E34 (1989 - 1995)
Old 11-30-2006, 04:25 PM
JAGJR7 JAGJR7 is offline
Mein Auto: 1989 525I
Fuse Box Location
Recently Purchased A 1989 525i For My Son.the Dashboard Lights Went Out But All Other Lights Are Working.
Thanks For Any Help
Old 12-02-2006, 04:18 PM
sander06 sander06 is offline
Mein Auto: 1992 BMW 535i
Download the manual. Section 610 at http://crass.on.ru/bmw/pdf/Bentley_B..._%28e34%29.pdf .
Old 12-08-2006, 04:55 PM
Cobit123 Cobit123 is offline
Mein Auto: 1989 BMW 525i
I had this problem a couple times. If you open up the hood, the fusebox is the black box on the drivers side, closest to the driver. On the inside of the box top it will tell you the fuse numbers for everything...Hope this will help, if you havent solved it already
Old 12-10-2006, 05:50 PM
fusebox location
thanks,we found the box,tested the fuses,seem to be okay.have to look somewhere else.
thanks again
Old 12-10-2006, 06:11 PM
GuinnessDraught GuinnessDraught is offline
Freude am Fahren
Mein Auto: 2004 330Ci
If all the lights in the cluster are out and the fuses are okay, this could likely be the problem: http://www.bmwe34.net/e34main/mainte...capacitors.htm
Old 12-11-2006, 08:48 AM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 2008 MS3
have you tested for voltage at the fuse for the dash lights?
possibly a break in the wiring. The manual will be very usefull for fixing this.
Similar Threads
97 528i glove box fuse diagram? Texas5 E39 (1997 - 2003) 4 10-21-2009 10:05 AM
Fuse Location / Fuse Map 325isONdubs E36 (1991 - 1999) 0 01-29-2006 11:10 PM
fuse box? dejavoo81 X5 E53 (1999 - 2006) 1 10-09-2005 05:29 PM
Location of Fuse Box advocat E39 (1997 - 2003) 6 10-07-2005 11:03 AM
Help! Aux Fan problem; no fuse #40? Nivola E36/7 Z3 (1996-2002) 2 05-26-2005 03:25 PM
