power steering pump?? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 12-29-2006, 08:00 PM
black99bimmer's Avatar
black99bimmer black99bimmer is offline
Mein Auto: 1999 bmw 328i
it just started but it sounds like the power steering pump is low on fluid but it is full. so im trying to figure out what is going on here!!!! if anyone knows how to fix this please let me know.
black 99 328i sedan.
premium package
shark injected
cold air intake
Old 12-29-2006, 08:44 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
The pump might be on it`s way out....is it original to the car ? Is it making moaning & groaning noises ?
Regards,
Bob
Old 01-01-2007, 05:20 PM
yeah, but it was all of a sudden, almost instant.sounds like its lowon fluid or its not getting enough
premium package
shark injected
cold air intake
Old 12-05-2007, 02:01 PM
jburns's Avatar
jburns jburns is offline
Mein Auto: 2007 BMW 328i Coupe
I have a 2002 325I and it is doing the same thing all of a sudden for about the last week and a half. My mechanic, who specializes in Mercedes and BMW, said it is the power steering pump. He said they had another customer with the same symptoms and same car and after changing out fluid, checking for leaks and changing out hoses, replacing the pump was the only fix. I always thought the pump either worked or it would quit altogether. The mechanic said they can start going bad and produce these symptoms until they finally go all the way. I have changed out the fluid (siphoning out the old, making sure to use ATF) with no permanent improvements. Getting my new pump installed Friday! Also replacing all the belts since they're all coming off anyway!
Old 12-05-2007, 05:27 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/05 X5
Mine moaned for a few months before snapping the shaft in the pump.
Old 12-05-2007, 06:57 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Same symptoms here, started after I fixed leaky P/S hoses. Not sure if the two are related, but it is time to replace your P/S pump. Say bye bye to $400 if you DIY, if not probably $600 plus....
Old 12-05-2007, 09:20 PM
DM3MD DM3MD is offline
Mein Auto: 325xi
I just had this fixed on my car today; sent you a PM.
Old 12-07-2007, 12:59 PM
jburns's Avatar
Got my car fixed today! Like a new car! About $330.00 for the pump and $100.00 labor. My mechanic is the shiznit! Hillcrest German Auto! Rocks.
Old 12-07-2007, 03:11 PM
smolck's Avatar
ROLL TIDE!
It would almost be worth it to drive to Arkansas for that price! WOW! I'll pick up Houston Nutt with me on my way thru Mississipp! Where did they get a pump for $330?
Old 12-07-2007, 07:40 PM
jburns's Avatar
I have no idea where he got it. He just said it was a rebuilt BMW pump. He only gets them from places where he KNOWS who rebuilt it. When I was checking around, Advance Auto Parts said they could have me one delivered for $140.00. I was tempted, but my mechanic said I may get lucky & not have problems, or I could get f#@ked. I went with his knowledge and experience! .....and come on to Arkansas! ....and bring ANY coach! lol
Old 12-07-2007, 08:09 PM
crowz's Avatar
My friend tried advance, orileys and autozone and all 3 allowed him to pay for it but later refunded his money saying there werent any rebuilt ones to be had. I got lucky on mine I guess.
BMW_tech's Avatar
BMW_tech BMW_tech is offline
Send a message via Yahoo to BMW_tech
Mein Auto: rickshaw
personally,I would have checked the pressure the p/steering pump is putting out.the fix could be as simple as a $10.00 part.there is a check valve on the other end of the pressure hose right before it goes into the power steering rack as pictured on this diagram :
http://www.realoem.com/bmw/showparts...58&hg=32&fg=20
item number 6 on the picture.i have had this banjo bolt with a check valve fail,its a good idea to replace this when you get the pump replaced or get the system drained when power steering work is performed.
YOUR SECRET ADMIRER
Old 12-07-2007, 08:42 PM
jburns's Avatar
I will mention this and show it to my mechanic if it's alright with you BMW Tech. I am lucky to have him close to me. All he does is BMW & Mercedes and you always leave his shop knowing the problem was FIXED RIGHT. If he is not aware of this possibility, he'll be glad to learn it.
Old 11-20-2009, 06:32 PM
gtolley gtolley is offline
Mein Auto: 325i
me too
My 325 is also having the same issue. I got my part from Advance Auto Parts. Was very reasonable and is less than $200 so far.
Old 08-02-2010, 07:14 PM
BillyDBmW BillyDBmW is offline
Mein Auto: Bmw325i
I had the same problem with my car and my power steering pump went just the other day. its been a work out driving with out it . am i better off just buying the part rebuilt or new??? and should i buy the part and have the mechanic put it in.. or should i just leave everything to the mechanic.
Old 08-02-2010, 09:26 PM
Cabo Bimmer Cabo Bimmer is offline
Mein Auto: 320i 2001
Cool No problems so far
I had the same problem so I bought this LF30 pump for $140 and worked perfect http://cgi.ebay.com/ebaymotors/E46-3...Q5fAccessories
I also changed the lines and the deposit. Works really nice I did it my self, 2 hours after was driving no sounds at all and very smooth driving
Old 08-04-2010, 05:13 AM
Christi325i Christi325i is offline
Mein Auto: 2002 325i
I may be in the market for a pump soon, but dang, never thought Ebay!...Do most pro's on this site trust Ebay for parts? Like the price, thats for sure.
Old 08-04-2010, 07:41 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
Alot comes down to what brand you are getting via ebay. Many good deals can be had but in the end you get what you pay for in many cases.
Old 08-04-2010, 08:44 AM
Thw BMW wiki says my 2002 325i needs a Luk 30, so Im gonna call around to some parts palces here to see what I can get, rather than buy on Ebay.
Old 08-04-2010, 08:54 AM
smilez smilez is offline
Mein Auto: e46 325i
mine been having the same problem. then yesterday my idler pulley snapped. so i'm guessing it was due to the idler. I'll find out by tomorrow when i replace it.
Old 08-04-2010, 09:00 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
Make sure you know which pump is currently installed on your car. There will be a label on the pump indicating whether it is the LF-20 or LF-30. This label is often visible from the top of the engine bay. There are also visual cues that will help you identify the pump - check the power steering hoses/flush DIY by Starless for more details.
If you are upgrading from the LF-20 to the LF-30, you will need a new pressure hose to go along with it. This would be a good opportunity to change out all of the hoses and the reservoir.
Old 08-04-2010, 09:08 AM
Mein Auto: 2001 Z3
exactly, Go by what your label shows not what a write up says as you can have either or.
Old 08-04-2010, 09:15 AM
catso's Avatar
catso catso is offline
catso
You're better off buying used from a junkyard than some of the ebay cheapos. Again "you get what you pay for"......
Old 09-24-2010, 11:17 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Old thread I know, but my power steering pump "groaning" is getting to me. While it hasn't failed yet, I want to replace it before it actually goes out. FCP Groton has a tempting deal on a new unit:
http://www.fcpgroton.com/product-exe...Pump+1999-2001
Have any of you had experience with this sepcific pump? I would rather not roll the dice on a used unit from a salvage yard. Are there any companies that rebuild PS pumps? It wouldn't be a problem for me to not have one car while it is being rebuilt...
I'm leaning towards buying the pump from FCP along with the $20 lifetime warranty.
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 09-24-2010, 12:28 PM
catso's Avatar
catso
It's a knock-off, not the LUK. Good luck.
Similar Threads
Power steering pump problems Bill325Ci E46 (1999 - 2006) 16 08-19-2015 10:25 PM
transmission fluid in the power steering pump? JennaCide E36 (1991 - 1999) 8 01-31-2006 04:40 PM
need help!!!: power steering line loosens! tonykim E46 (1999 - 2006) 1 06-07-2005 11:11 AM
need someones help!! power steering line loosens tonykim Do-It-Yourself H.Q. 1 05-30-2005 11:19 AM
Power Steering Pump glaws 1M & M2 7 10-01-2003 06:31 AM
