E46 (1999 - 2006)
Old 12-30-2006, 03:05 PM
beemermike beemermike is offline
Mein Auto: 2000 328 ci
Lower Control Arm Bushing
I came accross a thread that had a link to very detailed instructions on how to replace these. I can no longer find it. I've been looking for some time now. I do have the Bentley book but I don't know if those instructions are as detailed as the ones I saw on here.
Can anyone supply me with that link.......PALEEEZE! thanks
Old 12-30-2006, 03:18 PM
Cliff Cliff is offline
TMS
Mein Auto: 2015 Golf R
Is this the thread you're thinking of? link to thread
2015 VW Golf R: (pic)
Old 12-30-2006, 03:25 PM
Yes! Perfect! Thank you!
Old 01-01-2007, 08:59 AM
steve101b steve101b is offline
Mein Auto: 2000 328ci
control arm bushing repalcement
http://www.understeer.com/lcab.shtml
Old 01-01-2007, 09:11 AM
Old 01-02-2007, 09:29 AM
OK cool I installed them with no problems. Grinding the inner bushing away from the carrier was pretty fun!! LOL. The inner one came right out with the gear puller. Drives so much tighter now.
Old 09-01-2008, 01:12 PM
hockeynut's Avatar
hockeynut hockeynut is offline
Casey!
Mein Auto: '04 330cic
Had mine replaced on Fri dealer said they were cracked and leaking - only 22k miles on the car but its 5 years old. Is that normal? Do they really wear over time rather than miles?
SteveH
"Now I guess I'll have to tell 'em...That I've got no cerebellum" - The Ramones, "Teenage Lobotomy"
Old 09-01-2008, 01:22 PM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
I have an 03 ZHP with 26k miles. Mine are still solid/tight.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 09-01-2008, 01:23 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Scott & Hockeynut
You should drive your cars once in awhile.
Old 09-01-2008, 03:13 PM
hockeynut's Avatar
Casey!
Originally Posted by KrisL View Post
Scott & Hockeynut
ONCE in a while sounds about right. My car wasn't built for stop and go commuting and I refuse to put it through that pain Now a weekend jaunt through the Hill Country is another story completely!
SteveH
Old 09-01-2008, 04:32 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
If your car is exposed to hot and cold then yes they can crack over time. The design flaw is that the rubber expands and contracts with the change in temp. Eventually cracking will occur and then all your fluid goes out. This is why solid units like Powerflex are so much better IMO. And I truthfully believe 30-40k is about all you get from CAB's anyway.
Old 09-15-2008, 04:52 PM
JHitchcock JHitchcock is offline
Mein Auto: 2001 BMW 325i
WEEELLLLLLL!! I guess I should be happy with the 228 k miles I got from mine. Just replaced them yesterday and OMG what a difference. Like a new car again. And Scott ZHP is right - you guys need to drive your cars more often. It's call the perfect DRIVING machine - not the perfect parked machine.
Old 09-15-2008, 05:58 PM
smolck's Avatar
ROLL TIDE!
Originally Posted by JHitchcock View Post
I guess I should be happy with the 228 k miles I got from mine. .
I am willing to bet my annual salary (don't get excited, it ain't that much) that you didn't get 228k from them. They were on the car, but they died a LOOOOONG time ago!
Old 07-01-2009, 03:21 PM
Gfresh Gfresh is offline
Mein Auto: 325I> 2004
Lower control arm bushings E46
I have had all my brakes and rotors redone, four new tires and my oil changed. my steering wheel still shimmies on occasion. I am currently due for my II Inspection. I was told by BMW that I need to replace my lower control arm bushings too for $488.00 and $149.00 for alignment. I am going to have the work done at a place in Phx that is way cheap then the dealership. I will repost the results after this is done. I am going to have it do on Fri. July 3rd and will repost on the fourth. can hear a clunking noise when I brake, on hit curb lips. Looking to get it done as CHEAP as possible while keeping the integrity of the vehicle.
Old 07-01-2009, 05:08 PM
smolck's Avatar
ROLL TIDE!
More than likely this is actually your control arms (the ball joints) rather than the control arm bushings. The bushings no doubt are bad, but the noise you describe is not indicative of the failing CAB.
Old 07-02-2009, 07:53 AM
3beemers 3beemers is offline
Mein Auto: 01 330i 09K13GT 83R100RS
It is pretty much the kind of road you have and the way you drive through it. Because of the DIY on my control arms and bushings, I now negotiate pot holes almost like a grandma style of driving particularly in the industrial areas.
Regards
Old 07-06-2009, 07:16 AM
Ok, I had the Control arm bushing replaced for a cool $272.00 from what i was told by a BMW Machanic only 1 one out 10 Bimmers need to even have an alignment after this type of repair because the repair never affect or includes messing with any of the alignment controls. Bimmer just tries to upsale you but it is always suggested. I had the machanic drive the car and givve me his professional opinion and he said the car was fine. the car now drives tigher and doesn't clunk! car still vibrates mildly after speeds of 80 to 100+ I was told by BMW that I just need a ROAD FORCE BALANCE for around 200.00... ... I called Discount Tire and they said they can do it for $13.00 A TIRE! although they addmitted it will take a longer time to do it so it is done correctly, fifty dollars as opposed to two hundred sounds better to me. *happier driver*
Old 07-23-2009, 09:59 AM
waq999 waq999 is offline
Mein Auto: 545i
I was also told to replace the control arm bushing by the dealer recently for about $600. Can you give me your mechanic's contact info (Im located in the phx area too )
Old 08-25-2009, 05:55 PM
mavrik101 mavrik101 is offline
Mein Auto: 2003 325i
me too
I'm in phoenix also, and I'd like the name.
Had a front end alignment done, and was told for a mere $500 more, they would replace the control arm bushings, and not charge me for another alignment!! Nice guys.
Old 08-25-2009, 06:24 PM
smolck's Avatar
ROLL TIDE!
Especially since an alignment is not required after a control arm bushing change. The mounts have positive locator pins in the frame rail, you can only put them back one way.
Old 08-25-2009, 06:56 PM
jengirlie jengirlie is offline
Mein Auto: BMW 325ci
I was told that I needed my Control arm bushings replaced, for around $600 + $189 for an alignment + 2 new tires. I took it to another place and they said that nothing was wrong with my bushings and that it was just a belt in my tires and all i needed to do was get new tires and an alignment.
Old 08-25-2009, 07:00 PM
smolck's Avatar
ROLL TIDE!
Yet another instance of "trusted" mechanics being full of crap. They should know an alignment isn't needed. See my blog, I wrote an article about this crap
Old 08-25-2009, 09:58 PM
Rick Van Bimmer Rick Van Bimmer is offline
Mein Auto: 330 Ci ZHP:
My 06 has just 21,000KM (13k mi) because I can't stand driving a driving machine in bumper to bumper city traffic. I use my BMW for longer drives, holidays, and for times when I just want to go out and find a quiet road and wind it up in the lower gears.
For city traffic, I have a Toyota with automatic trans.
I guess the downside of this is a very high cost per mile, as time is the number one determinant of depreciation. Now I wonder about deteriorating rubber parts, although I always garage the car.
'06 330 CI ZHP 6MT
Old 08-27-2009, 09:45 AM
bimmer4828 bimmer4828 is offline
Mein Auto: 325i
Good Afternoon,
I dropped my car at the dealership this morning and my service advisor has called to let me know that the lower control arm bushings need to be replaced and that this will cost around $640.00. As a female, I don't know much about cars, but can anyone tell me how many lower control arm bushings are actually on my car? And, do I need to have these replaced right now or will the vehicle function normally without replacement? Equally, I live in Houston so if anyone can offer advice as to where I can find a shop that will replace these at a cheaper cost, that would be great. He also told me that I have to replace both of the rear tires ($350.00) or my car will not pass inspection. Thanks!!!
Old 08-27-2009, 11:43 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: e46 ZHP
Originally Posted by bimmer4828 View Post
Good Afternoon,
TX is an inspection state? I used to live in PA - another inspection state! Dealers use the inspection scare card to get people to pay through the roof for repairs..
Anyway, for bushings, get the pre-pressed ones ($88 from oembimmerparts) and find any mechanic with good reviews. Doesn't necessary have to be one who works on BMW's but that's recommended.
For tires, check ebay, good deals there and you will pass inspection...
Similar Threads
DIY Article - How to Replace the Thrust Arms on your E39 540i - 56k No! Hotswimmer 5 Series DIY 63 08-19-2016 01:53 AM
E-46 Control Arm Bushing Removal/and fixing new Powerflex urathane bushings seasider E46 (1999 - 2006) 2 12-20-2006 07:10 AM
Lower Control Arm Or Ball Joints? beemermike E46 (1999 - 2006) 8 11-12-2006 07:11 PM
Front ( Large ) Lower Control Arm removal ? spshond E39 (1997 - 2003) 2 08-07-2005 12:28 PM
t Nick T. The Test Board 5 07-05-2003 09:25 AM
