E46 M3 (2001-2006)
Old 09-06-2006, 07:49 AM
digicube digicube is offline
Mein Auto: EVO X?used E46 M3?IS500?
What's the real 0-60 time for an E46 M3?
BMW states 4.8 s but Edmunds.com states 5.3-5.5s, this is a huge discrepancy. I tend to believe Edmunds since manufacturers often put a * next to their claims. By today's standards, only cars with under 5s 0-60 time can be considered supercars, is the E46 M3 a supercar?
Old 09-06-2006, 09:51 AM
M3Mike's Avatar
M3Mike M3Mike is offline
Controversial - of course
Mein Auto: M3
Edmunds does not say 5.3-5.5
Not that Edmonds or anyone else is 100% accurate.
Here is what edmunds says:
http://www.edmunds.com/new/2006/bmw/...029/specs.html
Performance
Acceleration (0-60 mph): 5 sec. Braking Distance (60-0 mph): 112 ft.
Base Number of Cylinders: 6 Base Engine Size: 3.2 liters
Base Engine Type: Inline 6 Horsepower: 333 hp
Max Horsepower: 7900 rpm Torque: 262 ft-lbs.
Max Torque: 4900 rpm Drive Type: RWD
Turning Circle: 36.1 ft.
Old 09-06-2006, 01:27 PM
vrrooom's Avatar
vrrooom vrrooom is offline
Vorsitzer
Send a message via AIM to vrrooom
Mein Auto: Bummers, porkys
The problem is the M5, which is no faster than the M3. This data is from drag racing site, national times fro several M3's
1987 BMW M3 8.1 16.1
1988 BMW M3 7.1 15.4
1995 BMW M3 6.2 14.6
1995 BMW M3 Lightweight 5.3 13.9
1996 BMW M3 Automatic 6.7 15.3
1996 BMW M3 Luxury 6.6 14.9
1998 BMW M3 Sedan 5.5 14.0
2001 BMW M3 Coupe (U.S.) 4.8 n/a
2001 BMW M3 Convertible (U.S.) 5.4 n/a
2002 BMW M3 4.7 13.4
1988 BMW M5 6.3 14.6
1991 BMW M5 6.5 14.9
1993 BMW M5 6.2 14.6
2001 BMW M5 4.7 13.2
2002 BMW M5 4.8 13.3
Old 09-06-2006, 01:55 PM
Ajax's Avatar
Ajax Ajax is offline
Hydrocarbon Man
Mein Auto: 991 GT3
It also depends on whether the run was done with a MT versus SMG. SMG will be a bit slower.
Old 09-06-2006, 03:46 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
It also depends on what tires, what the track surface is like, what the track temp is like, what were the tire temps, what the driver is like (how well does he launch and shift), what the air temp and himidyt are (changes HP).
All these variables make each run a bit different. Think about it, if it was something that didn't change around ,why would there be draqg racing? Just run one 1/4 miles pass and until someone runs a faster on, you win every event.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 09-06-2006, 03:54 PM
M3Mike's Avatar
Mein Auto: M3
I think BMW's estimate of 4.8 0-60 for the E46 M3 coupe manual is in the ballpark.
5.3-5.5 sounds more like the Vert figures to me.
Old 09-06-2006, 04:44 PM
I thought SMG is faster than MT.
All 2001-2006 models have the same horsepower, is it correct to assume they all have the same 0-60 time?
http://www.edmunds.com/insideline/do...e=BMW/model=M3
In the video of the 2005 model, Edmunds state 5.3s. http://www.edmunds.com/insideline/do...ticleId=105396
On the page of the 2005 model review page, Edmunds states 5.5s. http://www.edmunds.com/insideline/do...6/pageId=63526
Edmunds does state 0-60 time of 5 s for the 2001 model. http://www.edmunds.com/insideline/do...82/pageId=5624
I guess the 0-60 time varies from 5-5.5 s, 4.8 s is possible if you're a professional driver.
BTW a 2006 Corvette Z06 can beat a M3, M5 and M6 in 0-60 run. The only bad thing is that it's a Chevy. In 2008, a super Corvette Z06 with 600 hp will debut, 0-60 will be probably be 4 s. This will be the first 600hp supercar under 100K, I think. Mmmm......thinking of it makes me want to get a Corvette instead of a BMW. Corvettes is my opinion is a bargain supercar.
Old 09-06-2006, 05:04 PM
M3Mike's Avatar
Mein Auto: M3
No argument on the Corvette - if thats your bag its a great bargain fully agree, a bit flashy for my taste, but I do like the new C6 models better than the last generation C5's.
Z06 even better yet.
Old 09-06-2006, 06:13 PM
Augenstein Augenstein is offline
Mein Auto: E46 M3
All true - but wait, there's more!
First of all, I don't think anybody is conferring supercar status based on 0-60 times, but if there actually was a gate on this, it's likely to be below four seconds.
Secondly, people measure this differently. For instance, you will never get an 0-60 time on a stock E46 M3 below five seconds unless you use electronic instrumentation that doesn't start timing until the car has already launched and has rolled about a foot. Such equipment is designed that way to mimic drag strip timers, and the difference is in the vicinity of a half-second or so. If you measure with a hand held stopwatch from clutch drop, a flawless run will likely get you somethingup near six seconds, because now you have to add the time it takes to take up the slack in the drivetrain, plus your speedo is a little behind actual at the time you hit 60 because of needle and mechanism inertia.
Lastly, a zero to 60 time is not a really effective way to determine how "fast" a given car is, assuming faster means "who's ahead?" at any given point. Time to speed has essentially nothing to do with time to distance, so the car that reaches 60 a little later than another car may be ahead of that car at the time. Happens all the time.
Bruce
EDIT: To answer the last question in the OP; No, the M3 isn't a supercar - but it is a performance bargain. There are very few cars on the planet that can outperform an E46 at that dollar point. In fact, on quick reflection I can only think of two: The Corvette and the Mustang GT500. Even then, the Mustang will likely lose (narrowly) to the M3 on a road course even if it is a little quicker in a drag race.
Old 09-06-2006, 06:30 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
4.5 to 7 seconds, depending on the driver. 4.5 is not possible with SMG.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 09-06-2006, 08:15 PM
There are not that many manufactured cars out there with 0-60 time less than 4 secs, most usually costs hundreds of thousands and is only within reach for people in the top 1% of economic status. The cheapest under 4s car I know is the 2006 Porsche 911 Turbo which has a 3.4s timem that's FAST! The 2007 Porsche GT3 has a 4.1s time but it's still considered a supercar. Same for the Corvette Z06 which has a 4.5s time.
What! The E46 M3 is not supercar! I want to drive a supercar or at least a high performance vehicle with supercar acceleration like the Mitsubishi EVO, I was hoping the BMW E46 M3 is the one. BTW, I doubt BMW vehicles can be considered a bargain, same goes to Porsche, Audi, etc because there is a premium price for the brand name. The Chevrolet Corvette is a bargain because the brand name is not premium but the performance is.
Old 09-06-2006, 08:22 PM
The M3 is a massively compromised vehicle that does everything adequately, but nothing well.
Old 09-06-2006, 08:36 PM
Ajax's Avatar
Hydrocarbon Man
Mein Auto: 991 GT3
It will SHIFT between gears more quickly than the average driver, but the SMG control unit will not engage first as quickly as any of us could....just the way the program is.
Old 09-06-2006, 09:59 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
The new Z06 is definitely capable of a sub 4sec 0-60 blast, especially since a 1-2 shift is not required, and requires less abuse than either of P-cars you mentioned.
.................................................. ................................Garrison-Jenner 2016 .................................................. ..........................................
Old 09-06-2006, 10:46 PM
Mein Auto: E46 M3
It depends on what you think the competition is. In the context of world-wide available automobiles, I'd say the E46 M3 is a car that does pretty much everything very well indeed, but nothing superbly. The exception perhaps is the ride-handling compromise, which is the one thing that I believe BMW does pretty much better than anybody else, as a rule. Of course, it doesn't either ride superbly or handle superbly.
Bruce
Old 09-07-2006, 08:18 PM
Moderato's Avatar
Moderato Moderato is offline
VIII
Mein Auto: 07 E92 335i 6MT
The M3 does do one thing well, it makes me feel GOOOOOOOOOOOD! (That's good, not God)
Old 09-07-2006, 08:21 PM
Don't you think if you're driving an M5/M6, you'll feel even better?
Old 09-07-2006, 08:52 PM
Moderato's Avatar
VIII
The M6 maybe, but the M5 no.
Old 09-10-2006, 01:31 PM
SPin1200's Avatar
SPin1200 SPin1200 is offline
Mein Auto: 09 WRX HATCHBACK
0-62(100km)
Absolutly bro, uuc ssk,Itg,Cat-back,6Spd,Mich-SPORT-CUPS, TurnerMotorsport Grand Am Sway front n rear(huge upgrade in perf!), comp steering susp....time card says....4.6:100Km or 4.5:60mph. oh it was also 78 f..but smg tranny cant process tq in excell like a standard, better shift speed and top end though..
Old 09-10-2006, 04:24 PM
Pinecone's Avatar
M Mad
What do you mean it can't process toq??? IT IS EXACTLY THE SAME TRANNY.
The ONLY thing that makes a difference in SMG versus MT off the line is that the SMG does not allow you to choose your launch RPM. From 5 - xx speed, the two are the same, except for driver shifting skills.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 09-10-2006, 10:41 PM
Mein Auto: E46 M3
What time card was that? Is there somewhere you can drive in and get your car electronically timed from 0-60 or whatever?
Bruce
Old 09-13-2006, 12:10 PM
JumpMan495 JumpMan495 is offline
Sleeper
Mein Auto: E60 M5/E39 M5
M3 is definitely no way near the supercar status, its a performance car with great handling and decent power. compared to the E39 M5, 0-60 time is about the same, but after 80mph, M5 will start to pull away.according to the automobile magazine Aug 2006 issue, Chevy is going to built a 650hp Z06 or call it Z07. They will either increase the LS7 engine displacement or just add a supercharger to pump out additional 145hp and that is Ferrari Enzo's category with 1/10th of its price..*****!!
Old 09-13-2006, 01:13 PM
xiliy xiliy is offline
Mein Auto: 2004 M3
yes you can choose your launch RPM with SMG. Turn off DSC , now you will be able to get the 6th bar for your smg shifting speed.Push shifter forward and hold it in that position, now step on gas and start releasing shifter back to its position but do it slowly. Try it a coule of time in the empty parking lot . let me know what you think of that
Old 09-13-2006, 02:53 PM
So I guess BMW doesn't make any supercar for sale then. If M3 is not a super car, then M5 and M6 aren't too. Maybe the BMW M3 GTR is?
Old 09-14-2006, 10:41 AM
Sleeper
its sad to say, BMW company is aiming for mass production vehicles and the sales/profit quota is their primary goal. they will make an engine that fits numerous models of vehicles and make most $$ for the company. making an exclusive super car that only numbers of people can afford is just not their ideology. for example, the most expensive BMW nowaday is the M6 which is around 110k after the msrp, mean while their biggest rival Mercedes's AMG has already push their price tag of the S, CL, SL65 AMG over $180,000 and it could go above 200k after the msrp, and lets not talk about the SLR Mclaren.
M3 GTR is not a super car, its not street legal and its modified from the regular M3, it can consider as a track car for race events. the only super car from BMW that i can think of is the Mclaren F1 93'-97'...WELL...it can ONLY considered A half BMW because ONLY the engine is made by BMW.
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 07:38 PM
BMW Captive Lease Rates - June 2006 LeaseCompare Ask-A-BMW-Dealer 0 06-05-2006 02:43 PM
BMWFS Lease Programs - 11/3/05 LeaseCompare Ask-A-BMW-Dealer 10 12-06-2005 10:22 AM
BMWFS Lease Programs - 10/6/05 LeaseCompare Ask-A-BMW-Dealer 23 11-27-2005 07:35 PM
BMWFS Lease Programs - 9/7/05 LeaseCompare Ask-A-BMW-Dealer 16 09-27-2005 09:46 AM
