Old 12-06-2002, 11:26 PM
Ron Stygar's Avatar
19,585 Miles
Z3 Heater operation
When you move the heater temperature control knob off of the minimum temperature position, it closes a switch and opens the heater valve. This sends water to your heater coil (core).
On the M's, it also shuts off the auxiliary water pump.
If you continue to turn the heater control knob, it reduces the amount of outgots air bypassing the heater core. Outgots, is air coming in. Ingots/outgots came from where I used to work.
At work, ingots was the indoor temperature. Outgots was the outdoor temperature.
So if the outgots air is really cold, the knob ends up at the maximum temperature position.
Old 12-08-2002, 02:35 PM
Randy Forbes's Avatar
Investigative Tinkerer
Re: Z3 Heater operation
Funny, where I used to work (and from another former Boeing guy...) we had "goes-inna's & goes-outa's".
For us, goes-inna's was the input signal (or voltage) and goes-outa's was the output signal (usually 4-20 ma).
Different part of the country, I guess...
Randy Forbes
2001///M Rdstr Steel Gray
Old 01-06-2013, 12:58 PM
hwatson hwatson is offline
Mein Auto: 2001 BMW Z3, 2.5i
How do you test the water valve control switch?
Old 01-06-2013, 02:03 PM
Ron Stygar's Avatar
19,585 Miles
Valve
From Z3FAQ:
http://www.bimmerfest.com/forums/sho...1&postcount=67
Old 01-06-2013, 02:19 PM
Thanks. This helps a lot.
Henry
