Old 10-11-2005, 12:06 PM
corgicoupe corgicoupe is offline
Mein Auto: 2006 M Coupe
Originally Posted by 01silber
moving the temp. control opens the blend door to allow heat from the heater core into the ducting, hot air will always over take cold air
But it used to be gradual. Turn a little and get warm air; turn a lot and get hotter air. Now, just cracking it causes the air to be full hot; no gradation possible.
Old 01-09-2007, 10:38 AM
drsantos drsantos is offline
Mein Auto: 2000 Z3 2.8
Has anyone looked into replacing these bulbs with LEDS?
[SIGPIC]
Old 03-25-2007, 10:49 AM
bird67 bird67 is offline
Mein Auto: bimmers
Resurrecting old thread
This thread is extremely helpful in explaining how to access these HVAC bulbs. I was able to get to the bulbs pretty easily.
But now, I have a different problem - I only intended to change the bottom bulb. I went to the auto parts store, found the GE #37 bulb, inserted it, and reassembled. NO WORKY! Not only that, but the other bulb - the one that is behind on the passenger side - doesn't work either! I checked fuses, none seem to be blown. Any suggestions as to what I did?
Old 03-25-2007, 10:55 AM
kostverloren's Avatar
kostverloren kostverloren is offline
Mein Auto: DINAN Z3 3.0,535i,MINI
No Light
I'm thinking that you've got to re-check the connecters to both bulbs.
Old 03-25-2007, 11:19 AM
Ron Stygar's Avatar
19,585 Miles
If you shorted the wiring, the headlight switch dimmer rheostat blows. Not a fuse.
Do you have dimmed lighting on the other items?
Old 03-25-2007, 11:30 AM
Mein Auto: bimmers
I do, and everything else is dimming properly - speedo gauge cluster, switches on console, gauges on console (M coupe console). I don't understand how I could have shorted anything, all I did was pull out the bulb holder from the positions in the back of the HVAC unit. Any other thoughts? Help much appreciated!
Old 03-25-2007, 11:32 AM
Ron Stygar's Avatar
19,585 Miles
Try the BMW bulbs.
Old 03-25-2007, 11:44 AM
Ron Stygar's Avatar
19,585 Miles
Try the BMW bulbs.
I have three BMW lamps for sale if interested.
They now retail for $6.95 each.
$4.22 each plus shipping via check.
Old 03-27-2007, 03:37 PM
Mein Auto: bimmers
Ron, your advice and posting on your site about this is great. Following your advice and gettin some bulbs locally I was able to find the problem and fix it in about 20 minutes. Thank you for the help and for the offer of the bulbs for such a good price. You make tackling mods a whole lot easier!
Old 03-28-2007, 06:56 AM
rjcoston's Avatar
rjcoston rjcoston is offline
///M Practical
Mein Auto: 00 M Roadster
So was the problem the non-BMW bulbs?
Old 03-29-2007, 03:02 AM
Mein Auto: bimmers
Yep. I tried replacing just the bulbs, not the holders, with a corresponding GE bulb from a parts store. It didn't work. I then went to the dealer and bought the bulbs with the holder in a single unit. Plugged in the dealer version, it lit right up. Conclusion: dealer part is cheap enough, no need to try to find a substitute.
Old 07-04-2007, 03:48 PM
postalZ3 postalZ3 is offline
Hey Ron, do you still have those light bulbs? If not, do you have the part number? Both are out in my Z.
<img src=http://i.imgur.com/JMjPR.jpg border=0 alt= />
Old 07-04-2007, 03:56 PM
Ron Stygar's Avatar
19,585 Miles
I have three. Email me.
ronstygar@aol.com
Old 07-04-2007, 04:07 PM
e-mail sent
Old 07-09-2007, 07:20 PM
WILLYALBRECHT WILLYALBRECHT is offline
Mein Auto: 2001 2.5 Z3
My experiance with the dealer( was a module change out) under warrenty for $879 for my 2001 2.5 roadster. A little more then the price of two bulbs.
thanks for the information.
Willy
Old 07-15-2007, 09:46 PM
Just a big thanks to Ron for the bulbs. Everything is now iluminated. Now I noticed that the cigarette lighter does not, is there a bulb back there? How do you get to it?
Thanks again Ron
Old 07-16-2007, 06:12 AM
Randy Forbes's Avatar
Investigative Tinkerer
Thanks again Ron
You knocked the bulb holder off the outside of the lighter while you were in there.
You'll want to correct that before the hot bulb lays against something it shouldn't.
Might be able to reach up the side of the console, depending on the size of your paws.
Randy Forbes
2001///M Rdstr Steel Gray
Old 07-16-2007, 07:33 PM
Thanks Randy, the bulb was out of the holder but also burn out, good thing I had a spare (2721 1.2w) laying around and was able to reach it by the side of the console as you sugested.
Tony
Old 08-01-2007, 11:36 AM
JT///M3's Avatar
JT///M3 JT///M3 is offline
10 YEARS!!!
Send a message via AIM to JT///M3
Mein Auto: 08 Sepang M5
Any update on an LED bulb for this application? Oh god, I should have tried to change both the bulbs out when I did this the first time. Now the RIGHT one is out.
08 M5 Sepang/Portland - Modified
11 328 LeManns/Oyster - Modified
06 Mini Cooper JCW GP 1281 - Sold
10 Mini Cooper S Laurel Sport - Sold
99 MCoupe Arctic Silver---> Laguna Seca Blue - Sold
01 740i Sport Titanium Silver- Sold
04 X5 4.8is Estoril - Sold
98 M3/2 - His - Sold
97 M3/4 - Hers - Sold
Old 08-01-2007, 11:26 PM
JT///M3's Avatar
10 YEARS!!!
Ok, nvm, it came back on it own...weird
Old 09-17-2007, 02:00 PM
ZGator ZGator is offline
Mein Auto: Z3
Just finished replacing both of my bulbs, boy that one in back is a bit tough to get out - tiny pliers might have helped. Thanks Ron for all the great pics. Did you actually buy that HVAC control just to get a nice picture?
I had an interesting side effect - now my temperature gauge actually allows warm air rather than producing heat only when almost all the way to hot position (it used to be more like an off/on switch). Must have been from bending it around to get to that back bulb - caused some linkages to change. I like it better now and it does feel a little different.
Old 09-17-2007, 02:15 PM
Ron Stygar's Avatar
19,585 Miles
Yes and a spare when I was keeping the Z3 forever.
Sold it to Dr. Burr when I sold the Z3 and I think that he sold it
to someone at HC. He sold his Z3 recently.
Old 02-04-2008, 10:06 AM
QuestMCoupe QuestMCoupe is offline
Send a message via Yahoo to QuestMCoupe
Mein Auto: 2000 M Coupe
I know this is an old thread but I'd like to thank Ron for posting those pics. They definitely helped locating the bulbs on the HVAC.
Does anyone know a place online that sells these bulbs so I dont have to drive down to the dealer and order them?
Old 02-04-2008, 10:54 AM
greyish's Avatar
greyish greyish is offline
tire consumer
Mein Auto: 99 z3c
here.
There are others, but that is a good price relative to others.
Of course, that site (if I'm not mistaken) also came to my knowledge via Ron.
Old 02-04-2008, 11:24 AM
Thank you very much!
