E46 (1999 - 2006)
Old 11-15-2006, 02:34 PM
Bill325Ci's Avatar
Bill325Ci Bill325Ci is offline
TXSunDvl
Mein Auto: '01 325Ci, ZSP, '08 CR-V
Power steering pump problems
Well, on Friday I will be getting my power steering pump replaced for the fourth time in 5-1/2 years. Fortunately, it's all been under warranty or has been warrantied by BMWUSA. Anyone else have this much problem with theirs?
The failure of Government Interference is always blamed on the astounding conclusion that Government didn't interfere enough - Hayek.
Old 11-16-2006, 05:47 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '17 340iGT
Have 3 BMWs, never a PS pump problem
Have 3 BMWs, never a PS pump problem. Sounds kinda wierd. I do replace the PS fluid on every oil change as preventitive, but still, you should not have had any failures.
Old 11-16-2006, 06:15 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Wow - replacing your PS fluid every oil change - that sounds a little extreme - How often do you change your oil? I certainly would not be changing my ps fluid every 7500 miles, and if your waiting for the BMW oil change interval, you'd be better off changing your engine oil more and PS fluid less. I would recommend doing it occassionally however - every 50000 miles or so or 3 or 4 years - it doesn't really break down like engine oil, more like brake fluid, gets contaminated and should be changed more like brake fluid or tranny fluid etc.
Old 11-16-2006, 06:29 AM
A little clarification
A little clarification. I change the engine oil every 7500 miles. When I said I changed the PS fluid, it's sort of. I simply suck out what I can from the resavoire with a turkey baster and refill it. So I'm changing about 1/3 the fluid each time. Only takes a minute and I dump the PS fluid into the oil container for recycling. A $5 gallon of dextron lasts for years. After a few years the PS fluid looked so nasty I figured it couldn't be good.
Did not feel like disconnecting PS hoses to do an true full flush every few years and just decided this was sooo much easier, and like I said, takes only a minute. Also felt it was just easier and less complicated to do it each oil change rather than to keep track of when it was done last.
Old 07-04-2009, 09:39 AM
alexusdiamond alexusdiamond is offline
Mein Auto: 325i
Bill, I have the same problem. My pump just went out for the third time in 3.5 years which is why I am on this blog. It seems extreme to me. I recall the first time it went out I called BMW USA and they told me the original pump may have been faulty. They told me their was a known issue that was fixed. Now I am on the third one my mechanic uses new parts (so he says) now it needs the lines fixed as well. Every time it goes out something else related needs fixing too. They are quoting me $1300
Old 07-04-2009, 10:15 AM
kc1976 kc1976 is offline
Mein Auto: 325ci
I got the same problem
I got a 05 325ci. I have the power steering pump problem on my way from Dallas to Austin. I parked my car on the roadside for about an hour and when I start my car again, there was noises as I steered my wheel. I got to BMW Austin before they closed door. They said it was power steering problem, but it's safe for me to drive back to Dallas. So I have to cancel my trip and headed back to Dallas.
Very frustrated. I just took my car to a dealer before my trip. Luckily, there are still two days before my original warranty expires. I am going to take my car to the dealership on Monday to verify and fix the problem.
One thing I like to add is the BMW roadside assistance does not live up to the BMW brand. When I called they cannot offer any technical advises nor can they offer me any reasonable solution. They said the only option is have my car towed and left in the nearby dealership which is in Austin. And the dealership closed 2 days for the July 4th. That means I have to leave my car in Austin for 3 nights. And they did not offer my anything like alternative transportation or trip interruption benefit as they claimed in their promotion materials.
Old 07-04-2009, 10:18 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
I've never seen any of that claimed in promotion materials. Roadside assistance is the same as AAA - both contracted out to local tow companies. That's all.
Old 07-04-2009, 11:59 AM
Mein Auto: 325ci
check this out
http://www.bmwusa.com/Standard/Conte...ssistance.aspx
Old 07-04-2009, 12:03 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Interesting. So it sounds like you can be reimbursed (they don't cover you up front, the brochure says you can be reimbursed). Have you submitted receipts for reimbursement?
Old 07-04-2009, 02:03 PM
kunal_D's Avatar
kunal_D kunal_D is offline
Mein Auto: 2008 335i Sport 6MT
Going on 8 yrs on the original pump, something else has to be wrong.
08' E90 335i, Sport, Premium, Logic 7, 6-spd
01' 330i TiAG, ZSP, ZPP, ZCW, 5spd - R.I.P 04/12- gone but not forgotten.
Old 07-04-2009, 02:07 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Originally Posted by kunal_d View Post
going on 8 yrs on the original pump, something else has to be wrong.
+1
Old 12-07-2009, 01:14 PM
enamoured enamoured is offline
Mein Auto: 2005 BMW X3 3.0i
Bumping this thread up to see if anyone has a solution for this issue. my brother-in-law's 2003 325i had it's second PSP failure in 6 months that it has been with him. Here is a little history:
1. PSP dies, we replaced it ourselves with a used PSP.
2. Noise from steering after a couple of months, PS fluid low, topped it up all is well.
3. PSP dies again after another couple of months.
We showed it to a local indy that specializes in BMWs and they told us that the circled rubber part in attached picture is sucked in, so the whole steering gear needs to be replaced. This is more than a thousand dollar part and about 350 in labor. Any ideas guys.
Name:	steering problem.jpg
(OO \ (|||) (|||) / OO)
Old 08-19-2015, 05:19 AM
ejrobert ejrobert is offline
2014 F10 535d
Mein Auto: 2014 535d MSport
M6 Power Steering
My 2008 M6 power steering pump just went out, and boy did it go. Catastrophic failure. I've seen many of the comments, but wondered if there is more info on this "known issue" from BMW? Who actually manufactures BMW's OEM pumps?
Old 08-19-2015, 05:21 AM
2014 F10 535d
That is an outstanding idea about using the turkey baster for a partial change. I think I will adopt this!
Old 08-19-2015, 06:43 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Known issue?
This is a six year old thread for a totally different car from yours. I have an E63 and can't recall PS pump failure on E63/4 forum. Not saying it can't or hasn't happened, but it's not something that pops up on the list of prevalent areas where BMW dropped the ball, and there are several...
Note that your M6 requires different fluid than an E46 and it should be changed periodically, every 30 to 50k miles would do. The biggest issue I've read of related to PS system is dynamic drive module failure theorized to be due to old fluid, or using incorrect fluid. The fluid for the E63/4 is Pentosin CHF 11S.
I suggest a new thread on E63/4 forum. Maybe it's more prevalent than I recall. First questions are going to be about history of fluid changes and fluid type. Whoever is changing your pump, make sure they fill it with Pentosin.
Old 08-19-2015, 07:00 AM
2014 F10 535d
Good Info
Thanks, all good info. I'm having it done at the dealership in this case. More expensive, I know, but I don't want any questions or issues later. As to history, all required services have been done at the dealer, and the car just passed 63K miles. Not sure why the failure, but a google search took me to this thread, which is why I posted here. Was hoping to get someone with a bit more expertise to comment, and look, it worked
Old 08-19-2015, 10:25 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
I do the same thing. Keeps the fluid looking new cherry clear for eleven years and counting; New fluid keeps the hose preservative fresh to they don't leak as quickly.
Similar Threads
DIY for power steering pump? mikey36m3 E36 (1991 - 1999) 9 03-26-2010 10:43 AM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 04:52 PM
More on the N54 engine/ new transmission mapezzul E90/E91/E92/E93 (2006 - 2013) 5 07-18-2006 08:30 PM
Power Steering Pump glaws 1M & M2 7 10-01-2003 06:31 AM
Power steering pump bracket failure... Randy Forbes E36/7 Z3 (1996-2002) 10 05-10-2003 06:20 AM
