Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Navigation, Audio & Electronics by BAVSOUND
BMW navigation, audio upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Sponsored by BAVSOUND
Old 10-06-2006, 05:39 PM
Franks 95 325i Franks 95 325i is offline
Mein Auto: BMW 325I sedan
e32 stock radio wiring diagram/HELP
I pulled out the stock Radio to ymy 1990 735il and need to know the code Please.
I have a CD player to install but have no Idea what wire goes to what and is there an Apm that must be bypassed etc. Please help. Thanks
Old 10-07-2006, 09:49 AM
esoteric esoteric is offline
Mein Auto: Just about everything
RADIO HARNESS
Wire Function Color Note Fuse # Size Location
+12V DC Battery(Constant) Red/white F41 30 amp Rear power distribution box
Switched Accessory Violet/white F18 15 amp Front power distribution box
Ground Brown
Power Antenna White
Remote Turn On(output) White
Illumination Gray/black
AMPLIFIER OUTPUTS
12V DC Battery Red/white F41 30 amp Rear power distribution box
Remote Turn On (input) White
Left Front Mid + Yellow/white
Left Front Mid - Yellow/brown Splits to the 3 left front speakers
Left Front Tweeter + Yellow/green
Right Front Mid + Blue/white
Right Front Mid - Blue/brown Splits to the 3 right front speakers
Right Front Tweeter + Blue/green
Left Rear Mid + Yellow/blue
Left Rear Mid - Yellow/gray
Left Rear Tweeter + Yellow/black
Right Rear Mid + Blue/violet
Right Rear Mid - Blue/gray
Right Rear Tweeter + Blue/black
Subwoofer 1 + Yellow/red Left front low range speaker
Subwoofer 2 + Blue/red Right front low range speaker
AT SPEAKERS
Left Front Tweeter + Yellow/brown
Left Front Tweeter - Yellow/green
Right Front Mid + Blue/green
Right Front Tweeter - Blue/brown
Left Rear Tweeter - Yellow/gray
Right Rear Tweeter - Blue/gray
Available Notes
Notes
The radio has a fuse of 6.3 amperes & the amplifier fuse is of 10 amperes.
The CD player is powered thru a red wire; it has the same fuse (F41) as the radio.
12 VOLTS Red Ignition harness +
IGNITION Green Ignition harness +
ACCESSORY Purple Ignition harness +
STARTER Black/yellow Ignition harness +
KEY SENSE Blue/black Ignition harness -
TACH SIGNAL Black At diagnostic plug AC
LOCK White/red In driver's kickpanel +
UNLOCK Blue/brown In driver's kickpanel +
DOORPIN SEE NOTES
TRUNK PIN White/brown At alarm module -
TRUNK RELEASE Manual release
FACTORY ARM Arms with lock wire
FACTORY DISARM Blue/violet
BRAKESWITCH Blue/red At switch above brake pedal +
PARKLIGHTS Gray/yellow & Gray/purple At light switch harness +
HORN Brown/red At steering column -
HEADLIGHTS Yellow At light switch harness +
REVERSE LIGHTS Blue/yellow DKP in harness to back of vehicle +
DIMMER Gray/red At dimmer switch harness
VSS WIRE Brown/red At instrument cluster harness
WEBSITE:
Similar Threads
My Stock RADIO SUCKS. Is that typical? M-Coupe-2Black E36/7 Z3 (1996-2002) 3 08-07-2004 05:41 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
Stock radio replacement question drewmvshs 5 Series 5 05-06-2004 11:48 AM
keyless problem and WTB stock radio Bruce E36/7 Z3 (1996-2002) 22 12-09-2002 07:24 PM
XM Radio can be had in our cars thru stock system OrientBlu 330Ci 3 Series & 4 Series 10 09-30-2002 08:32 AM
