Old 12-16-2006, 08:00 AM
MrSheen MrSheen is offline
Mein Auto: Z3
Z4 6 Speed Gearbox in a Z3. - Help
Please can someone can help me.....
I want to fit a 6 speed trany in my 2.8 M52TU Z3.
I have been offered a GS6-17BG box from a Z4. The Z4 had the new N52 engine. Does anyone know if the GS6-17BG will bolt up to my engine? Are the gearbox bolt locations onto the engine on the N52 engine and the M52TU the same?
It looks like it will from the line drawings I can find, but the drawings are poor and I don't want to end up with a box I can't use.
Old 12-16-2006, 08:29 AM
99flhr 99flhr is offline
Mein Auto: 00 Z3 2.8
Several members have installed 6 speeds, (Mpire comes to mind) use the search to find out particulars.
Old 12-16-2006, 08:44 AM
Mein Auto: Z3
I have spent a good few hours searching but I cannot see where anyone has taken a box from an N52 machine and shoe horned it into a Z3. The bolting patterns look similar, but its a big risk incase they don't totally match.
Looking at the flywheel in the N52 it only uses 6 bolts where as the M52 has 8. I will therefore have to use my existing flywheel, but that means I will need to do some kind of mod for the bearing housing for splined input shaft end bearing. The clutch has a different spline profile so I will need the Z4 clutch, The Z4 clutch is only 228mm where as mine is 240mm. These problems I feel I can overcome, but I just need to be sure the bell housing will bolt up. Someone must know.
Old 12-16-2006, 09:09 AM
wildag's Avatar
wildag wildag is offline
///M 'n it up!
Send a message via AIM to wildag
Mein Auto: '06 Z4 M Roadster
Ask the seller to put a piece of tracing paper over the end of the bell housing and pencil rub the holes. Then you can use that to match up the bolt holes on your car.
Old 12-16-2006, 09:15 AM
Mein Auto: Z3
Tracing paper is a good idea, but I'm not sure the junk yard man will be that helpful.
Old 03-13-2013, 03:05 PM
oliver.mogan oliver.mogan is offline
Mein Auto: 98 z3, 89 325es
so did we find out if there is a 6spd that will bolt into a z3?
I am still hoping it is possible and appreciate any information related to this. I have a 98 Z3.
Also, do the 5spd manual transmissions installed in the z3's come with different gear ratios depending on the motor installed?
Last edited by oliver.mogan; 03-13-2013 at 03:08 PM. Reason: forgot to add some info
Old 03-13-2013, 05:00 PM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
All the 6 cylinder Z3's came with the same transmission. The rear diff ratios were different depending on the motor. I swapped a euro E36 6 speed into my Z last fall. Here is the link.
http://forums.bimmerforums.com/forum...and-Diff-build
The other option for you is that you can use a US E46 6 speed but it requires a different clutch set up. Those are cheaper to come by but also a bit of piecing together of different parts to make it work properly. I have heard of people using a Z4 box but have not come across a DIY for it so I don't know what parts are necessary to make it work. My guess there is a whole lot more fabrication involved so it is more cost prohibitive.
Here is another link to UUC's website concerning the 6 speed swap.
http://www.uucmotorwerks.com/98M3/up...6SPD/index.htm
The swap is not really cost effective in any sort of way. I figure I'll have to go 130,000 miles in 6th gear to break even in gas savings but I love having the 6th gear and would do it again in a heartbeat.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2006 Inferno Red Ram 3500 MegaCab 3500
2010 Rescue Green 2 door Wrangler Mountain Edition
Old 03-14-2013, 06:41 PM
gmushial gmushial is offline
Mein Auto: 1999 Z3 2.5L
Depending on the engine and year, there are different transmissions and diffs:
all 1.9s S5D 250G Getrag trans 3.45 diff
2.3 99-00 " " Getrag trans 3.15 diff
2.5 01-02 " " Getrag trans 3.46 diff
2.8 97-00 S5D 320Z ZF trans 3.15 diff
3.0 01-02 " " ZF trans 3.07 diff
///M S52 " " ZF trans 3.23 diff
///M S54 " " ZF trans 3.15 diff
the automatics are differently entirely
the Getrag and ZF trans are essentially the same ratios wise:
Getrag 1st->5th 4.23 2.52 1.66 1.22 1.00
ZF 4.21 2.49 1.66 1.24 1.00
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
Some Exciting New Product for the Z3, Z4, & M Roadsters! Jlevi SW E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 16 11-05-2006 01:39 PM
NYT: Speed Trap Tour in Northeast 325xi_dc General BMW 18 03-27-2006 06:37 PM
97 Z3 2.8L 5 Speed BlackZ3 Cars - Private Party 0 04-20-2005 06:22 PM
Alternative to a shorter diff? Nick325xiT 5spd 3 Series / 4 Series 28 04-05-2002 07:06 PM
