Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 09-11-2006, 09:46 PM
h22a193 h22a193 is offline
Mein Auto: 528i
how to hook up sub/amp correctly...
so yea, Im okay with mechanical stuff under the hood, but audio not so good at, so i need to know how to hook up a amp (run a single 12 in sub) ..what do I need? steps? Thanks
Old 09-11-2006, 10:35 PM
jonbth jonbth is offline
Mein Auto: 2006 BMW 325CI
You just need basic wiring skills. Search this forum and other car stereo forums and you will find the info you need.
You need to run a wire with a fuse of the proper diameter from the battery to the amp.
You need a ground wire from the amp to a good ground somewhere in the trunk.
If you have a stock system you need to tap into the speaker wires to run an audio signal to the amp, you might need a signal adaper/converter for that.
Then you need to run speaker wire from the amp to the subwoofer.
I didn't know much about installing stereo equiptment either untill I searched forums and did research. I also bought a few books on the subject.
You can get a lot of info here:
http://www.the12volt.com/index.asp
Old 09-12-2006, 06:25 AM
bscarlett's Avatar
bscarlett bscarlett is offline
Mein Auto: 2011 550xi
I just finished installing my first amp and sub in my 530. I went with the 12" deck mounted sub from BSW. I love the sound and the install was pretty easy. There are pics on my site.
Quite simply you need the following
Power from the positive terminal to the Amp
Ground to a frame of the car to the amp
Splice into speaker wires. (check out my pics for this)
The splices go into a Line Output Convertor and are converted into RCA jacks which go into the AMP
Remote turn on from thin white wire on BMW amp to REM turn on of sub amp
Feel free to ask loads of questions!
2011 550xi Carbon Black/Oyster, M-Sport, Premium Package, Technology Package, Electronic Damper Control, Dynamic Drive, Comfort Access, Active Seats, Surround Cameras
2013 X5 5.0 Space Grey/Black, M-Sport, Technology Package, Comfort Access with Soft close doors, third row seats, Surround Camera
Old 09-13-2006, 12:06 PM
Mein Auto: 528i
so, ok....what gauge wire should i run for a 300 watt system? 8?
also, do i need to buy anything specific to bmw in reguards to hooking up the amp to the speaker, or stock amp? Ive heard of pins...idk, i need a lil more info, Thanks
Old 09-13-2006, 12:26 PM
bscarlett's Avatar
Yes, 8 gauge should be just fine. To connect the aftermarket amp to the factory amp you will need a Line Output Converter. I used the Soundgate LOC4.2. This has 2 sets of 4 wires at one end and RCA jacks in the other. You will use one set of the four wires to splice into the speaker inputs. This is done with butt connecters. The other side of the LOC has RCA jacks and those simplely run to the input of your sub amp. From there just the speaker wire from the sub amp to the amp.
Old 09-14-2006, 09:04 PM
Mein Auto: 528i
thank you!
Old 09-21-2007, 06:41 PM
cbins cbins is offline
Mein Auto: 325xi
http://www.scarlettnetworks.com/bmw/
Seams to be down.. what wires do i tap into for the LOC? Please be specific.
Thanks for all your help
Old 09-23-2007, 06:42 PM
bscarlett's Avatar
Thanks for pointing that out...I missed that folder when I rebuilt my web server.
The pics are back up. Take a look and let me know if you have any questions.
Old 09-24-2007, 04:39 PM
DouglasABaker DouglasABaker is offline
Mein Auto: 2002 Chiaretto Red M5
LOC's are only necessary if your amplifier cannot handle the speaker voltage. The stock stereo isn't that powerful to begin with so any amp that can take speaker level inputs or can handle a 10V low level (ie. MTX's) will not need LOC's.
d-
Old 10-08-2010, 06:43 AM
jkingston jkingston is offline
Mein Auto: 01 325 ci
Adding an aftermarket amp to a 325 ci
First of all, I cannot locate a factory amp at all in this 2001 325 ci convertible. Correct me if I am wrong, but i have looked all in the trunk area and at this point I am assuming there is not a factory amp in the car. It has the OEM business CD with 5 1/4" door and 4"rear side panel speakers. The 2nd question is, will there be a remote on/off out on the OEM deck that I can prompt the amp with ?
Old 10-18-2010, 04:12 AM
GSA1's Avatar
GSA1 GSA1 is offline
Mein Auto: '01 & '02 E39 530i Sports
d-
The headunit sends differential balanced output to the factory amp. If you add or swap amps you will need an amp that accepts this type input. Only a few do. JL is an example, while Most Alpine and Cadence would not work unless the LOC is designed to manage these loads.
The remote wire is white and can be tapped to turn on another or additional amp.
Similar Threads
'99 BMW 328i TOW HOOK COVER... BMWJuve E36 (1991 - 1999) 0 05-01-2006 06:32 PM
What that hook too? Bimmernutcase E46 (1999 - 2006) 2 10-21-2005 02:52 PM
Can you answer this question correctly? markseven Off-Topic 10 11-10-2004 01:44 PM
The Fish Hook Salesman Sabrina Off-Topic 9 11-09-2004 08:13 AM
Can I hook up Xbox to PC Monitor? FireFly Off-Topic 2 02-06-2004 09:58 AM
