5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
#26
These are the reasons that I like this forum. Thanks for posting Findog.
Lots of companies make tiny parts out of billet alum. for R/C cars, would be nice to see somebody start building parts for full size cars that are prone to failure. Quote:
#28
findog can you please send me the pdf to down.en.out******s@gmail.com
#29
Good write up!
I was able to get mine apart and found out my adjusters are just fine!!! I've been using zip ties to hold the light higher thinking they were broken! Turns out, the lights are fine.. probably the fact that I'm so tall, maybe has a little to do with it me thinking the lights were too low |
#30
That's a little weird, if you have two headlights on the same car, one glued and one epoxied. |
#31
I just had this same thing happen. Took it into the dealer and they indicated that it was just installed incorrectly and repaired it for 1/2 hour labor charge only. Guess I got lucky.
Great info though!
TimW Last edited by TimW; 02-21-2008 at 10:50 AM. |
#32
I found this post while searching for how to identify parts in order to adjust my 2002 E39 headlights.
I took the liberty of shrinking DIY PDF here to fit the 500 KB limit and converting the PDF to pictures so it can be read by anyone without the PDF here. |
#33
Just last week, I followed findog's instructions, including putting the housings in the oven (although only at 180 degrees). That did help a lot in getting the lens off the rest of the housing. I used aluminum adjusters from EAC tuning. All worked out great. You do need to be very careful removing and replacing the headlight assembly from the car as there is a trim piece on the bottom of the assembly that hooks into the edge of the fender. It can be easily broken if you are not careful, and gentle. There is another DIY out on the net that says you do not need to put the assembly in the oven, but I guarantee I could not take mine apart before warming in the oven.
Last edited by tnations; 01-03-2010 at 03:12 PM. Reason: spelling and adding last sentence. |
#34
Epoxy on the lense
Use a sharp xacto knife or razor to cut the epoxy.
#36
Mover, does this work on the 2003 headlights that supposedly have a stronger bonding glue and cannot be "baked" apart?
#37
http://www.ca-automotive.co.uk |
#38
Mover
Will you please tell me where in the CA Auto website does it show the procedure for opening the epoxy lens? Thanks |
#39
Not only is EAC the only company in the USA who sells the aluminum repair parts, I offer to repair the 2002-2003 lights that will not open in the oven for you. Getting the lens off with a knife or blade is VERY difficult and you will not do so without sacrificing the seal of the light. I have a much better method that does not let moisture or fog build in the lights. I have been repairing these for about 4 years with fantastic results. If anyone would like to send theirs in just send me an email or PM.
#40
How do you test the auto adjustment feature to see if it's working or not? My low beams seem too low and I don't notice any movement on my garage wall when I turn the lights on.
#41
They have never had a problem with the epoxy lens. Knowledgeable and friendly bunch of guys to deal with. They do a lot of business with BMWs. The one below belongs to one of the guys. E39 540 CA Auto in the press enquiries@ca-int.co.uk www.ca-at.co.uk Tel: 0044 (0) 871 231 1010 Last edited by - Mover -; 06-08-2010 at 03:58 PM. |
#42
I just replaced my adjusters with the ones from eBay. They seem to be of good quality and the job was no where near as bad as I thought. This write up sure helped. Thanks!
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot. |
#43
How are folks readjusting their lights AFTER repairing them? The Bentley Manual is no help as it just has a grey box warning indicating some special procedure needs to be done.
It would be nice to find out how far from a wall one should be and where on the wall the lights should be adjusted to. For now, I just adjusted them on my garage door, went for a spin, adjust some more, and called it good but I would like them adjusted correctly if at all possible.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (97k miles) 2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease transferred...no longer have) |
#44
This is not as technical as what you are looking for but.....
I had my wife drive the car at night behind me while I observed the angle of the headlights. I discovered the driver side was too high and the wall procedure did not reveal this. |
#45
Hi Ågent99,
I still have my headlight adjusters to do myself (I still haven't debugged which ones I need) so I take a keen interest in this. In the bestlinks thread, there is a point for adjusting headlights at: - Adjusting headlights Do the diagrams and procedures there help (I was unsuccessful, but, probably more due to the adjusters doing nothing than to the procedure). Other than that thread, maybe this set has how to actually adjust the headlights (I didn't check 'em all - just the one above): Useful BMW E39 broken headlight adjuster links (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) |
#46
link to aluminum headlight adjusters for the 2001-2003 lights:
http://www.eactuning.com/e39-aluminu...ers-p-467.html The Hella lights found in 2003 cars, and the Hella euro xenon lights that can be bought aftermarket will not open in the oven. I don't care what anyone says. CA is very reputable, but they do not offer an installation service for these parts like I do. I have handled dozens of these lights and yes, the ones that will not open in the oven are out there. It is well documented that a different sealant was used that is not effected by heat. You will destroy the plastic light before that particular adhesive gives. If you find your set will not open just send me a PM and I would be glad to fix them for you. |
#47
Even after all this time, I still am frozen with indecision about MY headlights. I wonder if you've run into this: - It's a 2002 525i & the headlights are pointing mostly downward very stably. - I turn the passenger side two fittings and the light moves but in strange ways (maybe I don't understand how to adjust them) - I turn the driver's side fittings and nothing moves whatsoever (as measured by pointing to a garage door at night) - However, NOTHING bounces on the road ... it points consistently downward without bouncing. - Strangely, if I grasp the driver's side bulb, and wiggle, both bulbs wiggle without any friction whatsoever ... - On the other hand, if I wiggle the passenger side bulbs, they move but with muuuuch more friction holding them together - It doesn't help that I have broken tabs but people say that isn't the problem. From that (admittedly lousy) description, should I pay for new headlights or just new adjusters? That enigma is what is holding me up (I hate when I don't have a good diagnostic tool - it freezes me like, well, uh ... like a deer in the headlights). Re-using a pic from that thread (the question was answered already that the tab is part of the headlight assembly). Last edited by bluebee; 10-04-2010 at 09:22 AM. |
#48
bluebee,
Sounds like your adjusters are busted...just like mine. If you turn the adjusting knobs and nothing to little happens, they are toast. I replaced my plastic adjusters with some aluminum ones I bought like 2-3 years ago. Finally got around the tearing the lights apart yesterday and it went pretty well heating in the oven, working them apart. Once apart, they are simple to replace. The housing that holds both bulbs is one unit so moving one moves the other. The friction you feel just depends on HOW the adjusters busted and what happened to them as you try to adjust the lights. You could've jammed pieces together or freed them up a lot. So in some cases, they will be very loose and possibly in others, they could be very tight. Hard to say but I'm pretty confident that yours need replaced. Here is the thing, it is only a matter of WHEN they break and not if. As it turned out, my passenger side adjusters were fine but I replaced them anyway. The driver's side ones were both complete toast. The broken tab probably isn't an issue but if the light moves around a bit because of it, THAT can be a problem in getting them aimed properly. I think some Plastic Weld (epoxy available at most hardware stores...just go to OSH) will probably fix that one up fine. Get the aluminum adjusters, come over, and we'll knock this all out in an hour.
#49
As to the headlight adjustments, what is suggested in bluebee's post is pretty much what I figured or is standard:
(1) Make sure tires are inflated to normal psi, tank about 1/2 full or so, typical driver in seat. (2) Park close to a wall on a level surface. (3) Mark horizontal line with tape. (4) Mark vertical line with tape to make a + sign for left/right light. (5) Back up 25 feet. (6) Adjust centerpoint of light 2" below horziontal line. (7) Adjust vertical 2" to the right of vertical line.
The horizontal and vertical adjustments are absolutely possible on my Xenons (2001 530i).
#50
agent99 is correct. We just have some generic symptoms listed on our site and they may not apply to all lights with busted adjusters. The biggest give away that yours are broken would be the facts that they are pointing too low and do not respond to adjustments you make.
It's much cheaper obviously to just replace the adjusters. However if yours have broken tabs and what not you may opt to replace the whole light. I would be happy to get you a quote on a replacement or a pair if you'd like. Keep in mind though, a couple few years down the road you may find yourself back at square one, with broken adjusters. I would glue the mounting tab and repair the adjusters. Also, it has been a while but for those of you looking for how to aim the lights there is a lot of great aiming info on www.hidplanet.com, it is a forum all about lighting. Lots of good info there. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions | EPBB | E46 (1999 - 2006) | 119 | 05-09-2010 04:09 PM |
| Disappearing dash pixels - DIY fix? | TXE38 | 7 Series / 8 Series | 15 | 01-18-2010 04:39 PM |
| DIY "Brake Light Failure" CCM Fix!!!! YEA! | bmwfreq | Do-It-Yourself H.Q. | 14 | 08-16-2006 11:00 AM |
| Is there a DIY for fixing a broken sunroof shade? | wag-zhp | E46 (1999 - 2006) | 11 | 07-21-2005 05:23 PM |
| front brakes-- DIY fiasco-- broken bolt /cut wires | bmw325 | Do-It-Yourself H.Q. | 41 | 04-23-2005 05:13 AM |
