3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here. |
is the HK stereo not worth all the potential hassle?
is the HK stereo not worth all the potential hassle? there seems to be so many problems with it- is the stock system all that bad? from what I could hear the HK was a little bit better but maybe it's just not worth it..
my opinion...
it's not worth it if u like to feel and hear SOLID tight bass (this requires aftermarket upgardes which will run slightly more the HK price). if u want loudness w/ a little bass, go for the HK.
actually, u should listen to it at a dealership. Last edited by jaisonline; 12-18-2002 at 09:34 AM. |
Re: is the HK stereo not worth all the potential hassle?
"When the going gets weird, the weird turn pro." - HST |
I think the HK is pretty good, aside from the piss poor AM reception. I'm sure that is more a result from the anteana than the unit itself. It's plenty loud and doesn't sound too bad.
the HK system is a good one and I ended up retrofitting it myself to replace an aftermarket system (which was a very nice system). check out my E46 stereo page:
http://www.mindspring.com/~pmbenn/stereo.htm
my BMW page |
Get the HK
Unless you want ghetto style bass. Then, you'll need something else.
For just "loud, clear, hurts-your-ears, rock / pop / whatever" the HK is splendid. Try Billy Squier or Ozzy and turn it up 'til your ears can't take any more. It's SWEET!
I have had both; HK is worth it.
Significantly better sound. |
I haven't had any hassles with the HK at all. As for bass...it has all you should ever need unless you like to be thumping around your neighborhood. Frankly, for a strict audiophile it may be slightly too much bass as it is imo.
Eric |
Sometimes my friends complain, then I turn around and pimp slap the hell out of them.
2006 GG Evo IX GSR got acronyms? "Bbbzzzzzst and all that..." - rost12 |
Re: Get the HK
Here's an audiophile's review to the H/K.
http://bimmer.roadfly.org/3series/me...w17/43413.html Here's Edmunds' review... http://www.edmunds.com/reviews/list/...6/article.html |
for the record, I'm a long time audiophile myself and have had equiptment such as McIntosh electronics with Dynaudio speakers in sealed enclosures in vehicles. present home theater system cost more than my subaru but less than the bimmer. the HK system is a good one.
my BMW page |
Unless you plan to install an aftermarket stereo, get the HK.
my BMW page |
For a factory system, the HK is actually pretty decent. I don't know how the coupe compares to the sedan I listened to as the sub setups are different.
OTOH I think the wagon HK is a rip, as it doesn't have a sub at all. 6.5" aftermarket 'subs' I put in back aren't working out. These things I have seem to need a real enclosure which the body cavity can't provide. I'm gonna attempt to build a tiny sonotube sub recycling an old Solobaric from my old car and put it in the center of the spare tire. |
Here's an observation...
Many people seem to complain that the bass isn't strong enough for them on the HK system. Many people seem to complain of the rattles in a car. The more bass, and the stronger the "thump", the more likely you are to loosen up the car and cause rattles. Trust me, I know this from installing $3000+ in aftermarket on my Passat. And I only have a single 10" sub! I'm looking forward to getting my 330i which comes standard with the HK. I'll have in-dash CD, clean sound, and some other perks without having to cut into my car at all. If the HK bass doesn't quite rattle the windows, then that's fine. I'm sure the act of driving will loosen the car up and cause rattles well enough without it.
Eric (the Obsessed) 2002 M3 Convertible 2005 VW Passat 1.8T Wagon |
the other thing I touched on and that most peopledon't take into consideration is the quality of recorded material. on a good system, mediocre recordings (most of what you buy) don't sound much better, in fact they often sound worse. similarly, a good recording I have found will sound good on almost any system.
my BMW page |
Eric |
Ah! another heretic
I've been beating this drum for years and most folks think I'm nuts. Now, granted, I just have an -ahem- adequate stereo (VPI Jr, Benz-Micro, Tara Labs RSC interconncts, Linn Genki, PS Audio 100c, Vandersteen 2c's) but there is just "stuff" there in the LP grooves that get lost in a 44.1KHz sampling rate. People say that "stuff" isn't important. Aaaa..... Quote:
I'm amazed at how often I hear comments on the quality of a sound system, that only refer to the amount of bass it puts out. Talk about juvenile. Maybe we can get BMW to start installing Cervin Vega's in all their cars?
"dude...."
#25
there are indeed design flaws in the H/K system from an audiophile perspective, though. the tweeters are badly placed. they should be close to the mid/woofers for a central focal point and they would probably be better placed down lower on the door panel, close to the 5.25" mid-woofers. the idea is to keep the left and right speakers the same distance from your ears. this is why serious audiohpiles place the main components down in the kick panels and aimed up at the dome light (or in our case with E46s, aimed at the motion detector cover). the other flaw is the high range of the rear door speakers. ideally, these should be configured with a bandpass crossover (highs and lows rolled off - just midrange at a lower volume) this is for rear fill.
my BMW page |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
