Old 11-07-2006, 07:53 AM
chavelock chavelock is offline
Mein Auto: 98 520i se
aux fan and fuse e39
Hi guys I need help please
a/c aux fan packed up just brought a new one but its not working.
I've checked the fuses under the dashboard 40 amp and 50 amp fuse and they are fine. the new fan has three wires red, black and green.
please any ideas im pulling my hair out.
520i SE 1998
Old 11-07-2006, 09:07 AM
IanBMW IanBMW is offline
The Guru
Send a message via AIM to IanBMW
Mein Auto: 1998 528i, 1988 327i
Use a test light and make sure your getting power to the Fan. If so track back and see if there is a relay somewhere that could have gone bad.
Old 07-27-2011, 08:44 PM
stanley1x stanley1x is offline
Mein Auto: 528
Same problem. I just replaced the aux fan, the temp sensor and the AC final stage unit but the aux fan still does not go on. No cold air. Haven't checked freon level or compressor. If freon is low will compressor and or aux fan NOT engage? Also, you mentioned a relay to power to the fan? Where does one check for this relay?
Any help much appreciated!!
Old 07-28-2011, 07:40 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Need to know what year, and possibly the last 7 of your VIN.
There are 2 different fans, one that uses relays (in DME box) and resistors (on fan frame) for the different speeds with a temp switch in the side of the radiator.
The other is a PWM fan, no relays, resistors, or side temp switch.
Old 07-28-2011, 09:36 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Dunno if this helps the OP or not ... but this is what a quick 'aux fan' in the bestlinks nets me ...
- How to test the cooling system auxiliary electrical fan (1) (2) & the infamous fuse 75 (1) & the aux fan relay (1) and a good auxiliary fan DIY (1) (2)
Similar Threads
Clutch Fan Delete Z-Thrizzle E36/7 Z3 (1996-2002) 2 07-03-2006 11:26 PM
aux fan relay ??? gotaZ3 E36/7 Z3 (1996-2002) 1 06-19-2005 09:25 PM
Aux Radiator Fan on 96 318i sdreyer E36 (1991 - 1999) 1 06-19-2005 02:33 PM
Help! Aux Fan problem; no fuse #40? Nivola E36/7 Z3 (1996-2002) 2 05-26-2005 03:25 PM
97 528i A/C-aux fan not working Please Help 528iguy 5 Series 3 04-10-2004 06:03 AM
