Old 12-06-2006, 06:41 PM
wareagle72 wareagle72 is offline
Mein Auto: 99 540 6sp
'99 540i - Lose heat at higher speeds
Did a search and could not find anything about losing speed at higher speeds. So here is my problem.
While city driving (mainly to work and back) i have heat blowing from all vents. But when i get on the highway and travel for 30-40 minutes cold air begins to blow...and i have not adjusted any of the heat settings.
Any ideas? The car is at my local indy shop now and they are confused.
Old 12-06-2006, 08:15 PM
aiwapro aiwapro is offline
Mein Auto: 2004 BMW 545i
Does the cold air blow through the visible vents, or from the floor or lower windshield area? I sometimes get cool air all of a sudden. I look at the adjuster on the center visible vent, and remember I had changed it to cool. It seems very simple, but have you checked it?
Old 12-07-2006, 08:13 PM
yeah, i checked the visible vents and cold air was blowing. Indy shop did not really have an answer either.
Old 12-07-2006, 08:57 PM
Did you move the adjuster on the center vent?
What I meant to ask, and I may have asked it wrong before, but my question is, does cold air blow from the floor and windshield?
Old 12-08-2006, 05:39 AM
Petes540i6 Petes540i6 is offline
Mein Auto: 1998 540i/6
Is the thermostat stuck open?
What does the heat guage do when you are on the highway? Does it go down? If the thermostat is stuck open, the coolant may be getting too cold from the extra air going through the radiator.
Does it take longer than ususal for the car to warm up in the morning?
I suspect that it is unlikely that your thermostat is stuck open, but you never know.
Old 12-08-2006, 04:36 PM
This explains exactly what my car does. It goes sometimes when on the highway, and takes a long time to warm up in the morning. However, if I sit at a stop light, or a drive-thru some where, for a couple of minutes, the temperature guage will eventually go straight up. Once it's straight up, it usually stays there, no matter what it seems. However, before getting there, like I said, it will go back down.
What does this mean?
Old 12-08-2006, 08:07 PM
razzy530's Avatar
razzy530 razzy530 is offline
Send a message via Yahoo to razzy530
Mein Auto: 2007 530i 6 Speed
its your THERMO!! Go replace it, do it NOW!!!! Go, Go!!!!
(BTW, i had the same exact problem, dont worry about it)
2007 E60 530i - Current
2002 E39 530i - RIP
BMWCCA MEMBER #397411
Old 12-09-2006, 11:30 AM
The center adjuster is on "red" when it is blowing the cold air. I am having the thermostat replaced as we speak. It never took long to warm up in the mornings and the temperature gage always stayed in the 12 o'clock position.
I will update when i get the car back. I am having the waterpump and the tensioner assembly and new tires put on as well.
thanks for your help.
Old 12-11-2006, 02:30 PM
glocati's Avatar
glocati glocati is offline
Mein Auto: 2000-528ia
Wareagle, any update on this issue?
My 2000 528i is starting to exhibit similar issues. - My car warms up normally and the temp guage does not flucuate (stays one lick below dead center) so i am doubting it is the thermostat?
Old 12-11-2006, 05:50 PM
Just got the car back today. Will test out the next time i am on the highway (it may be a few days) . I am hoping for the best. Will let you know
Old 12-12-2006, 08:49 AM
glocati's Avatar
thx
Old 02-02-2013, 12:13 PM
akillies akillies is offline
99 540i Make Over
Mein Auto: 99 540i
wareagle72, was it the thermostat? I am having the exact same problem with my 99 540i.
Similar Threads
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW 7 07-19-2006 04:52 PM
99 540I (E39) heated steering wheel issue Beachbumm E39 (1997 - 2003) 10 02-01-2006 12:19 AM
Does anyone know new E30 cold air heat shield? goong E30 (1982 - 1993) 1 09-08-2005 03:23 AM
Should I choose oil or gas heat? Plaz Off-Topic 38 08-12-2004 07:24 PM
