Old 11-14-2006, 10:43 PM
infernoM3 infernoM3 is offline
Mein Auto: 535
battery light and no steering???
hey guys. WAs about to head to work this morning when I started my car e39 2000 540i6 I noticed the battery light stayed on and then was unable to turn my steering wheel easily. Like I lost power steering? There doesn't seem to be any leaks. I read my user manual and it mentioned somehting about drive belts? Anyone know what my problem is and solution? Hope this isn't a big ticket item? Man this car is drving me crazy only driven it 1000 miles and i've already had clutch replaced and this just came off cpo???
Old 11-14-2006, 11:41 PM
BMWtech75 BMWtech75 is offline
Mein Auto: IS300
Sounds like your alternator belt broke. This same belt runs the power steering pump.
Old 11-15-2006, 06:18 AM
macfelon macfelon is offline
Mein Auto: 2000 528it and 2002 540i
Also runs your water pump, don't drive car until you get it replaced.
Old 11-15-2006, 10:01 AM
Mein Auto: 535
how much?
Whats the cost and time to repair this? how much is belt and install.
i'm gonna take it to the indy.
Is it part#1 in the picture. they call it ribbed v-belt
http://www.realoem.com/bmw/showparts...=11&fg=18&hl=5
I checked bMA and the part i found is called serpentine? Only $22 is this the part?
CONTINENTAL Serpentine Belt
Water Pump/Alternator7PK163599-
BELT-MULTI RIB
http://catimages2.sophio.com/webapp/...1281432724.jpg
http://www.bmaparts.com/epcvsoapimc....entid=bmaparts
Old 11-15-2006, 07:30 PM
14mpg 14mpg is offline
Mein Auto: '98 540
serpentine belt is correct, check your belt tensioner before you put the belt on and make sure its not loose. also make sure belt pieces are not stuck behind any of the other pulleys and inspect your pulleys to make sure they weren't the cause of the belt flying off. have honestly never changed mine but 99% of serp belts are not very hard to do on any post '95 car.
Old 11-15-2006, 11:13 PM
m5james's Avatar
m5james m5james is offline
Send a message via AIM to m5james Send a message via MSN to m5james Send a message via Yahoo to m5james
Mein Auto: 98 740iL - Tweaked a bit
Takes 10 minutes to install, goto www.e38.org and do it yourself, seriously.
640hp 10 X5///M, Alpine White/Sakhir Orange - Gutted cats, muffler delete, Eurocharged tune
325hp 98 740iL, black/black - Eatin 540's & $hittin 318's
PERFORMANCE:///M5 6spd swap, Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd
INTERIOR:
Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint
EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads
Old 11-19-2006, 03:03 AM
Mein Auto: 535
Darn! Ended up costing me $550. The power steering pump supports cracked off causing the belt to rip off. It looks like there was just to much pressure and cracked the water pump where it mounts. had to get new pump, belt+labor.
Old 11-20-2006, 08:57 AM
m5james's Avatar
I kept breaking serpetine belts myself, did like 3 times driving down the road....thanksfully I keep socket set in the trunk. Of the 3 bolts total holding on the power steering pump, 1 was there tight, 1 was sheared, and he back on was completely missing! Don't ask me how I didnt notice the first time when I was in there that the pulley was tipped up instead of being flush with the rest, but after some new bolts all was good.
So you broke the power steeing pump AND the waterpump?
INTERIOR:
Old 12-16-2006, 12:48 AM
marvel marvel is offline
$550?? dude, a pump goes for around 60 bucks and a belt around 30 at most. seems like you got overcharged.. job not take more than 45 min. find another guy
Old 12-16-2006, 12:54 AM
AusBmw's Avatar
AusBmw AusBmw is offline
E Nomine.....Das Omen!
Mein Auto: Oxford Green BMW E39 523i
I had my belts done just after i got my car,it was 45 for one 30 for the other.
Old 12-16-2006, 10:23 AM
Mein Auto: 535
Naw it was the PS pump i mean. These run $350.
