Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 01-25-2002, 10:51 AM
JD JD is offline
BMW fanatic
Mein Auto: '01 VW GTI
Wheels
I recently bought a previously owned bimmer. The wheels are in good condition, but not perfect. There are some visible traces of dirt/grime. Car wash soap would not remove this. Any suggestions on how to remove? The wheels are 1998 M3 LTW polished wheels. Thanks.
2001 VW GTI Reflex Silver, Frozen slotted rotors with Porterfield pads, Bilstien sports, H&R race springs, H&R 22mm front sway bar, H&R 5mm rear spacers, Neuspeed upper strut tie bar, Neuspeed 25mm rear sway bar, Audi TT 5 spoke forged wheels with SO3s, Upsolute chip, AEM CAI, Thermal R&D Catback exhaust, Autotech Stage II Drivetrain upgrade w/lightweight clutch, Euro front and rear bumpers
Old 01-25-2002, 12:42 PM
Guest84 Guest84 is offline
Account closed at users request
Mein Auto:
Alan F. had some pretty bad wheel dirt, grime..forgot what he used..hopefully he'll be along soon.
Old 01-25-2002, 12:54 PM
gundamzaku gundamzaku is offline
Send a message via AIM to gundamzaku
Mein Auto: 1992 325i
maybe you can use some engine parts cleaner spray, but only spray it then immediately remove it or it will eat the wheels away.
Old 01-25-2002, 01:43 PM
GTI GTI is offline
Mein Auto: 2001 330i SP/Step
Eimann Fabrik Hi Intensity cleaner. Mix 50/50 with water. Or other non-acid cleaner.
For a quick ONE TIME fix dilute Simple green at least 50/50 with water and you MUST seal the wheel with a good wax or polymer sealant right after you got it clean. Rainse the hell out of it, dry/seal.
Meguiar #20 Polymer sealant is one sealant you can get locally at Pepboys/Kragen. Zaino/Klasse works great too. Nu-Finish also works and last long but it is sort of abrasive.
(Note: Only recommend you use simple green the first time. DON'T use it regularly.)
You can order EF Hi-Intensity at places like http://www.properautocare.com/hi-c32.html
Similar Threads
BMW Wheels vs. Aftermarket/Replica/Refurb (Which to get?) OBS3SSION General BMW Questions 37 02-24-2003 06:42 AM
4 E39 17x8 Style 5 wheels + Kumho 245/40/ZR17 tires - $950 (So. Calif. preferred) Vincent528i Classifieds 0 10-01-2002 05:26 PM
330Ci - 17" vs 18" Stock Sport Wheels MikeW 3 Series & 4 Series 34 08-03-2002 12:41 PM
