Old 10-02-2006, 08:20 PM
kgleason kgleason is offline
Mein Auto: 2002 BMW 540i
Talking This was cool
I have a Silver 2002 540i 6 speed sport, pp, cw package. Just picked up from 50k service. Stopped at a light and a 2005 silver 545i pulled up next to me. Not sure if he had a stick or not but while he initially pulled about 2 feet infront of me, once I hit 3rd gear he quickly faded and it wasn't like he wasn't trying. Does anyone have any experience with the 2004 + being a little slower? maybe new body stle is heaver not tunned the same. I know it has more horse power, I was shocked that I beat him. Maybe he just didn't know how to drive. Once I hit 120 I backed off and let him pass.
Old 10-03-2006, 01:28 AM
1UZFE 1UZFE is offline
Hoz are nothin' but Showz
Mein Auto: 540i
He lost because he had slushbox
Old 10-03-2006, 04:35 AM
RPM Photography's Avatar
RPM Photography RPM Photography is offline
Send a message via AIM to RPM Photography
Mein Auto: 2003 540i M-Sport 6 Speed
As I recall, the E60 545i isn't really any faster than the E39 540i. So if the E39 has the six speed and you know how to use it well, you should win.
Jack Miles
AIM-RPMPhotographyJM
2003 540i M-Sport Six Speed
1987 Mercedes-Benz 190e 2.3-16
1986 Mercedes-Benz 190e 2.3-16
1989 Mercedes-Benz 190e 2.6 5 Speed
Need your ride detailed? PM me for details.
Old 10-03-2006, 04:56 AM
franka franka is offline
Mein Auto: E39 540i Sport
Maybe he didn't know he was in a race.....
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 10-03-2006, 06:48 AM
AirFrcd's Avatar
AirFrcd AirFrcd is offline
Mein Auto: e46 M3
I have raced a close friend of mine who owns an e60 545i and I have beat him on multiple occasions by at least 1-2 full car lengths from launch to +/- 135mph.
We both have the SMG trannies, and my car is a blown 530 w. a bunch of other goodies (i.e. 4.10's...)
I can do everything through Him who gives me strength.
Philippians 4:13
Old 10-03-2006, 09:31 AM
JumpMan495 JumpMan495 is offline
Sleeper
Mein Auto: E60 M5/E39 M5
its hard to believe that a 530 has a smg or beat a 545
Old 10-03-2006, 09:37 AM
n3rd n3rd is offline
Mein Auto: E70, GT4, RRS
Jumpman search and you'll see what airfrcd's set up is.
Old 10-03-2006, 09:43 AM
SilverE39's Avatar
SilverE39 SilverE39 is offline
Mein Auto: '01 530i S/P 5sp
+1
OEM M5 F Bumper | EuroDyne R Bumper | Magnaflow Exhaust Manifold and Full Cat-Back Exhaust | Koni+H&R Sport | CDV Deleted | Eibach f/r sway bars
Hard-wired V1 Radar | E60 shifter w/ZHP shift knob | 18x9 Style 42 | Continental DW 255/40 | Zimmermann XDrilled F/R w/Akebono Euro Pads
35% Madico tint | Infinity Basslink | E0n0n D5201Z Navi | Thule Bike Rack
Old 10-03-2006, 10:23 AM
roadie's Avatar
roadie roadie is offline
Mein Auto: X5 3.5i, 911C4, C230
Errr...Are you sure you have SMG - or you have an auto transmission with the paddleshifter? They are completely different things. In my experience, SMG set to the aggressive setting will kill a 6spd manual. On the track, SMG consistently beats a 6spd shifter because it shifts perfectly every time. That's why it's used in M3.
EXCERPT FROM A CANADIAN PUBLICATION:
October 18, 2002
What is an SMG transmission?
The Sequential M Gearbox (a $4,900 option on the M3 Coupe and Convertible), is essentially a six-speed manual gearbox where the clutch and gearbox are operated electro-hydraulically by a computer in response to the driver pulling on two paddles behind the steering wheel, or by pushing a floor shifter forwards or backwards. There is no clutch pedal. As well, the SMG is capable of operating completely automatically if desired.
Die-hard manual transmission enthusiasts may find it hard to believe that an electronically-controlled transmission without a clutch pedal could be more satisfying than a traditional manual gearbox. I'm not going to say that it is better than a traditional manual gearbox, but there are some advantages which make it possible to drive the M3 more smoothly and safely at higher speeds, and add an element of excitement that wasn't there before.
Gearshift system of the sequential M gearbox. Click image to enlarge
First, note that the SMG system is not an automatic transmission than can be shifted manually - like BMW's Steptronic or Porsche's Tiptronic - it is a manual transmission with a clutch, but without a clutch pedal, that can change gears by itself in response to driver input. BMW developed the SMG in close collaboration with Getrag and Sachs, and uses a similar technology in the Williams BMW Formula One racing cars.
After you get into the car, you'll see a small (too small, in my opinion) orange LCD display in the instrument cluster that tells you what gear, or mode you are in. 'R' is for Reverse, '0' is for neutral, 'A' is for automatic, and 'S' is for sequential. This display is not only small, but confusing because the automatic mode includes an 'A' and an 'S' symbol, while the sequential/manual mode has an 'A' symbol in a different font type. As well, I'm not sure why '0' stands for Neutral. It took me a while to figure out what mode I was in.
The system also includes a 'DriveLogic' button just behind the gear lever that allows the driver to adjust the speed of shifts and the shift points using six different settings.
To start the M3 SMG, your foot must be on the brake and the shift lever in '0' mode while the ignition is on. Turn the key, and the 333 horsepower inline 3.2 litre six cylinder engine roars to life, emitting a dull rumble from the M3's quad tailpipes. The SMG can be changed between manual and automatic modes any time while the car is running simply by tapping the floor gear lever to the right. Tapping to the left will put it into Neutral.
Sequential M gearbox. Click image to enlarge
Just behind the steering wheel are two large, flat 'paddles' which can be reached with your fingertips while holding the steering wheel in the '9 and 3' or '10 and 2' positions. To shift up, the driver pulls on the right '+' paddle, and to shift down, the driver tugs on the left (-) paddle. Alternatively, the driver can shift up by pulling back on the floor gear lever, or change down gears by pushing forwards. (This is the opposite direction to that of some semi-automatic transmissions.)
The SMG DriveLogic system has six settings: the lowest setting starts the car off in second gear, shifts sooner, and goes into sixth gear more readily to save fuel - the highest setting starts off in first gear, revs the engine higher before shifting, and tends to stay in lower gears to keep the engine revving faster for more responsiveness. It's also more aggressive when downshifting.
Experiencing the SMG
Let's talk about the Automatic mode first. My experience, after driving the M3 around town in rush hour traffic, is that it's easier to let the transmission shift automatically in this type of driving environment - even though there's no clutch pedal. Under moderate acceleration in the Automatic mode in the lowest DriveLogic setting, the transmission shifts gears at about 2500 rpm, and shifts slowly - even slower than you might with a normal manual transmission. At the same acceleration rate but at a higher DriveLogic setting, the transmission will shift more quickly at higher revs, usually about 3500 revs. If you really put your foot into it, the shift points go even higher. When slowing down or when coasting down a grade, the SMG will automatically shift down gears, and when braking, the downshifts become more aggressive.
Compared to a regular automatic transmission, the SMG is more performance-oriented, but depending on the DriveLogic setting and your driving style, the shifts are generally not as smooth.
In Manual mode, things get exciting. In the lowest DriveLogic setting, shifts are slower and less aggressive, but in the highest setting, shifts are faster at higher revs. Under hard acceleration in the maximum DriveLogic setting, the shifts are much faster than you could do yourself BMW says the fastest shifts take just 80 milliseconds - and they're aggressive enough to jolt the rear-end quite severely.
Further, if the driver chooses the highest DriveLogic setting and turns off the DSC (Dynamic Stability Control), the SMG shift times "match the sporting performance of a true race car," reports BMW. In this situation, the driver can make use of what's called the "acceleration assistant". By pushing the gear lever forwards and keeping it in that position while stopped, and then pressing the gas pedal to the floor, the engine will rev to the "optimum" starting speed. The driver releases the gear lever, and the M3 accelerates "with optimally controlled slip". BMW says this function is unique to the M3.
I wasn't able to confirm whether the M3 SMG is faster in a straight line than the M3 with a standard six-speed manual transmission, but with the quicker shifts, I suspect it's probably about a half second faster than the 5.5 seconds it takes for the M3 Coupe 6-speed to go from 0 to 100 km/h.
The speed of downshifting with the paddles varies with the DriveLogic setting as well: softer shifts at a lower DriveLogic setting, faster shifts at a higher setting. The most amazing thing is that the SMG system does its own double-clutching - that is, blipping the throttle to match engine speed to the transmission speed to make shifts smoother - when downshifting. And it does it much faster than any driver could do manually with a standard manual transmission. Observers who don't know you have an SMG transmission will think you are a really, really good shifter.
Keeping both hands on the wheel
The ability to keep both your hands on the wheel is a definite advantage of the SMG system because it gives you greater steering control. However, there are some situations where it's difficult to keep both hands on the wheel while shifting with the paddles. When accelerating from a standing stop while turning a 90 degree-plus turn, it's necessary to change into second gear before the turn is completed, and it's difficult to reach the paddle with the right hand at that severe steering angle. The same thing applies when negotiating sharp turns when shifting is necessary. In these situations, I found myself using the floor lever.
As the SMG is very similar to a manual transmission, the car tends to roll back when starting on a hill. To prevent this, a special function called the "climbing assistant" can be engaged in either manual or automatic modes for forward or reverse travel. All the driver needs to do is to depress the brake pedal and pull the paddle for a short period of time. When the brake is released again, the M3 is ready to drive away within two seconds without first rolling back.
The SMG has some safety features: if you slow to a stop without shifting down gears, the SMG will automatically shift down to first or second gear. However, if you forget to shift up when accelerating, the SMG will not automatically shift to the next gear (unlike many automatic/manual transmissions such as the Tiptronic). It will, however, prevent you from over-revving the M3's very expensive motor.
On one occasion, I mistakenly pulled the left paddle instead of the right paddle, sending the engine up to its rev limiter. It takes a while to get used to which paddle upshifts and which paddle downshifts and which way the gear lever is pushed to upshift and downshift and in the excitement of spirited driving, mistakes can be made.
Overall, I found the SMG transmission has a distinct advantage over a regular manual gearbox in its speed of downshifting and upshifting and the secure feeling of being able to grip the steering wheel instead of fumbling around for the gear lever. Still, as I mentioned, tight turns make it difficult to operate the paddles. As well, drivers raised on the traditional push-in-the-clutch, pull-back-the-gear-lever, let-out-the-clutch will find it hard to get used to this new, simpler system. In a way, the SMG's automation takes some of the fun out of shifting.
Old 10-03-2006, 10:32 AM
Brevity= the soul of wit
You're right, he doesnt have SMG. Just the paddle shifters on a sport Auto. But a blown 530 with 4.10 gears will walk an E60 until the gears make the redline run out of room in 5th.
Old 10-03-2006, 10:34 AM
Don't forget the E60 M5 and M6, too!
Old 10-03-2006, 11:10 AM
AirFrcd's Avatar
Mein Auto: e46 M3
I stand corrected - Prop, you are correct w. re. to the sport auto and paddleshifters +/-
Philippians 4:13
Similar Threads
Inspection II, good service experience and a cool loaner gek330i General BMW Questions 13 12-11-2006 07:05 PM
Semi OT: Got Some Cool Vintage (?) BMW M Gear... Ben Carufel E36/7 Z3 (1996-2002) 12 06-30-2006 12:48 AM
Xenon Lights Turn Really Cool tonymey X3 E83 (2004 - 2010) 9 01-26-2006 05:27 PM
Old but cool ZHP Review tehkao E46 (1999 - 2006) 0 06-21-2005 03:53 PM
Did you guy's get any cool things? ICEBERG X3 E83 (2004 - 2010) 25 04-02-2005 11:37 AM
