Bad IAT symptoms? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-18-2006, 10:38 PM
MN325iSedan MN325iSedan is offline
Send a message via AIM to MN325iSedan
Mein Auto: '93 325i
Bad IAT symptoms?
Still trying to diagnose my rough idle when stopping problem. Anyone know what a bad IAT would constitute? Do IATs ever go bad?
Calypso Red '93 325i
Old 09-19-2006, 05:43 AM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Don't know what you have tried thus far, but my rough idle, often ending in a stall, was corrected by replacing the O2 sensor and fuel pump relay. Obviously, could be so many things, but these two relatively cheap fixes completely eliminated the problem. Oh, and two separate so-called "master mechanics" at German boutique garages in the area told me that replacing the O2 wouldn't do anything, and that I should start with replacing the idle control valve and a bunch of other things, starting at $300 and up up up. Electronic diagnostics did not indicate an O2 problem, but there you go. The O2 and relay cost me a grand total of $85 and it idles smooth, NEVER stalls, and runs like a champ.
Old 09-19-2006, 06:49 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
have you tried this?
http://www.unitedbimmer.com/kb-e36-icvcleaning.php
2001 Mini Cooper R50
Edirty6 for life
Old 09-19-2006, 07:16 AM
Mein Auto: '93 325i
Yup, used that exact writeup 2 weekends ago and cleaned the ICV. The thing is it only idles rough when coming to a stop, after the car has sat for an hour or so, and smooths out after 10 or so minutes.
Old 09-19-2006, 07:32 AM
Still here
Mein Auto: M3
Sounds like it could be a vacuum leak somewhere
Edirty6 for life
Old 09-19-2006, 07:44 PM
If it's a vaccuum problem, check your mass air boot for tears, cracks, or misalignment. Found a rip on the underside of mine which wasn't noticible until I removed it. It's an easy fix if that's the problem; attached by two common hose clamps. New ones are about $40. If you're going to have a vaccuum problem, that's the best place to have one!
Old 09-20-2006, 01:58 AM
Still here
Mein Auto: M3
I too had this problem with a tear but only had acceleration problems, she idled fine.
Maybe check your throttle body is clean, she maybe letting in too much air because the butterfly is not closing properly
just take off the intake boot and thoroughly clean the inside of the throttle body with carb cleaner. black tar and deposits build up here and can cause all sorts of problems......FREE FIX!!!
Edirty6 for life
Old 09-20-2006, 10:35 AM
Mein Auto: '93 325i
But the throttle body would be closed when idleing...
Old 09-20-2006, 11:32 AM
lesl2 lesl2 is offline
Mein Auto: '97 & '99 M3, '02 530
A torn boot is a pre-throttle valve leak, which I suspect should not cause such a drastic issue such as killing the engine. A post-throttle valve vacuum leak however would cause a condition that would stall an engine during idle. This can be simulated by taking the oil cap off. BTW, did you happen to leave your oil cap off accidentally? If not, then take it off and see if it makes a big difference. It should. If not, get a vacuum meter and test it. I believe you can rent one free from Autozone.
'97 M3 Auto
'99 M3 5 speed
'02 530i Sport/Premium Package
Old 09-21-2006, 01:59 AM
Still here
Mein Auto: M3
The butterfly is closed indeed when idling, but the dirty deposits cause the mixture at idle to be incorrect. They stop the plate from closing completely and so letting more air in than expected. The engine thinks it is closed but more air is getting in than expected. it is the same as the unmetered air Lesl2 is talking about above.
Take the boot off and inspect it, while it is off, you may as well check the throttle body too
Edirty6 for life
Similar Threads
Speaking about bad cell service, who hates Sprint as much as I? Jever Off-Topic 12 09-22-2003 09:33 AM
'98 M3 with bad rings. Engine removed today. Emission 1M & M2 5 07-30-2003 10:36 AM
3 damages in one bad day yamato The Detail Department 2 07-03-2003 05:40 PM
m3 CSL.. not bad.. 330iGT General BMW Questions 9 06-28-2003 01:41 PM
