E46 (1999 - 2006)
Old 11-12-2006, 07:52 AM
Fifty_Cent's Avatar
Fifty_Cent Fifty_Cent is offline
Pure Natural BMW Muscle!
Mein Auto: 320CiC
How much oil does the 3 series take?
My BMw specialist says 7liters. BMW states 7.5 liters?Which is the correct one?
Old 11-12-2006, 08:04 AM
brabus brabus is offline
Mein Auto: 2001 BMW 330ci
Whoa...I put 7 quarts (about 6.6 liters) in my 01 330 and it's full to the brim according to the dipstick. It lasts all the way between oil changes also (about every 5000mi). Don't know why you're hearing 7-7.5 liters. Anyone know?
Old 11-12-2006, 08:10 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
change of filter maybe? Oil filter take up some oil, mayb 0.5 l
Old 11-12-2006, 08:15 AM
Whammy Whammy is offline
Mein Auto: ...
7 quarts??? My '00 Wrangler 4.0L only took 5 quarts. Does the E46 have a huge oil pan?
Old 11-12-2006, 08:25 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Yes.... BMWs have always had a somewhat larger than "normal" oil supply....
Regards,
Bob
Old 11-12-2006, 08:31 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Regards,
Bob
MIne is a 320Cic and still uses 7 liters of oil.
Old 11-12-2006, 08:52 AM
Hmm, well maybe I'm only filling it to 80-90% capacity and you're filling it to the brim. Weird. Either way though, my dipstick says full, the oil light doesn't come on, and my car runs great (especially since I just replaced the bad camshaft position sensor...man what a difference!). Don't know.
Old 11-12-2006, 09:08 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Regards,
Bob
Old 11-12-2006, 09:19 AM
Fast Bob's Avatar
Keeping it surreal
And your point is ????....
Old 11-12-2006, 09:21 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
I was referring to this post-stating that a 4.0l car uses 5 quarts.
Mine is a 2.2l and uses more oil than that.
Old 11-29-2006, 08:16 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Well, I know. Its because I OVERFILLED!
7 liters and the dipstick says it is one milimeter above the top line!!
How do I remove that now?
Old 11-29-2006, 09:16 AM
iskoos's Avatar
iskoos iskoos is offline
Coupe OR Never
Mein Auto: '02 - 325ci
Remove the dipstick dip a hose all the way in and suck it just like it is a milkshake
There are two ways, you either get under the car and loosen the drain plug and let some oil out.
Or use an extractor. Check the link.
http://www.bmw325i.net/maint_oil_extractor.shtml
I know it is not good to overfill I just don't know if you should take an action. See what others say.
Old 11-29-2006, 09:20 AM
Plaz's Avatar
Plaz Plaz is offline
Mein Auto: '11 1M;'08 MCS;'02 325iT
I think 1mm over the top "line" (assuming this is referring to the top of the two cutouts) is really not a big deal. I highly doubt that's going to cause any damage.
2011 1M
2008 MCS
2002 325iT
Old 11-29-2006, 09:22 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Well, definitely I wont go under the car, I dont fit under there.(or if I eventually fit, I will be stuck imagine the neighbours face when I call for help )
My mechanic is just down the road, and he has an extractor. Most gas stations ave as well.
Problem is, I am sure I put 7 liters in there(with the filter oil as well)
People say it is 6.6 liters max.
So I put @ 0.5 liter more.
So when the car is hot, the dipstick is at max.
When it cools down, it goes abit over the max.
Old 11-29-2006, 02:33 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
The oil should be checked 5 minutes after shutting off the engine (assuming it is up to operating temperature), according to my E46 owner's manual. You will probably find it is about right.
Old 11-30-2006, 04:41 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Anyways, I am switching to MOBIL 1 0W40 after only 300km with the Castrol SLX 0W30.
Any opinions on this?
http://www.bimmerfest.com/forums/sho...d.php?t=177526
Old 11-30-2006, 10:28 AM
Fifty_Cent's Avatar
Mein Auto: 320CiC
Guys, have a look at my thread regarding oil here http://www.bimmerfest.com/forums/sho...d.php?t=177704 and let me know of what you think.
I am very angry at the moment.
Similar Threads
DIY - 528i OIL Change (E39) 6 cyl GOKOOLJAPAN 5 Series DIY 56 12-18-2009 11:08 AM
oil change, 325 rikdee E90/E91/E92/E93 (2006 - 2013) 6 11-09-2005 10:19 PM
Lift your car? luciano136 E36/7 Z3 (1996-2002) 37 10-04-2005 09:24 AM
WSJ article on new 3 series jben E90/E91/E92/E93 (2006 - 2013) 31 01-22-2005 07:13 AM
