E36 (1991 - 1999)
Old 10-16-2006, 04:57 PM
drverdon drverdon is offline
Mein Auto: 1998 BMW 323iC
Talking OBC Ignition Lockout code forgotten?
I am new here and thought I'd share something I recently learned with all of you.
I had my car parked in a parking lot and decided to set the ignition lockout code on the OBC. I guess I didn't really need to, but it is a toy that I've never had on another car!
Well, I came out to go for lunch and punched in the code, and I either mis-keyed the number when I put it in, or forgot what it was (I thought I knew it, but my memory isn't as good as it used to be), but the OBC wouldn't accept the code. I was stuck and couldn't get the car started.
The only thing I could think was that I'd have to tow the car to the BMW dealer and pay big bucks to have the code reset or something like that. I thought that I'd disconnect the battery and try to clear the code that way.
To make a long story a little less long, what you have to do is to disconnect the battery (I disconnected the negative and then the positive and shorted them together and then reconnected them). Then put the key in the run position and watch the OBC count down for 15 minutes. DO NOT turn the key off during this time, or the counter will restart at 15 minutes again. After the 15 minutes you will be able to start the car.
Anyway, I just thought I'd share this with you, as I'm sure if it happened to me, it could happen to you!
Old 10-17-2006, 05:46 AM
eazy02909 eazy02909 is offline
Mein Auto: 325is
how do i do the ignition lockout 94' 325is
Old 10-17-2006, 06:09 AM
Pirate_copy's Avatar
Pirate_copy Pirate_copy is offline
Still here
Send a message via MSN to Pirate_copy
Mein Auto: M3
lets hope no car theives read these pages hehehe
Good time though....god i wish my OBC did more than tell the time and warn me my engine is gonna explode.....
2001 Mini Cooper R50
Edirty6 for life
Old 10-17-2006, 10:28 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
Don't worry, there is a much faster way to defeat the CODE function.
Old 10-18-2006, 02:37 AM
Still here
Mein Auto: M3
good point John
a friend of mine fitted a high-end model alarm a few weeks ago and challenged his cousin (convicted car thief) to bypass it and drive off....he did it in 86 seconds
gutted!
Edirty6 for life
Old 10-19-2006, 07:39 PM
Well, JohnF, I have no doubt! I'm thinking that the code will help protect against the casual joy rider. Let's face it, if a real pro wants your car, it's his!
Old 10-20-2006, 02:16 AM
Still here
Mein Auto: M3
too true
Edirty6 for life
Old 10-20-2006, 04:01 AM
johnf's Avatar
John Firestone
True enough, but I really wouldn't put too much faith in the CODE function. If you want to protect the car, I would retrofit BMW's EWS-II system (or something comparable) if the car doesn't have that already. Transponder EWS systems have been very effective in Germany and cut the auto theft rate to a quarter of what it was about ten years ago.
Old 01-08-2013, 10:25 PM
msiedliski msiedliski is offline
Mein Auto: BMW 750 LI
Wow, i am going trough this, car in the garage, used the toy CODE hope I can figure it out tomorrow. 3 tries and the car shuts off. I have a 740 iL.....
Old 01-08-2013, 10:34 PM
I had my 740 iL in the garage, before leaving town did the CODE, got back today....tried it and cammot start car. I think I was rushing it, 3 timee locks you out.....should I try the battery thing? Hope tomorrow I will try again, any suggestions? I have 3 tries, maybee I pressed one # wrong out of the 4....... 740 iL, 1998 E38 no navi..just hope it is not mayor and I am not towing the Flagship anywhere....
Old 01-10-2013, 06:47 AM
I don't think disconnecting the battery will do you much good. I don't think it did for me. I think what you have to do is turn the ignition on and let the counter count down. It was a long time ago, and that car is gone now. Got a 2007 e93 now!
Hope this helps!
Old 06-27-2016, 09:49 AM
denis28381 denis28381 is offline
Mein Auto: BMW E39 520i 2003
Thank you very much!!!!!!
You saved my life
It did not accept my code and i thought that i woud have to brute force it
It would've taken so much time
There are about 10 000 possible combinations
Thank you again very much
Old 10-27-2016, 07:00 AM
Mr.Brake Mr.Brake is offline
Mein Auto: E34 540i 95'
Does shorting the positive and negative together just simply mean remove them from the battery terminals and is there a specific amount of time of doing so?
Old 10-27-2016, 07:05 AM
What if the obc doesn't display the 15 minute count down once the car is turned on and the alarm is going off
Similar Threads
The same old code again!!!! kenkorsak E36 (1991 - 1999) 6 01-21-2014 04:58 PM
Lost OBC Code, Hilfe! BItte czellars General BMW Questions 1 04-29-2006 01:04 PM
radio lockout, have code, need seq jusflotnalng E30 (1982 - 1993) 8 03-23-2006 06:46 AM
code 1 on guage cluster danielson E36 (1991 - 1999) 3 03-02-2006 10:39 AM
