E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
#51
Thanks to everyone who contributed to this thread! It made what would have normally been a 5 hour disaster turn into a 15 minute job. My two cents though...once you get the radio out, it's insanity to try to pull the AC panel through the radio opening. You guys who were able to do that are magicians. I had to change the bulbs while the panel was loose, but still behind the dash. Still a fairly easy job, but it just took a while to figure out how to fit both hands in there at the same time.
#52
I don't think anyone has pulled the panel out through the radio opening. It's just a place to put your hand in to get to the back of the HVAC controls.
Daniel 2002 M roadster |
#53
Ya, sorry...misunderstood that. Shame on me
#55
Back from the dead. Does anyone have a pic showing where the cigarette lighter bulb holder is located. My bulb is dangling. Thanks
#56
there's a hole for it along the side
#58
As Randy said, unless you have tiny paws, the best way to get it back in place is to go at it from the driver side footwell. Remove the panel that's over the pedals, remove the two screws that hold the center console to the underdash panel, lay in the footwell and reach in there with your left hand. You can get it back in place by feel without seeing it. Pay attention to the door chime, it's all too easy to knock it off.
#59
Thanks for the info. One more tip for that pesky left side HVAC bulb, on M models, if you remove your middle gauge, you'll be able to see the left side bulb holder through the hole in the 10 o'clock position. You can reach through the hole and pull it if you have super strong fingertips or you can use a needle nose pliers. This is assuming, you can reach through the stereo opening to turn the collar behind the gauge in order to first remove the gauge.
#60
My pain is your gain.
After a failed attempt without removing the HVAC assembly, I decided to go for it one more time.
I don't remember replacing a pair of bulbs being this gory . Please be carefull when pulling on the plastic lock for the radio wires:![]() Tools used for this operation: ![]() The mirror helped orient me with the back layout. ![]() Removing the E106 bulb was a lot easier with the HVAC assembly still attached. I didn't want to twist and move it around to much just to get to the bulb later. ![]() I decided not to remove the bulb from the wire to prevent the occasional opsies and dropping the bulb disappearing in the web of wires forever. Just be careful with the needle nose when pulling. Make sure you have a firm grip on the plastic body; you don't want your pliers to slide when yanking and accidentally pulling the wires instead. Hidden behind cables and plastic arms is the second E105 bulb...what great placement: ![]() This is the part were the HVAC assembly needs to come off: ![]() Just support the assembly with one hand and remove the bulb with the other. The less you disturb the cables of the HVAC the easier it is to install back IMHO. ![]() Check if the lights work before plopping the assembly back. ![]() Putting back the HVAC assy. wasn't as hard as others described, it's just a matter of taking your time & familiarizing yourself with the layout. Check if all the chrome rings are in place. line up the bottom of the HVAC assembly first with the center console, then snap the top in place. Finally, do not forget the ziploc on the self dimming rearview mirrors before tucking your Z away for the week ![]()
#61
Now, six (6) years later, since this thread is still used for reference, I'll update it with some new pictures. Note that while not shown, the head unit has to be removed first, so be sure to have the security code if it's the factory unit. The CD head unit requires a 2.5mm Allen wrench to remove, the cassette player takes a special five (5) sided tool available from the dealer. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
#62
My 318ti is similar and uses just one of the same bulbs. Going on twelve years.
#63
Great pictures Randy and btotoro! Thanks.
#64
subscribing for some great info!
1124 U-R-not-E
#65
My fan speed light, the temp gauge under it and the clock all have lights that go off for a while and then come back after going over a bump or smacking the console. So something must be loose right? Any ideas what to look for since the lights aren't actually out? Aftermarket stereo wiring might be pressing against something or loosened eventually after installation?
#66
I did mine the easy way. I recently had to have the a/c evaporator and expansion valve in the dash replaced to the tune of $1200+ and asked them to replace the bulbs while they had the entire dash apart!
Greg H 1999 M Coupe (daily driver) 2002 Spec Miata race car 1993 Porsche 911 RS America 1976 Triumph TR6 2001 Ford F250 crew cab 4x4 diesel (track support/tow vehicle) |
#68
Do the sides of the console in the footwell come off? Last edited by 00MR; 06-23-2009 at 12:31 AM. |
#69
So if I need to do the lower row as well, are they the same bulbs and how many? Randy's pics of bottom row above magically got fixed. Any trick to doing bottom row?
#71
#72
I had a broken hot/cold control arm on my 2000 Z3 where it engages the serpentine groove which is just a plastic tit at the fulcrum of the arm. Well the tit broke off when the blend door was binding up a bit. I removed the arm and drilled a hole in it where the tit was and threaded in a ball link from a remote control airplane servo. You can get them at most hobby stores. It worked perfect and is much stronger than factory. Added weight is negligible!
#73
Thank you everyone for the great info. Even though my lights would sometimes come on for a little while with a good dash smack or road bump, they were obviously bad when I pulled them out and examined them. One extra note - keep checking as you reassemble to make sure the lights don't pull out. Mine didn't stay in very well.
#74
Bulb For Power Jack
Z3 Heater Control Repair
Hi All,
This is my first first post. I have to thank all of you for the tremendous info and great pics. I used your experience to repair the "notorious" broken plastic pin issue on the temperature control. Following your radio and control panel removal/release instructions, I was able to rotate the panel within the radio opening to expose the rear side. Yep, the plastic pin broke off and was still sitting in the track. Using it to determine what would be a proper substitute, I happened on the idea of using a 1/8" diameter x 1/2" long aluminum pop rivet. After protecting the center circular dashboard opening (where the temp control lives), I drilled through the control arm at the exact location of the old plastic pin. In order to expose as much of the rivet as possible on the "track" side, it was important to ensure a tight fit for the rivet so the riveting tool could release it with only 1-2 squeezes. Voila. Works really well. I suspect that other parts of the car will break before this does. I hope that helps someone out there. You folks saved me a lot of dough. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
