Old 11-20-2006, 10:34 AM
bokonnon bokonnon is offline
Mein Auto: 2001 E39 540iT
Question Transmission Failsafe Mode w/ Transmission Code 15
I recently had my mechanic replace the transmission in my 2001 540iT Sport Wagon based on the diagnosis from Concord BMW. When it was installed, the car dropped into the Transmission Failsafe Program mode and displayed transmission code 15: Pressure actuator failure. This is also generic OBD II code 1748: Manufacturer Transmission Control Unit Malfunction and/or Transmission Control Unit Self Test Failure.
Has anyone experienced this problem? If so, what was the diagnosis?
My mechanic doesn't have the big BMW test set to fully diagnose this issue so I've made an appointment to take the car to Concord BMW for diagnosis.
I also had the transmission control module replaced and reprogrammed. Does anyone know if the transmission failsafe program cuts out a lot of the transmission control module functions?
First off, the shift selector indicator on the dashboard is disabled. According to the service manual, the LEDs are enabled through the TCM. Also, the shift lock solenoid is not operating. I can put the car in any gear without having to depress the brake. The pathway for this circuit also travels through the TCM. Unfortunately I do not remember if those two items worked before I had the transmission replaced.
The sport mode is unavailable and no indicator lights change when I tap the shifter to the left.
Additionally, the parking control assist does not activate when the vehicle is placed in R (possibly indicating an electrical problem vice a hydraulic/mechanical problem with the transmission).
I am trying to avoid another R/R of the transmission and was wondering if it could be the computer interface inside the transmission? If so, can that be replaced? I have verified continuity between the TCM and transmission connector and a visual inspection of the connector pins does not indicate any damage/missing pins.
Even though the car is sluggish from the start (because it is stuck in 4th gear), it drives great.
The last time I had the transmission diagnosed by the dealership, 20 minutes later they said, "We couldn't see anything wrong specifically, BUT you need to replace the transmission." $6000.00 later, I now have a working transmission but I am still having issues. Any input to help isolate the issue BEFORE I take it back to the dealership for their input would be greatly appreciated.
2001 BMW 540iT Sprot Wagon w/ Steptronic 5 speed
ZF transmission part# 5HP24A
Old 11-28-2006, 12:51 PM
SliverBullet5 SliverBullet5 is offline
Send a message via AIM to SliverBullet5
Mein Auto: 00' 540ia
Check your batterymy dad had the same problem and it was the battery
Old 11-28-2006, 07:21 PM
GJR's Avatar
GJR GJR is offline
Mein Auto: 2003 530i
Wow- sorry to hear. How many miles do you have on the original tranny?
Old 11-30-2006, 01:00 PM
soutsos soutsos is offline
Mein Auto: 2001 540
Post Transmission issues
My 2001 540 4-dr. sedan just had the 'failsafe transmission prog' come up on my dash. I took it in and it was diagnosed with a burnt transmission. The oil had been burnt completely.
They said I need a new transmission at a cost of $7,500.
This is absurd for a car that has been maintained exclusively by the dealer since I purchased it brand new. It has 180,000 km on it which is not excessive for an engine of this nature. I'm an executive and drive the car around a big city in normal traffic conditions.
This should never have occured. They are now scrambling to reach a compromise solution.
Old 01-10-2007, 04:43 PM
Update on the transmission issue, it turned out the "new" transmission was the wrong part. It was the correct ZF part number (5HP24), but it was the wrong BMW part number (orgionally out of a 1998, I have a 2001). The problems were because the transmission control module couldn't talk to the new transmission. It took 8 weeks and two trips to the dealership to figure this out. The money was bad enough but not having the car for a couple of months was really frustrating.
But, with the correct part number the car runs great. Taking her down to San Diego this weekend
Old 01-11-2007, 10:23 AM
matteni matteni is offline
Mein Auto: 540iA Sport
How do you read the transmission error codes? I have the Pieke tool and I was testing my transmission shifts and it went into failsafe but I couldn't get any codes out of the Pieke (just got the "---")
Old 01-11-2007, 10:54 AM
kaptom540 kaptom540 is offline
Mein Auto: 1998 540 IA
I had the same issue came on twice within minutes of each other and then nothing ... car now drives fine .. I was on a very steep incline hill when the trans failsafe came on. Just weird?
btw, didn't you just complete a tranny fluid change? Is the car running and did the light come on again?
what i have read .. it can be the battery ... or altnerator ..
1998 Arctic Silver, OEM M-Tech Bumpers, Koni FSD/Eibach Pro Kit, MKII Motorsport 18x8.5 and 18x10, M5 Style Mirrors, ACS Style Trunk and Roof Spoiler, OEM Hella 4300k Headlights, Slim HID 3K Fogs, Euro Hella Celis Taillights, OEM M5 Kidney Grill, 35% tint, Magnaflow 14815
Old 01-11-2007, 12:08 PM
In the morning and when the car is really cold it shifts crappy. It either bangs into gear, looses power while turning and accelerating. When I shift manually it seems to act a lot better. When the car is warmed up it seems to act a lot better.
When I took it out at lunch (cold) I was doing some testing. I turned off the DSC and did a hard launch in automatic - sport mode. It felt like a slipping clutch going into gears and then going into 4th the Transmission Failsafe light came on. I was kind or relieved to at least know I wasn't crazy and would have some codes to work with.
I got home. Turned the engine off. Inserted the Pieke tool. Then turned the key on. Then pressed Go. No codes "--". Nothing.
Turned the car on. No Transmission Failsafe. Drove around. Car drove perfectly fine. Tried to repeat the transmission failsafe and couldn't do it. Very frustrating!
Now I have been getting some weird electrical things lately. I had 3 of my 4 new Angel Eye rings light up and the 4th would come on later. Re wired the whole thing and didn't help. Bumped up the fuse and that helped 100%.
Then the brand new battery dies on me 2 days ago. Ordered the FSU for replacement and charged it over night but no problems.
Then I started the car after work yesterday and the flashers and the dome light came on - on their own.
So it could be alternator, new battery is bad, VW MAF unit doesn't work I just put in, did something wrong when doing the tranny fluid, etc etc etc.
Guess I will have to watch, wait, and see.
Old 01-11-2007, 01:28 PM
here is couple of links about trans failsafe .. i am not sure if you have already read through these threads .. let us know what happens.
http://www.bimmerfest.com/forums/sho...Trans+failsafe
Old 01-11-2007, 01:53 PM
I had not seen that 3rd one - thank you!
Old 01-12-2007, 07:11 AM
OK - here is an update on my condition. Took my car to AutoZone to have the new battery checked and the alternator checked. Still planning on re-checking the tranny fluid level too but this was an easy place to start.
First the battery. It was very low despite being charged all night. It read "charge and retest". It did fine under load.
Then the alternator. Got in and held 2000 RPMs. I was 100% prepared for it to be bad. Guess what - it tested OK. I don't know how long this thing will last but that was some good news. During the test the tech noticed as the revs fell to idle the voltage dropped too. He then suspected the battery was bad. We grabbed a new one and then retested and sure enough the voltage remained constant and didn't drop off with load. Kept the new battery and drove around. Didn't seem to be any problems with shifting. No mystery lights coming on.
Next day - fire up the car and drive off. It is wet from rain and a LOT warmer then usual but the car behaved 100% better. The car always seems to be perfect in manual shifting mode - it is just when in normal driving mode when I head out in the morning that it seems to loose power upshifting, hunt for the right gear (feels like slipping clutch) and then bangs into gear sending the car forward.
I will keep testing but maybe this was an electrical gremlin. I will still use the Bentley to recheck my fluid level on the rack this weekend as well.
Old 04-01-2008, 09:16 PM
efrain efrain is offline
Mein Auto: Ford F 150
Transmission Malfunction, Failsafe Mode
Thank you SILVERBULLET5, I have a Ford f150 '05, I was driving when I got that Transmission Malfunction, Failsafe Mode message, I started researching when I came across your post and I opened the hood, the battery posts were covered with that white stuff, so I cleaned everything real good, went for a test drive and I didnt get that message anymore, I hope that took care of that problem, and thank you again
Old 05-15-2008, 10:18 PM
RodimusPrime RodimusPrime is offline
Mein Auto: ITR, 540iT, & Touareg V8
Hello guys, just want to point out that I, too, am having the same problem. I have a '99 540iAT and the reverse gear was a bit iffy. Sometimes it would work when the car is still fairly cold or have not been thoroughly warmed up and when it has the reverse would be sluggish on flat lands. So you're pretty much stuck if you are driving on a decline and needed to reverse. Anyways, in 2004 I was forced to buy a Remanufactured Tranny from the stealer (Peter Pan BMW in San Mateo) and had my shop in Concord install it. In 2007, the "Trans Failsafe Prog" started showing. I ignored it just because I knew that it couldn't be the Tranny as it is fairly new. It would show up rougly about twice a week. When it does, the car would die for a few seconds while it was still in gear. It would happen also when I came to a stop. It would start eventually, my "clock, radio stations, program for the seats" would be resetted. Lately, when the error shows up, the light for the DSC and brake would be lit. I would lose power on my steering wheel such as horn, volume for the radio, and cruise control. My radio would also stop functioning. I would eventually return, sometimes the duration would be 10 min to 30 or sometimes a whole hour. It's very frustrating. I have an OEM battery and it has a green color on the peep hole, so I would assume it is still good. The batt is about 4 years old. I hope this could be some kind of info for anyone who is trying to decipher this very vague and frustrating error.
Old 04-07-2010, 05:38 AM
racerock racerock is offline
Mein Auto: 745Li 330i K1200LT TL ...
Trans Failsafe - no steering wheel buttons - intermitt. seat belt warning - trans o.k
Originally Posted by RodimusPrime View Post
...In 2007, the "Trans Failsafe Prog" started showing. I ignored it just because I knew that it couldn't be the Tranny as it is fairly new. It would show up rougly about twice a week. When it does, the car would die for a few seconds while it was still in gear. It would happen also when I came to a stop. It would start eventually, my "clock, radio stations, program for the seats" would be resetted. Lately, when the error shows up, the light for the DSC and brake would be lit. I would lose power on my steering wheel such as horn, volume for the radio, and cruise control. My radio would also stop functioning. I would eventually return, sometimes the duration would be 10 min to 30 or sometimes a whole hour. It's very frustrating. I have an OEM battery and it has a green color on the peep hole, so I would assume it is still good. The batt is about 4 years old. I hope this could be some kind of info for anyone who is trying to decipher this very vague and frustrating error.
I know this is an old thread, and you only have 8 posts.... BUT, sure would like to know what the resolution was...
I'm getting very similar indicators:
- One night took my right front headlight out to take apart and get rid of the moisture inside it.
- Just 10 minutes after putting it in, took it for a ride - and the seat belt warning light would come on and not go out - even with all the seat belts latched... Driver and passenger in the front. Then it went out after a stop. Next morning similar situation, then at lunch, everything o.k. Thinking microswitch in the drivers seat belt.
- Next night - wash car, test seat belt - it is sort of o.k., think there was an intermittent. Then go to move it and wham - "Trans. Failsafe Mode" and the yellow BRAKE light on the dash are on... WTF...
-- Check trans fluid - nice and red, full
-- Clear trans codes by removing the battery ground for a while and turn lights on.
-- Test battery voltage while sitting there - 12.54 V
-- Test battery voltage/alternator after starting - 14 V ish
-- Move car, starts out o.k., then 100 yards away "Trans. Failsafe Mode" and the yellow BRAKE light on the dash are on... WTF..."
-- I drive it down the road - get this - even though it says TF Mode - it is shifting like it normally does - starts in first, etc. I have sport mode, and I can manually shift through all the gears - Trans seems fine...
This morning - here are some further clues - I notice that I have no functions on my steering wheel - No radio control, no cruise, and no horn...
Seat Belt Warning - Now the little red warning does not even come on...
I did test the ground point near the air cleaner as well - Continuity from the connector to battery ground tested fine with a DVM, and to make sure, I went ahead and took the connector off the stud, no corrosion there, brushed it anyway and put it back on. (I did not think this was an issue because all of my gauges work fine.
OBD II Scan tool showed no codes at all...
Is there a major connector somewhere that could be a problem?
My drivers seat has been intermittent in the past, three times - it stopped all functions, and then when I go to check it out - works fine after testing the power to the connector under it, and resetting the connector once, the other two times - it just started working...
Time to check out the schematics at least, but seriously - if anyone has seen something like this, I would appreciate it...
Thanks.
Old 04-07-2010, 04:02 PM
Hooray!'s Avatar
Hooray! Hooray! is offline
Mein Auto: 2002 530i Sport Premium
Peake tools dont read EGS codes. I returned mine just for this reason and purchased the Bavarian Technic software / cable solution, it reads all the modules including the trans EGS.
2002 530i
Exterior: Black
Interior: Black
Packages: Sport, Premium, Cold Weather
Options: HID, Folding Rear Seats, Ski-pass
Old 04-07-2010, 07:39 PM
Thanks. I'm probably buying the BMW softare and interface to be able to test/repair all of my BMW's.
Old 04-08-2010, 04:56 PM
Hooray!'s Avatar
The "real" BMW kit is thousands, Bavarian Technic is $287 or $9ish for unlimited VINs, it reads most BMWs from the 80's. Others to consider, Carsoft and Autoingenuity (I think that is the name)... I liked what the BT web site had to say and called them. Happy with the BT thus far.
2002 530i
Exterior: Black
Interior: Black
Old 04-10-2010, 02:29 PM
Just wanted to close the loop - Ignition switch replacement corrected all of the problems above.
I'm picking up a computer with the BMW software - should work o.k. I have an 04 745Li - and there are no manuals for it...
Old 04-10-2010, 06:47 PM
Hooray!'s Avatar
what made u think to replace the ignition switch?
2002 530i
Exterior: Black
Interior: Black
Old 08-15-2011, 02:33 PM
thegimpster thegimpster is offline
Mein Auto: 2000 740il
bokonnon - did you replace the transmission or the TCU? the same thing is going on with my 2000 740il. i got a transmission out of a 98 and now it immediately goes into failsafe.
Old 08-16-2011, 05:35 AM
Sorry for the delayed reply...
Searching on this forum and others - a relatively common problem - there is a power issue going to a number of items - vanity mirrors, radio controls on the steering wheel, cruise, stuff like that.
Figured for $45 worth a try - and it fixed it.
Old 08-17-2011, 07:05 AM
i got it, it was the TCM that made the tranny work.
Old 08-17-2011, 09:01 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
So others benefit, I just added this threads to the bestlinks:
- How people resolved transmission "Trans Failsafe Program", aka "Limp Mode" (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14)
Old 08-23-2012, 05:44 AM
bluebee's Avatar
For the record, here's another trans failsafe posted today:
> E39 (1997 - 2003) > HELP!! Trans failsafe program gurus? MAJOR problem…
Old 08-30-2012, 02:16 PM
bluebee's Avatar
For the record, another one opened today on transmission failsafe:
- > E39 (1997 - 2003) > Transmission fail safe mode stuck in 3rd gear just got the codes read,help!
Originally Posted by ill540i View Post
I have a 98 540ia and the transmission is in a limp mode,and the codes i have reade are the following:
Code001:
149 CAN wheel speeds
Code002:
049 symptom,,gear monitoring
Code003:
053 Gear monitoring 3
Code004:
059 stall speed
Any ideas?
Sent from my MB502 using Bimmer App
See also:
- How people tested & resolved transmission "Trans Failsafe Program", aka "Limp Mode" (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16)
Similar Threads
REVIEW: Autoxray 4000, and Code Reader for sale! RKT BMR General BMW Questions 14 06-28-2014 08:14 PM
The same old code again!!!! kenkorsak E36 (1991 - 1999) 6 01-21-2014 04:58 PM
Option code list Terry Kennedy General BMW Questions 16 05-14-2006 03:59 PM
