Central Locking problems after battery replacement. Ideas? - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 09-03-2006, 10:40 PM
jjclyde jjclyde is offline
Mein Auto: 2007 Z4 M Coupe
Posted this in the General section - but it was suggested I post here as well - here goes.
This all pertains to our 2003 X5 3.0.
Hadn't driven the car for several weeks - and found the battery dead the other day. Jumped it (carefully following directions in manual) - drove it around for a while - seemed to restore a reasonble charge.
However - the keys/fobs no longer work to lock or unlock the car. Must insert the key in the drivers door handle. This manual method works as expected. But the keys/fobs don't work anymore. ALSO: The lock/unlock button inside the car no longer works.
Having had weird behavior in my 540i when the battery was near-dead, I decided to try replacing the battery. Did that, but that has not improved anything. Still have the same problems.
I have tried the following:
-- Checked all central locking fuses - all ok.
-- Tried to reprogram both keys (via the directions found elsewhere on this forum) - no response. Did this before and after replacing the battery.
-- Replaced the battery.
So now I'm out of DIY ideas. Anybody have any other bright ideas?
2016 Estoril M235i ED
2007 Interlagos Z4M Coupe (sold)
Old 09-04-2006, 07:09 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
You may need to charge the keys or it could be the key to key memory link up. Dealer may need to re-program the module.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
Old 09-04-2006, 07:58 AM
IrvRobinson's Avatar
IrvRobinson IrvRobinson is offline
Past Sponsor
Mein Auto: BMW X3
call your service adivisor, they should be able to fix it while you wait !
Old 06-08-2010, 10:24 AM
kwshea kwshea is offline
Mein Auto: BMW X5
Remote control issue after battery jump and recharged
I also have the exast same problem after my battery dead, jump and recharged. My remote control and central lock system have the same sympton as yours. I am interested in finding out any DIY solution.
Old 09-02-2012, 09:02 AM
Princerakesh Princerakesh is offline
Mein Auto: X5
I had the same problem but got the module repaired for 55 with a guy in REading UK. His number is 07790658 683. Good luck and do not waste your money with greedy garage!!!
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 06:38 PM
Central locking - Does nothing! Clnilsen E30 (1982 - 1993) 7 07-18-2006 12:08 AM
Central locking system dca820 3 Series & 4 Series 0 09-21-2003 10:26 AM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
