Old 01-24-2017, 06:44 AM
V8Mike V8Mike is offline
****erMensch
Mein Auto: 2003 540i6
Zionsville radiator problem
Hi Folks;
I replaced my radiator, thermostat, cooling lines and fan a few months ago. I used the zionsville kit with the 2 speed electric fan.
So far it's worked great, temps are good and it's tight as a drum with no leaks. Only problem is I get a "Check coolant level" warning on every start. I have it filled roughly half way up the expansion tank, and as far as I can tell I thoroughly and properly bled the system of air. I've checked the levels and feel they're safe so I'm not worried about damage but the message is really annoying. I believe I've installed the coolant level sensor properly, and it seems to be connected properly but I really don't know if it's working. It's also hard to know how much coolant to add as there is no floaty level checker thingy.
I contacted zionsville but the customer service has been less than stellar as I can't get anyone to reply to my messages. Any suggestions from anyone who has this system?
________________
2003 540i/6
Bury me in my e39.
Old 01-24-2017, 11:11 AM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: 2000 DINAN 540, 1983 745
Add a little more, mine has to be about 3/4ths full for the check coolant level not to show in the dash.
Sent from the moon
2000 Dinan 540 Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Powerflex polyurethane bushings, Dinan stage 2 engine software, Stage 1 trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, Dinan TB, AFE cai, 18" style 5's, 235/40/18 275/35/18, Ultimate cup holders, rear cup holder delete/coin holder, Hella taillights, clear sides, Depo AE, M5 spoiler
1983 745 turbo, style 138 wheels
Old 01-24-2017, 12:02 PM
****erMensch
I'll give it a try thanks. If it's that simple I'm going to feel really dumb.
________________
2003 540i/6
Bury me in my e39.
Old 01-24-2017, 12:57 PM
540nj 540nj is offline
Mein Auto: 03 540i6
Not sure about the zville set-up, but I've got a check coolant light on for a while. Original sensor from new, 140K miles. Bought a replacement, but haven't gotten around to installing yet.
Coolant level hasn't changed in a year.
Dave
03 540i6
95 993
Old 01-24-2017, 01:04 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Is there a float in the tank?
BTW, these guys are gearheads; they're probably not schooled in the art of customer service.
Old 01-24-2017, 06:03 PM
matt540's Avatar
What happened?
Sent from the moon
Old 01-25-2017, 07:16 AM
****erMensch
There is not a float in the tank. Just a level sensor in the bottom.
As for "what happened" - nothing, it's all good. The kit seems great so far after about 3 months use with the exception of the low coolant warning. I just haven't been able to get a response to any of their customer service emails. Haven't bothered trying to call yet.
________________
2003 540i/6
Bury me in my e39.
Old 01-25-2017, 07:47 AM
matt540's Avatar
Did adding more coolant fix the problem?
Sent from the moon
Old 01-25-2017, 09:14 AM
****erMensch
No unfortunately. I will try just a tad more.
________________
2003 540i/6
Bury me in my e39.
Old 01-25-2017, 09:38 AM
matt540's Avatar
It could be the coolant level sensor
Sent from the moon
Old 01-26-2017, 01:14 PM
waters17 waters17 is offline
Mein Auto: 2003 540i/6
I have the same issue with my zionsville radiator. It randomly started last year, but the message is now on all the time. Coolant level is perfect. I looked into it briefly, and IIRC, the coolant level sensor in the Zionsville is a different BMW part number than the stock level sensor. -not sure though. It also looks like it's a pain to replace since the bracket for the air quality sensor is located directly under the coolant level sensor.
expansion tank, radiator, zionsville
