drive with reduced engine load.
please have the system checked by bmw ...
so i called bmw and they cant see me till 2 and helf weeks from now ... can someone please help me and tell me whats wrong with the car and what might be the problem ? ALSO I WANT TO KNOW CAN I STILL DRIVE THE CAR LIKE THAT ? thats the only car i got and i gotta get places ...
thank you in advance ...
Old 09-19-2010, 01:48 PM
also
also the car is shaking and looks like it about to choke and turn off... that happends when i stand on a rad light or so ...
Old 09-20-2010, 05:47 AM
dcabot dcabot is offline
Mein Auto: '05 645 Convertible
Little bit of advice. Try not to run the tank so low. If there is any sediment at all you will suck it up. Not a good thing for the fuel system. You may want to have the car checked.
Old 09-20-2010, 08:33 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Unfortunately when you get an emissions problem, it can be a number of issues. Bad sensor, bad fuel such as water in it or pump getting faulty. You have gotten some good advice here but like I always saw, try the least expensive thing first. Do the system flush with the BG44K. if that doesn't work then you are looking at a component failure that will have to be diagnosed. Also you may want to check the coils. My friend recently had this problem after filling up in QUEENS! with his 745. After some testing, it was found that one of his coil went bad. You can always take it to an indy shop and get the fault codes and then do the process of elimination.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 09-20-2010, 10:41 AM
hey
thanx for the respond ... im gonna try adding the BG44k ,i see your from queens ,me too do u know by any chance where i can get this BG44K ? i went to auto trader and pep boys both dont have it and i dont know where i can get it ...
thank you .
also where u go to check your car ? i dont want to go to BMW couse they charge so much just to even look at it ... do u have anyone good ?
Old 09-21-2010, 10:17 PM
Gb44k
i put new fuel and BG44K i did it today and the car still shaking...
how many days it takes till i see result ?
Old 09-22-2010, 04:09 AM
645/333's Avatar
Michael
Bg44k
Hi, the stuff starts working once it is in the tank, and stays in all parts of the fuel system whilst the car is not in use, one of the things I did was give the car a good blast and long drive about an hour or so to ensure I was maximising its use. If you read the BG44K site you will see the recommendations and results. Since using it I found that my idling was better and throttle response improved, these could be my mind set, so proof my mileage went from 23.5mpg to 26.7 mpg, without changing driving style, and on long motorway journeys at 80mph ave+ to 31,2mpg. This is imperial gallons UK measure.
If the problem on your car is either poor fuel or dirty fuel system/injectors you should get a result. If not then you will have to look at other avenues......
Old 09-22-2010, 01:19 PM
BG44k
so i still have 230mil left with the new fuel and the GB44k in it the car still shaking while i stand in a rad light and the increased emissions and another msg shows on the screen says "engine malfunction" engine loads may damage catalytic converter.
WHAT DO I DO ? SHOULD I WAIT TILL I FINISH ALL THE FUEL WITH THE BG44K U THINK ITS GONNA WORK OR TO TAKE THE CAR TO THE GARAGE ?
Old 09-22-2010, 01:41 PM
to be honest mate id get someone to have a look at it at this stage, even get someone to read the codes there must be some bmw specialists in new york that can do this ???
if the codes were read it would give you a good idea
Old 09-22-2010, 03:03 PM
pablo645's Avatar
like I've suggested before, if the flush don't work get the car hooked up to read the codes by an Indy that has the computer that can connect to car. Looks to me you may be experiencing the same problem my friend had with his 745 where he got a bad coil on one of his cylinders right after a fill up. It may have been a coincidence that it happened and had nothing to do with the gas itself but you will never know until you get the fault codes.
Previous Cars:
Similar Threads
Service Engine light on due to increased emissions! hawk123 E60 / E61 (2004 - 2010) 17 03-01-2012 08:55 PM
Voluntary Emissions Recall on 2006 525 & 530's SteVTEC E60 / E61 (2004 - 2010) 1 05-05-2006 07:08 PM
Roadside Emissions Survey in Calif. Esteves Forced Induction 3 12-30-2005 10:09 AM
Emissions Tricks for 1988 325is? CD-55 General BMW Questions 6 11-04-2002 06:00 PM
Cost of insurance for BMW increased?? ayn General BMW Questions 25 02-28-2002 03:24 PM
