Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 12-10-2006, 07:38 PM
findog findog is offline
Mein Auto: 2002 540iA
01+ Broken Headlight Adjuster Fix (E39)
Just want to share my fix for 01 - 03 E39 Headlight adjusters. I found the parts at http://www.odometergears.com and thought I would give it a shot. Parts worked out great, it's nice to have headlights that don't point down.
PDF DIY -
Part 1 - http://www.bimmerfest.com/forums/att...9&d=1165817474
Part 2 - http://www.bimmerfest.com/forums/att...1&d=1165817580
ID:	94053   Click image for larger version
2002 540iA Sterling Gray
1999 540iT (retired)
Old 12-10-2006, 07:44 PM
frhsfootball80 frhsfootball80 is offline
looking for a car
Mein Auto: e39 m5 & 92 civic
hey another E39 owner in DFW, welcome. and those adjusters will probably break again in due time. its just how it works i guess. id try to layer them with something that would support them. maybe JB weld?
Old 12-10-2006, 07:52 PM
chivas's Avatar
chivas chivas is offline
You Lick It, You Own It
Send a message via ICQ to chivas Send a message via AIM to chivas
Mein Auto: 98 540i/6
email me the PDF:
chivas228 at gmail.com
americandan.com
It takes a lot of work to be lazy.
Old 12-10-2006, 07:58 PM
Chivas:
DIY .pdf on its way to you.
Old 12-10-2006, 08:37 PM
chivas's Avatar
thanks!! i got it... trying to cut it up in 2 so it can be attached as 2 files.
americandan.com
Old 12-10-2006, 09:09 PM
kc5's Avatar
kc5 kc5 is offline
Mein Auto: '03 530i 5-speed, SP, PP
Great find. My adjusters aren't broken yet. I look forward to reading more about your fix.
Sent from my iPad...............no one cares
'03 530i 5-speed, Sport & Premium Pkgs
Old 12-10-2006, 09:10 PM
Now why didn't I think of that? 2 files? If you have any trouble let me know, I can go back in and edit. I did this in PowerPoint.
Old 12-10-2006, 10:14 PM
Chivas:
I made some changes. Hope this helps others. If anyone needs higher resolution pics, just PM me.
Mike
Old 12-10-2006, 10:50 PM
kaleb's Avatar
kaleb kaleb is offline
I make websites.
Mein Auto: 2007 335i Coupe MT
Very nice write up! Thank you a bunch! I will reference these when I get my new adjusters. I HATE driving at night right now.
2007 335i Coupe MT - Space Gray Metallic / Coral Red / Gray Poplar
Options - Premium Package, Sport Package
Mods - V1 Fusebox Hardwire, OEM Alarm System, Llumar 20% Tint, 3M Paint Protection Film
Work I've done - OEM Alarm Install, V1 Hardwire
2001 540i Sport MT (Traded) - Alpine White / Black
Options - Premium Sound (DSP), Rear Sunshades
Mods - Koni FSD/Eibach, Axxis Deluxe/Brembo, RP Synchromax, V1 Hardwire, DICE HD, Aluminum Adjusters, CDV (ZR), Tint
Old 12-11-2006, 12:11 AM
Kwaaahhh Kwaaahhh is offline
Slammed E39!
Mein Auto: 03' 530i
Do you have oem ae on your headlight?
Old 12-11-2006, 04:51 AM
Yes, original OEM headlights .........
Old 12-11-2006, 12:32 PM
chivas's Avatar
putting this in the FAQ. thanks!!!
americandan.com
Old 12-12-2006, 12:03 AM
gixxer gixxer is offline
Mein Auto: 03 E39 VFE DINAN5/04 M3
Great DIY write up!!!
Few odd questions:
a) where stated in write up, "thread the new pieces on the existing headlight adjustment white screw", is the cutting of the new threads necessary on the new piece done by the screw with the 10mm nut (that can also be turned by the white adjuster screw but not advised), at the direction shown in following picture?
Or, maybe i got this thing all wrong in how the new adjuster piece is screwed/threaded on to the existing screw.
b) In the following picture, how are the A and B adjustments affect the proper alignment of the headlight?
c) After cutting the new threads on the new pieces, is it recommended to still use the 10mm nut to do final headlight adjustment? Or use the white adjuster screw?
Thanks much!
Old 12-12-2006, 12:18 AM
Slammed E39!
Mein Auto: 03' 530i
Damnit if only I got balls to open up my headlight! Anyone in the bay want to do mine?
Old 12-12-2006, 04:31 AM
Gixxer:
Question = a) where stated in write up, "thread the new pieces on the existing headlight adjustment white screw", is the cutting of the new threads necessary on the new piece done by the screw with the 10mm nut (that can also be turned by the white adjuster screw but not advised), at the direction shown in following picture?
Answer = correct. I turned the 10mm black nut clockwise(below the white adjuster knob) to thread the new piece on the threaded rod inside the chassis. The new piece did not look like it was threaded, and it required some torque to run all the way up to the end. Do not use the white knob to do this, the teeth cannot take the stress. Once you have run the piece back and forth a few times, the white knob will handle all future adjustments.
Question = b) In the following picture, how are the A and B adjustments affect the proper alignment of the headlight?
Answer = (A) seems to be the main adjustment for height. I think (B) is for the high beam as it did not seem effect the low beam pattern. I never had the high beams on when I set the lows, so I am not sure. I could not find any info in the owners manual on headlight adjustment procedures. Maybe someone else will chime in with additional info.
Old 12-22-2006, 08:51 PM
john530i john530i is offline
Mein Auto: 530i sport
This may sound stupid but how do you know if this repair is needed. I just received my 01 530 with HID and it seems to be point straigth down, i turned the screw at least 5-8 rotations with no noticable difference on the wall. I am wondering if my is busted also.
John
2001 530i Sport
Titanium Silver
Premium Package
MKIII Navi/CD changer
Old 03-12-2007, 06:07 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
This may be a little off the subject but I have 1 in 3 people flash their high beams at me even though just my low beams are on. I have the auto leveling HIDs and am wondering if thats normal or could they be adjusted too high? Any input would be greatly appreciated, especially by wife.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 03-12-2007, 01:38 PM
4dreuropean540i 4dreuropean540i is offline
Mein Auto: 99 540i/6
i have another sorta off topic Q...
if you have say a 99 like i do, do you have to follow the same steps to change the adjuster? or is their another way for the older model non-angel eye style headlights?
thanks
Old 03-17-2007, 05:48 PM
CHRIS341 CHRIS341 is offline
Send a message via AIM to CHRIS341
Mein Auto: 97 540 6
Crazy Glue Works Great Also!
Old 03-17-2007, 06:41 PM
Oscswa's Avatar
Oscswa Oscswa is offline
Oscar
Mein Auto: 330i Sport
Good write up. One thing to note is that not all OE AE Headlights will come apart in the oven or with a heat gun, some are sealed with epoxy and will not pry apart.
For example my drivers side comes apart real easy in the oven, but the pass side has will not come apart.
Oscar
Dallas, TX
01 540i Sport
06 330i Sport
01 530i Sport
01 540i Sport 6spd
Old 03-17-2007, 07:50 PM
laidback's Avatar
laidback laidback is offline
Mein Auto: M's
I have replaced my adjusters (both lens)...ordered mine from Odometergears.com ask for Jeff (great guy, easy to deal and very fast shipping) the very next day i got my new adjusters and installed them with ease ( well i baked them and used a blow dryer to keep it warm)...i have another set oe AE i will work on soon imho it's worth it...
Old 04-06-2007, 03:10 PM
Tony Whelan Tony Whelan is offline
Mein Auto: 1998 528I
1998 528i E39 headlight adjusters
Hey findog,
I reviewed your excellent post on replacement for the 2001-2003 E39 headlight adjusters. Can you give me the details for how to replace the headlight adjusters for my 1998 528i? Your help would be appreciated. I have purchased the kit from my local BMW dealer for the $20 you mentioned in your post. However, talking to the service department, I could see that they weren't very knowledgeable about what this procedure will entail. Thanks very much.
Cordially,
Tony Whelan
My email is RWhelan539@aol.com
Old 04-06-2007, 04:56 PM
Tony:
I do not have any experience with pre 01 headlight adjusters. I think there are DIY instructions at http://www.bmwtips.com/
Old 11-29-2007, 08:42 AM
harleyman harleyman is offline
Mein Auto: 528i
dude its so easy only 4 bolts hold the whole thing in
Old 11-29-2007, 11:34 AM
Sinh Sinh is offline
Send a message via Yahoo to Sinh
Mein Auto: BMW 540ia w/ M-package
Findog,
Great write up on the headlight seld-leveling adjuster DIY, because I am experiencing the same problem, but I don't have the ball to open up my headlights .....lol....I really don't know what to do....I guess I have to wait and same up some $$$ and buy new headlight.
Sinh
Similar Threads
Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions EPBB E46 (1999 - 2006) 119 05-09-2010 04:09 PM
Disappearing dash pixels - DIY fix? TXE38 7 Series / 8 Series 15 01-18-2010 04:39 PM
DIY "Brake Light Failure" CCM Fix!!!! YEA! bmwfreq Do-It-Yourself H.Q. 14 08-16-2006 11:00 AM
Is there a DIY for fixing a broken sunroof shade? wag-zhp E46 (1999 - 2006) 11 07-21-2005 05:23 PM
front brakes-- DIY fiasco-- broken bolt /cut wires bmw325 Do-It-Yourself H.Q. 41 04-23-2005 05:13 AM
