Old 11-08-2006, 09:59 AM
Jean-Louis Jean-Louis is offline
Mein Auto: E65
NAVI 02 problems
Hello,
I had a Navi 1 (CD) on my E65 (2003). I upgraded with a second hand NAVi 02 (DVD) but this one is not functionning properly. Everything is fine except erratic position errors (+/50 meters behind the car) and eratic accelerometers / gyroscopic behaviour . One trip fine, next one crazy.
Recoding of NAVI 2 and car at BMW dealer was unsuccesfull. The problem is coming from the NAVI module as everything was perfect with my initial Navi 1 and during a test with the last Navi 03.
Here are my questions:
1) any suggestion or solution on the subject ?
2) Could it be possible to replace the cd reader module inside of the Navi 1 with the DVD reader module of the navi 2 ?
Old 11-09-2006, 01:28 PM
Mein Auto: E65
autoreply to question 2)
Just opened both NAVI 1 and NAVI 2 to check the compatibility.
Basically, the connections of the CD module and the DVD module are not the same although fixations are identical (4 screws)
I checked all connections of the NAVI 02 and hoped that it could be a bad contact somewhere.
Unfortunately, no improvement on the dead recognition operation and still position error
Just like if the car speed was not correct
Can someone confirm if the car speed info is measured by the navi or does the Navi take the info from the car?
Old 11-09-2006, 02:05 PM
JA 7's Avatar
JA 7 JA 7 is offline
Master of the Universe
Mein Auto: 2004 745Li
How helpful it would be if you had another Nav DVD unit to swap it out with to determine if the problem was wiring or the actual unit itself.
When called an idiot sometimes it is better to be quiet, than open mouth and remove all doubt.
Old 11-10-2006, 12:47 AM
DanT DanT is offline
Cars Suck
Mein Auto: I drive your cars
When you are in the Navi screen on the Central display can you see dots in the upper right corner of the screen (with the globe) confirming that it is seeing satellites?
Old 11-10-2006, 08:12 AM
Mein Auto: E65
Yes, GPS reception seems quite good.
I have a green GPS indication on the right uper corner when GPS is available.
Looks like the GPS actually correct the delay of the position of the car.
Looks like the GPS car position move foreward faster every 10 second or so to recover the delay compared to real position. The faster you ride, the bigger is the error (100 M on highway at 120 KM/H). When driving slowly, the error reduces (50 M or less).
Also, note that the car orientation changes when parked for a long period from time to time. For exemple, you enter the garage with a perfect position and heading. The next day when you take the car back, the position is still good but the heading has changed by 90 or so?? -> the GPS is screwed up for the first 3 min until it gets a new valid signal as dead recognition is using that last wrong heading!
Something to do with power supply to GPS interupted or GPS Heading memory lost ?
Similar Threads
Wall Street Journal reports reliability problems Robert A 5 Series 10 11-18-2004 12:40 AM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
01 v. 02 325xi bfriedman 3 Series & 4 Series 14 04-17-2002 05:23 PM
Problems with new 7-series SchwartzBlack General BMW Questions 3 01-14-2002 07:13 PM
Some '02 330i impressions...(long!) Eric Giles General BMW Questions 14 01-10-2002 12:27 AM
