Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 10-09-2006, 04:50 AM
s0caL.e39 s0caL.e39 is offline
Send a message via AIM to s0caL.e39
Mein Auto: 1998 528i
Question 528i moonroof ?'s
First off i'd like to say this DIY forum has helped me out tremendously and thanks to all.
The moonroof has been given me problems for awhile now. While open and when pressing the button all the way forward the moonroof begins to slide forward. However, just as it is about to fully close itself, it automatically opens back up about 3 inches. And in order to fully close it the button has to be pressed with a series of quick short presses which causes almost a grinding type of sound for split second after shut.
Also, I have never been able to get it to tilt either. When I attempt to you can hear what must be the motor to the roof starting and a horrible sound. It seems that the moonroof is stuck in the flat position and wont budge up. Any help would be appreciated and thanks again.
Old 11-01-2006, 09:45 AM
ez2456 ez2456 is offline
Mein Auto: 525i
Hi. I am having almost the exact same problem on my 01 525i. Have you heard from anyone with a solution, or have you otherwise resolved theproblem?
Old 11-05-2006, 10:15 AM
St8kout St8kout is offline
Mein Auto: '97 528i
Try this:
Reset sunroof or window by holding down the close switch button for approximately 15-30 seconds; otherwise, check for mechanical failure.
http://www.540i6.com/probsfixes.html
Also, you could try 'rebooting' the car by disconnecting the battery ground strap for 5 minutes. This will reset all your electronics including your radio presets and your ECM fuel management system. This just means your car's computer will relearn your driving habits all over again. No big deal. As always, don't create a spark next to the battery. I always disconnect the ground strap from the car body, not the battery.
You might have to maually close the sunroof first (if it's not closing) using the tool in the trunk lid's tool case - see your owner's manual. You can try it both ways if it doesn't work the first time.
Edit: I just noticed you mentioned grinding sounds. That's not good. Once you get it closed I wouldn't open it again until I was ready to have the mechanism replaced. Not an easy DIY.
Old 11-07-2006, 05:02 AM
n3rd n3rd is offline
Mein Auto: Acura TL
If your sunroof wont tilt, sorry to say this but its dead. Do you hear ticking or a rapid set of clicks from the roof area?
Anyway... Look for my walkthrough on how to remove and replace the sunroof. I'll try to get it uploaded this weekend.
Old 11-22-2006, 04:03 PM
I've tried the few remedies that have been posted in here and I'm sorry to say none have worked. The reseting of the window actually made it worse! I do hear a series of clicks and will appreciate it whenever you get that walkthrough uploaded! Thanks to all who've tried to help out!
Similar Threads
98 528i water pump replacement ?'s aharper E39 (1997 - 2003) 3 05-14-2006 01:41 AM
Are the BMW 528i, and the 525i the same powerwise? BMW528i_Bilal 5 Series 7 02-05-2005 11:14 AM
malfunctioning moonroof on 528i bmwmarc 5 Series DIY 1 08-14-2004 04:36 PM
Moonroof problems in my 330Ci ayn 3 Series / 4 Series 20 07-27-2003 10:13 AM
