5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
#76
They say 5 minutes.
![]() 1999 528it Sport 5Sp |
#77
Mine is also glued with epoxy. It dont come off when i tried to cut the epoxy. Does someone has some suggestions?
#78
I replaced the adjusters on 2001 530i Hella HID headlights today using the procedure in this thread. The procedure worked well. Here are a few observations.
I used the aluminum adjusters from EAC which are threaded. I didn't need to cut threads in the adjuster with the screw. Mark at EAC suggested baking the headlights at 210 F for 7 minutes instead of 5 minutes at 200 F. After I removed lens, I baked the headlights for two more minutes to ease the removal of the bezel. I found that if I removed the HID bulb so I could see the auto-leveling motor ball and socket. This made it easier to reinstall the auto-leveling motor ball in the assembly socket. The ball came out of the socket to the right on both headlights. I removed the socket from the reflector assembly to get the old plastic adjuster remnants out. This allowed me to use a small screwdriver to depress the retaining tab from the back of the socket so the screwdriver did not interfere with the ball removal. I didn't realize how poorly the lights were working. This repair restored their performance.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
#79
I stumbled upon a source of butyl rubber glue for headlights. My headlights went back together well and appear to be well sealed, but I thought it might be helpful to people replacing adjusters if the headlights do not seal well on re-assembly.
#80
2000 525i
#81
Excellent writeup. I was able to fix my adjusters. Thanks a lot.
#82
For the record, there is useful headlight adjuster information here today:
- E39 (1997 - 2003) > 2003 530i Sport Headlight Adjustment - How
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#83
Hello all,
Looks like I have to deal with this issue at well. I have an '03, and the autoleveling headlights have stopped leveling when I turn the car on, and they point rather low on the road. I have not yet attempted to make any adjustments on my own. Mark@EAC, are you still working with these '03 assemblies? Is it pretty clear that I need new adjusters? Thanks all. |
#84
Hey, just wanted to drop by and say thank you for the excellent writeup! I followed it this weekend and now the lights adjust properly. Thanks again!
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions | EPBB | E46 (1999 - 2006) | 119 | 05-09-2010 04:09 PM |
| Disappearing dash pixels - DIY fix? | TXE38 | 7 Series / 8 Series | 15 | 01-18-2010 04:39 PM |
| DIY "Brake Light Failure" CCM Fix!!!! YEA! | bmwfreq | Do-It-Yourself H.Q. | 14 | 08-16-2006 11:00 AM |
| Is there a DIY for fixing a broken sunroof shade? | wag-zhp | E46 (1999 - 2006) | 11 | 07-21-2005 05:23 PM |
| front brakes-- DIY fiasco-- broken bolt /cut wires | bmw325 | Do-It-Yourself H.Q. | 41 | 04-23-2005 05:13 AM |
