E46 (1999 - 2006)
Old 10-18-2006, 04:15 PM
jwhelan jwhelan is offline
Mein Auto: 2001 330 Convertible
Hardtop Installation Kit Instructions
Got the Hardtop, got the hardtop preparation kit, anybody know where I can find the directions for installing the kit? 2001 330i. Thanks, Joe
Old 10-18-2006, 05:00 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I had a little advice and pretty much had to figure it out after that - it is relatively simple. You need to put the top down not quite all the way so the cover is still open (prop it with a stick) slide out the 2 little plastic inserts where the hard top pins go and you will see 2 metal pieces with holes in them about 1.5 inches apart, this is where the mount pieces go. The mount pieces are marked R (drivers side) L passenger side and the wire contacts point up, the mount sits under the holes in the frame and the bolts go through - that is the easy part. The wires connect to a plug that is fairly far up and unreachable from the top compartment. Next you need to remove the back seat - the bottom piece just pops up and comes out, the backs you remove 2 bolts you will reveal after removing the bottom of the seat and the back will come out. Next you need to remove the interior side panels. There are 2 screws under the bottom of the arm rest on each side and then the bottom half of the panel including the arm rest pulls off - the rest are tension fasterners that will pop out. Once that is out, you can push the top piece of the trim panel up a bit and see where the wire plug goes on, there are already 2 plugs on the block and this will be the third one - one on each side. Now just put it all back together!
realoem.com has parts explosions that help if you are looking for the fasteners. Wish I took some pics when I did it!
Rob
Old 12-27-2007, 10:32 AM
damills's Avatar
damills damills is offline
bimmerfest Supporting Member
Mein Auto: 2002 m3 & 2014 650i
Rob
Did you have to buy both the installation kit and the adapter before putting on the hardtop
Old 12-27-2007, 05:01 PM
BMWayne BMWayne is offline
Mein Auto: 2002; titanium 325 Cic
i know nothing about the installation,but give me your input on my hardtop pics + question. i couldnt imagine not having it in the winter months, i love it!
~A
http://www.bimmerfest.com/forums/sho...d.php?t=251028
2002 convertible - 18 inch SSR GT3
Old 12-27-2007, 05:31 PM
damills's Avatar
~A
Not big on the 2-tone, I like the wheels, have you ever thought about replacing the front bumper with a m-tech or zhp bumper, biggest improvement you can make on an E46 besides wheels and interior trim IMHO.
Its your car, do whatever makes you happy with it, nothing else should matter.
Similar Threads
ipod kit installation cost kwilliams E60 / E61 (2004 - 2010) 40 11-24-2006 01:48 PM
Cruise Control Installation Instructions Lance Burt E36 M3 (1995-1999) 0 08-24-2006 05:45 AM
FEELER: OEM Navigation Installation Kit kid007gold Mobile Electronics and Lighting 0 08-03-2006 11:12 PM
Installation instructions for Motorola IHF1000 Bluetooth car-kit mishenka Car Navigation, Audio & Electronics by BAVSOUND 8 12-12-2005 06:14 AM
Suspension Kit for Storing the Hardtop zeke 3 Series & 4 Series 1 05-22-2003 06:02 PM
