Old 10-31-2006, 07:51 AM
kaptom540 kaptom540 is offline
Mein Auto: 1998 540 IA
TRANS FAILSAFE Prog Error
Need some help .. The other day .. I was up on a very steep incline road ... I had the AC on and started up the incline ... before I moved forward the car slight rooled backwards .. like a manual car would do on a step incline ... all of sudden ... my dash indicated Trans Failsafe Prog .. Car had a hard time moving ... I pulled over and shut her down ... then restarted the vehicle ... Trans Failsafe Prog came on quickly and disappeared ... I was able to move normally and drive her home without any problems or any message popping up .. Started the car today .. and no message ... I will go home tonight and take her for a spin to see if I get the message again ... Would rolling backwards would create this message ?
I had reviewed the search ... I will have codes read to determine the exact cause of this message. In addition, i was wondering what are some of the results with others who had this issue. Did you have to rebuild your Tranny or was it just connectors, or cables ... or something really minor ? Please share your outcome. Thanks!
1998 Arctic Silver, OEM M-Tech Bumpers, Koni FSD/Eibach Pro Kit, MKII Motorsport 18x8.5 and 18x10, M5 Style Mirrors, ACS Style Trunk and Roof Spoiler, OEM Hella 4300k Headlights, Slim HID 3K Fogs, Euro Hella Celis Taillights, OEM M5 Kidney Grill, 35% tint, Magnaflow 14815
Old 10-31-2006, 08:05 AM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
Happened recently to me...alternator failed. Have your electrical system checked, and a load test performed on your battery. Many auto parts stores will do this for free. Please report back your findings.
Old 10-31-2006, 08:15 AM
battery is only 2 years old .. Not sure about the alternator .. Do you know if I got the computer read ... it will let me know the exact problem .. would hate to rebuild a tranny ... Only have 80K ... Also, wondering if rolling backwards on a steep incline in an automatic car would create this message or maybe the fluids were out of stuck in one sectoin of the tranny ? Does that make sense?
Old 10-31-2006, 08:17 AM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
unlock your OBC and see what the voltage is reading. i can help you do this... or did i show this to you way back before? you know how right? add up the vin, input it and select i think test #7 and you get volt readings.
PS: i was on the can when you called.
americandan.com
It takes a lot of work to be lazy.
Old 10-31-2006, 09:01 AM
More information than I needed to know about your bodily function ...
you should me but .. you went really fast through the process ... Contacted Bill and he indicated that I need to connect the readings from the Tranny to get the code ... going for a drive 2 night ... hopefully will be okay ...
Old 11-01-2006, 09:09 AM
Took the car for a drive last night ... No error message came on ... What I did notice was a slight increase is rpm when shifting from 2 to 3 but only when the car was in sport mode. Maybe a slight slipage ...
I have 80K miles .. Should I change the tranny fluid? I know there are pros and cons!
Old 11-01-2006, 06:15 PM
chivas's Avatar
i'm getting the harness to run carsoft..
americandan.com
Old 11-01-2006, 07:12 PM
jpettit's Avatar
jpettit jpettit is offline
keep those wagons rolling
Mein Auto: 1999 BMW 540i Touring
i had the Trans Failsafe Prog error message a few weeks ago...had to replace the alternator.
Old 11-01-2006, 08:03 PM
chivas's Avatar
well... i see what i'm going to be doing soon...
americandan.com
Old 11-01-2006, 08:35 PM
cool .. Can I be first in line ..?
Old 01-28-2007, 12:12 PM
flyboyy's Avatar
flyboyy flyboyy is offline
I glow in the dark
Mein Auto: 2003 BMW 530i
was it constant with the failsafe prog error ? does the error code happen everytime you start up the car ? and also was your car in like 3 or 4 gear and it picked up very slowly ?
did you also have a check service engine light on ?
how much did it cost you to change the alternator and where did you do it ?
Old 01-28-2007, 12:23 PM
jpettit's Avatar
the light was on constantly, and happened everytime. i didn't have any gear issues, but after about 3 starts my car wouldn't even start.
i don't remember, but i don't think so.
i had it done at a local independent shop. the battery was covered under warranty, and i had some other work done at the same time, but i think around $400 CND.
Old 01-30-2007, 06:53 PM
trulynutso trulynutso is offline
Mein Auto: cars
If you have the life time bmw trans fluid, I would not recommend changing the fluid. From my experience, the new fluid has some chemical in it that helps break in the new clutches of a trans. When you add this to the used clutches, it may cause the transmission to slip when it was fine before. This is just my experience from it. I'm not sure if this applies to the 5 series, but the 7 series have a problem with the transmission harness. The harness develop high resistance and cause shifting problems. Good luck.
Old 05-26-2007, 12:27 PM
fkhatib fkhatib is offline
Mein Auto: BMW 530 2003
OBC unlock for 530 2003
Hi chivas,
My car is BMW 530 / 2003 the old shape, would you please tell how to unlock the OBC
Old 11-03-2007, 10:40 AM
Hey kaptom,
I have the same problem,
Have you been able to fix the problem with the (Trans Failsafe Prog) msg, did you have to replace the tranny ?
Regards
Old 02-09-2008, 07:05 AM
manthny18 manthny18 is offline
Mein Auto: 2003 Bmw X5 4.6is
I Jusy Recently Also Got That Message When I Was On The Thruway My Car Just Turned Off And Wouldent Start It Said Trans.failsafe Prog I Drive A 2003 Bmw X5 4.6is With Only 37k I Dont Understand What This Means But Im Taking My Sav To The Dealer Today But A Little Later. Can Anyone Tell Me What This Means I Will B Very Thankful.......thanks....
Old 02-09-2008, 07:08 AM
Hey Kaptom Did U Fix It If U Did What Was The Issue And How Much Did It Cost...thanks....
Old 09-02-2008, 02:50 PM
ilian007 ilian007 is offline
Mein Auto: BMW 530i 2002
I have same problem as Kapton somebody found the problem yet????
Old 09-02-2008, 06:44 PM
Fudman's Avatar
Fudman Fudman is offline
BEWARE, the Trans Failsafe Prog may or may not be a real problem. This mode limits you to third gear to allow you to limp to a dealer. I got it two years ago on a rainy winter day when I had 50K on the clock. I took it to the dealer who spent two days troubleshooting it. They even called BMWNA. They finally said I need a new tranny. I said No F'in Way! I asked them to reset the OBC and the tranny has been fine since (now 69K). I have never returned to that stealer.
There have been many posts regarding possible causes. Some are related to alternator, some battery, some a sensor. Very rarely has it been a true tranny problem. I believe mine was sensor related. Not sure a Peake can reset the OBC. If not, take it to a dealer or indy. It'll cost you 1 hrs labor but it is cheaper than a new tranny.
Old 09-02-2008, 07:07 PM
dannyc9997's Avatar
dannyc9997 dannyc9997 is offline
Send a message via AIM to dannyc9997
Mein Auto: 540i
Atf could be a little low too
never had any issues since that day .. never got it checked out .. my guess .. i was on a steep incline hill and maybe the fluids shifted causing the trans failsafe .. check out roadfly.org and do a search on that board ..
Old 09-25-2008, 07:28 PM
Renegade_530 Renegade_530 is offline
Mein Auto: BMW 530
Hi all. Kaptom, I dont believe its got anything to do with the incline or the fact that your car rolled backwards, since i have the same issue. I drive a 530 2003 btw, this happens to me rarely if i step on the gas after a complete stop and the RPM goes beyond 5 or 6. Also seeking help if someone had this issue before and got it resolved.
Old 11-25-2008, 07:40 AM
Rick3010 Rick3010 is offline
Mein Auto: BMW 530d
Trans failsafe prog
Yep, I had the same thing. I drive a 530 diesel (2002) and had the same warning a couple of times after driving "sporty" so to say. My wife never had this problem since she drives it slow and gentle. It has definitely something to do with the torque and/or slip. I assume the tranny is protected for uncontrolled slip or something. Mine has 390 000 km on it BTW...
Still going.
Old 11-25-2008, 01:52 PM
Fudman's Avatar
Damn! 390,000 KM? That is a lot of driving in 6 years! Way to go!
Old 11-25-2008, 06:32 PM
well .. this thread came back to life .. might as well give you an update .. no issues ..
Similar Threads
trans failsafe prog. flyboyy E39 (1997 - 2003) 53 11-29-2014 04:30 PM
trans failsafe mode in cold weather dcampbell E39 (1997 - 2003) 2 11-25-2005 02:08 PM
2000 540 engine failsafe Prog dagoo98 E39 (1997 - 2003) 12 11-10-2005 08:35 AM
Trans. failsafe CFMBENSON E39 (1997 - 2003) 3 05-06-2005 09:24 AM
