View Poll Results: What percentage of time is your automatic in manual?
Never 3 17.65%
Less than 25% 10 58.82%
Around 50% 2 11.76%
More than 75% 2 11.76%
Voters: 17. You may not vote on this poll
Old 05-07-2011, 09:07 PM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
Driving my Automatic as a Standard
I find myself driving my automatic more in the manual shift mode than in automatic. I thought I'd create a poll to find how you automatic owners drive.
I find there are several situations where the X3 is just in the wrong gear; at least not the optimal gear. To get it to change, I have to press the accelerator a considerable amount for it to kickdown, then the revs are too high. In manual mode, I can get it to a lower gear and the revs are perfect as well since I can control the revs with the accelerator pedal and the gear with the shifter. The functions are independent.
In particular, going up hill at a steady rate and I want to briskly accelerate, the X3 doesn't change gear unless I press the accelerator hard, then it sounds like I'm trying to race. Another situation where I find the X3 in the wrong gear is when slowing down then needing to speed up quickly, it doesn't drop down a gear. Not to say it moves away slowly, not just as briskly as if it was one gear lower.
Consequently I think I spend well over 75% of the time in manual shift mode. Basically the only time I'm in auto is in bumper to bumper traffic and on long stretches on the highway. Maybe the fact that all my other cars are manual has something to do with this as well.
1979 Porsche 911SC
1996 Porsche 993 C4S
2003 BMW M5
2013 BMW X3 35i
Old 05-07-2011, 09:28 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
I use the selector a lot, especially on downgrades.
Old 05-08-2011, 07:36 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
The gas mileage is bad enough without using the manual.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Matts-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Matts
Old 05-08-2011, 06:31 PM
Mr. J Mr. J is offline
Mein Auto: X3
cheers
vern
mine is better using the manual,,,
Old 05-08-2011, 06:57 PM
Mine is a little better as well shifted manually. I know typically standard shift cars get better mileage than automatics, but I wasn't sure if this applied to automatics shifted manually. I reset my trip computer with every fill up and consistently get 18.5-19 mpg whether I leave it in auto or not; typically slightly better shifting.
I think the key is not to do jack rabbit starts and rev the engine up to 5k rpm regardless of the stick position. For best gas mileage in the standard mode, I think shifting a little less than 3k rpm is the secret.
1979 Porsche 911SC
2003 BMW M5
2013 BMW X3 35i
Old 05-08-2011, 07:41 PM
AzNMpower32's Avatar
Tar Heel Faithful
Mein Auto: X3
I live it in Drive and go. Works for me and my driving habits 90% of the time. The Sport mode (auto shifting) works for the other 9%. I use manual mode only on longer/steeper gradients for stronger engine braking.
Do you have the 5-speed or 6-speed automatic? I find the 5 speed plenty responsive, probably a bit more than necessary but that might just be because I have the 2,5 litre.
Old 05-08-2011, 08:40 PM
I have the 5 speed. I wish I had a 6th gear.
1979 Porsche 911SC
2003 BMW M5
2013 BMW X3 35i
Old 05-08-2011, 08:55 PM
Tar Heel Faithful
Mein Auto: X3
The 6th gear doesn't lower highway revs. It just fills in the huge gap between 4th and 5th.
Do a search, try resetting the Adaptation values. I think it's something like, turn the electronics on but dont start the car, hold the throttle to kickdown for 20 seconds, then start the car.
Old 05-08-2011, 10:03 PM
madurodave's Avatar
BMW Enthusiast!
cheers
vern
I'm still getting 23 to 24 mpg. Not too bad.
Madurodave
My garage: 2007 BMW Z4 3.0si Manual, 2007 BMW X3, 2006 BMW 530xi
Retired: 1998 BMW Z3
Member of BMWCCA!
Old 05-09-2011, 10:02 AM
Thanks. I'll search adaptation values.
1979 Porsche 911SC
2003 BMW M5
2013 BMW X3 35i
