E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
| View Poll Results: Which Gauge Set-up to go with? | |||
| Oil Press, Voltmeter, Oil Temp. |
21 | 77.78% |
| Oil Press, Clock, Oil Temp. |
6 | 22.22% |
| Voters: 27. You may not vote on this poll | |||
Gauge Panel Poll
Getting ready to install the M Console in a week or two. I am going to go with VDO Series 1 Gauges.
Option 1: -Oil Pressure, Voltmeter, Oil Temp Option 2: -Oil Pressure, Clock, Oil Temp Please note that the gauge faces are black, not the gray they appear to be in the pics. Which set-up looks best and which is more functional (non-daily driver).
![]() Follow us on Facebook for news and current promotions08 E82 135i | 02 Z3 Coupe | 01 R1100S |
for non daily driver i would say the voltmeter set up
but the clock is more handy on a daily driver max |
Volts.
We will get the goddamn OBC to work and put the OBC on an a-pillar pod. We can suede cover the a-pillars so the pod is invisible.
Jon Maddux 10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe |
i was going to make a obc comment but didint know andy good enough and thought he would get mad at me
I'm not putting an OBC in my car.
You can always velcro on a cheap digital clock from Radio Shack.
Terry Carraway '95 Alpine M3 LTW '00 Dakar M Roadster '02 Topaz M3 Red/White SRF #4 (Chassis 561)
Don't 'cha own a wristwatch?
Forget the clock |
).Will end up going with the Voltmeter but I am still not sure about the red-green band along the top. May have to swap out for a new one.
You don't like the Vision series?
2 main reasons: 1. Series 1 illuminates from the edge not the center. I prefer this look over having the light coming from the center of the gauge. 2. I prefer the Series 1 font and overall appearance (Feel it better matches the Z3 dash). Both reasons are personal preference. I have Vision gauges in my GTI and they are perfect for what they do, but in the Coupe I prefer the Series 1.
My Pick
Well if you want to monitor the oil,temp and pressure don't forget the Volts. Red/green bands are good. When I get to the oil gauge I'll talk to you about covering the A pillar.
2000 Imola Red M Coupe Dinan suspension, M rotors /Axxis pads Eurosport Cam Kit 1, touch lane change Zaino polish, Beach Sand Garys mirror adapter, S54 Oil Cooler seat tilt coupling nuts, spare tire "life's to short to drink cheap beer"
Andy or Jon:
Do you have a source for getting the gauge faces silk-screened (or hand painted) to match the gray gauge faces of the 01-02 Ms?
I too want to add an oil pressure gauge and voltmeter in place of the clock and ambient temperature gauges, but since I have the gray/black interior, the gray gauges look right. I do not have any trouble reading them in any kind of light, as was mentioned about them when the 01s first came out. Worst case, I could use black gauges like my 99 has. Do you have an oil pressure gauge to match them? I prefer not to use the A-pillar pod... Thanks!
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Voltmeter. Screw adjusting for daylight savings time. Check time on your wristwatch or cell phone.
2001 IR/IR M Coupe |
Re: Andy or Jon:
We can get them silk screened but there would be a very large investment. Jon will be able to better answer what all would be involved. The numbers were insane, something like 50 to 100 gauges.
Re: Re: Andy or Jon:
However, we can get a VDO Series1 or Cockpit gauge made with a custom face that will match M gray. NHS can match the font, everything. They do really, really high quality restoration work on gauges and I am sure they could do this for us. The needle color will match too. I don't know cost. Under $250 apiece. I have been thinking of getting one made for myself to see how it turns out. The only "problem" with a Series1 or a cockpit is they light from the side. Like the Z8 or an old-school Camaro. The light does not come thru the numbers like the rest of the stock gauges in the car. I think this would be OK if you mounted the custom oil pressure gauge on an A-pillar pod, but if you put it in with the rest of the lineup it would not match. Certainly not at night. The needsle are not fiber optic on series1 or cockpits. Only on Visions. So, long story short, the best route is a stock vision gauge, possibly with one of our orange bulb covers for night illumination, and with an M chrome ring. Like what Ron has.
Thanks Guys!
I'll take that all into consideration... Three (3) more questions though. Could I get a Series 1/Cockpit oil temp gauge (gray face) so that those three would match? If I went with black face Vision gauges, do the oil press and voltmeter match the stock 99 (black face) oil temp? And lastly, should I just get three Vision gauges (black face) for oil temp/press & volts to avoid any possibility of mis-match? Not counted as a question (but still requires an answer), do you have all the required sending units (electronic gauges-not mechanical)? Again, my thanks.
Randy,
This is the story. You and I are esentially in the same boat. (1) Senders. No problem. We keep senders for 4- and 6-cylinder BMWs in stock all the time. Boost and EGT and other weird stuff is order-only. (2) Cockpits or Series1. You could feasibly have 3 new gauges made for you custom. Either series. Have all 3 made with red/amber needles and with custom silkscreened faces that match S54 gray. You could have OEM chrome rings crimped on. You cold use amber bulb covers from us. They will all be side-lit, they will match, they will look good at night (see Andy's preference above). You can use all electrical gauges, even though they are older designs. The "problem" is only the price. NHS makes their money on custom stuff. They do great work, but it will not be cheap. You will be permitted to redesign the gauge face any way you want however. ie: delete the VDO insignia, choose the measurement units, etc. We thought (or are still thinking) that maybe Andy's car would get series1 gauges with dakar yellow faces and black lettering and black needles. Still an option. Andy may go that route some time in the future. Who knows what goes thru his head. (3) Visions. To get a perfect match, the best and cheapest way to go is to replace all 3 gauges with visions, from us, with M chrome rings and amber bulb covers. We have had a voltmeter with chrome ring in stock for literally years now, and of course you qualify for employee pricing. If you replace all 3, they match, they will be backlit light the main gauges, the needle color matches during the day, and we can get you a deal since we want to move the stock. The only drawback with this route is they are not gray and the font is slightly different than the main gauges. But since all 3 next to each other match, I think it's OK. If you want to discuss, give me or Andy a call today. I am painting to-be-rusty portions of brake rotors with Eastwood stainless steel high temp paint. It is tedious and I would not mind a distration. 425.377.0162. I like the idea of oil press on the a-pillar with a cockpit gray custom gauge myself. You can get pretty obsessive about gauges if you aren't careful. Andy and I noticed that the volt and oil press gauges in his pics do not match the oil temp gauge (which is a correct series1 gauge). We are taking steps to address this in the spirit of making no compromises.
Kind of related
I got thinking when I read all this gauge and lighting stuff. What would I have to do to change my lighting from the stock red. I have trouble reading the numbers with the red color. I think the passat color scheme for instruments is great. I'd settle for white for all them.
Hey randy isn't it hard to change staions with the radio on the floor?
Keep in mind that the '01 and later M's use a gauge control module.
So if you add another oil temperature gauge you will also need to add another oil temperature sensor along with the oil pressure sensor at the oil filter housing assembly. Since this takes up both holes you lose the idiot light sensor. You can get this back by using the VDO sensor with the idiot light included. I used the BMW black oil temperature, sensor and voltmeter in my '01 m Coupe along with the OBC. I used a vision series oil pressure gauge mounted on the A-pillar. ![]()
Re: Kind of related
Hats off to Ron (yet again) for pointing out the pitfalls and to keep us from making expensive mistakes. It would seem obvious that it's okay to let the gauge control module continue its purpose in life without the factory oil temperature gauge connected to it... ...and to pick up the voltmeter signal from any "Hot in Run & Start" source located nearby (same as what would be used to power the new gauges)? Did you get my E-mail about the SSS?
Re: Re: Kind of related
Re: Re: Re: Kind of related
Working on my photoshop of the insrtument cluster. |
Re: Kind of related
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
