Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Closed Thread
Old 01-01-2007, 10:30 PM
umnitza's Avatar
umnitza umnitza is offline
• www.umnitza.com •
Mein Auto: ///M
DIY - E65 HID Fogs Installation Guide ••ü••
Originally Posted by umnitza View Post
The same concepts apply to the following cars:
E90, E64, E92, E65, E60, E39 M5 and most BMWs after 2003 except E46s
REQUIRED PARTS - Provided with Kit
2 H3 Bulbs (any Kelvin)
2 Ignitors (Prolumen)
2 Ballasts (Prolumen)
2 H3 Adapter Plugs (Included)
2 Resistors (50W 60hm)
1 Complete Relay/Wiring Harness for HID system
1 Set of Zip Ties
REQUIRED TOOLS
Box Cutter/Knife
3/4" Drill Bit
Philips Screw Driver
Socket Set
Cordless Drill
2 Metal Self-Tapping Screws
Needle Nose Pliers
Electrical or Covering Tape for cleaner install
Extending Magnet (for the nut you WILL drop )
Install Procedures
1) Remove cover to gain access to fog lights
2) Unscrew fog light and remove fog light
fog light removed
3) Remove back cap - note locations of positive lead and negative post.
4) Remove existing H3 bulb, do not damage contact guides for the H3 bulb.
Insert the new H3 HID bulb (there is a squared edge and a rounded edge).
Use needle nose pliers to squeeze the two prongs (rounded and squared) onto the base of the H3 HID bulb to secuire HID bulb into base.
5) The HID bulb leads and Adapter Leads
Find the removed back HID Fog cap. Drill a 3/4" hole (size of the rubber grommet on the HID bulb wires) through the cap. Be careful, do not damage the positive lead and negative post.
Push the adapter leads through the grommets existing holes (these holes may need to be enlarged slightly using a blade/knife/box cutter).
There is no modification involved with the back cap nor the OEM plug. they will plug in normally as before.
6) At this point, you can test and you are finished with the fog light installation and it will look something like this:
However, you will receive an error message on the dash/iDrive claiming there is a fog light error and you will receive occassional flickering perpetuated by the LCM throwing occassional pulses to check if the fogs are operative. The next few steps will guide you to finish the installation with no adverse affects to either your car, the fog lights, or any electrical components.
--- COMPLIMENTARY WIRING TO ELIMINATE ERROR CODES and/or FLICKER ---
At this point, you have varying options:
- for the E65, headlights must be removed to do this properly.
- for the E64, it's not required, though helpful
- for the other cars, it's not required and doesn't change the aspect of the install.
- in all cases, it's wise to remove the wheel or turn them all the way to one side to gain easier access to the fender wall/liner area just behind the headlights.
7) Remove the 7 Series Headlights. We do not want to go into too much depth here because we don't want you to damage your car, so if you aren't comfortable, you need to ask someone that is. But basically:
a) Unscrew fender liner bolt located just behind the seam of the bumper and the fender. It's a 10mm bolt.
Also, there is a push out pin located at the vey bottom of the bumper as well that needs to be removed.
Remove bolts #34 and #22 and pins located near #28/29/21
b) PUSH THE BUMPER SKIN FORWARD, do not attempt to pull it out towards the outside of the car's side, only PUSH it forward, that's how it's designed to release from the holders. Here's an example picture (more specific photos will be available as soon as we can get them).
located at #25
Once these parts are done, do not remove the headlights yet.
c) Unscrew the headlight
remove screws located at #5/#6
remove screws located at #1
8) On the 7 series, the positive battery post, has a little "trap door" just under the post itself. Simply remove the cap (it's clipped in place) to reveal the nut (13mm). Once the nut is removed (don't lose it), place the positive lead from the ballast onto the protruding positive terminal bolt and secure back down TIGHTLY with the nut.
At this point, decide exactly where your wire will be running and dremel or shave or snip a little opening in the cover that you just removed so you can safely - without pinching the positive wire - re-insert the cap.
9) Now you have the harness positive post installed, you will need to find the part of your car where the negative lead will be inserted. For example see picture below. It must be non-painted, ground. Also, find a safe location to mount the relay (it's not heat senstive, but somewhere using an existing bolt/nut will be fine.
10) You now have 3 leads that are remaining. 2 leads will have a 9006 mail plug on the ends of them. These plugs will go directly into the HID ballast plugs (RED if Prolumen) or directly into the ballast (if non-Prolumen).
If a plug needs to be extended due to the length of the 7 series, you can use 16g wire to extend the leads.
The final lead is a two pronged trigger wire. This trigger wire is important, because it has to be crimped onto the fog light wires (just like the resistor's wires as well). You can combine those two triggers together if you want to only make a single splice into the main wiring plugs
We are still gathering photos for this, but here are a couple from an E90:
11) Now that the headlights are removed, you have access directly onto the two metal posts that hold the horns. Using 2 sheetmetal screws attach the 2 resistors to these posts and run the wires from the resistors over to the positive/negative wires of the fog lights.
These resistors get very hot, so mounting them on a metal surface is the only way to go.
12) Crimp wires of the resistors (parallel) onto the fog light wires.
Join Our Facebook! - Check Out Photos, Talk to Customers, Ask Us Questions!
Call US! 877 486 6489
Available: 9am-5pm M-F
Old 01-01-2007, 10:33 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
13) You are finished, it's over. And you get this:
no error messages
6000K HID Fogs, 6000K Low Beams, Predator ICE 6000K
Old 01-02-2007, 01:09 AM
SevenMan's Avatar
SevenMan SevenMan is offline
Mein Auto: 745Li
Looks good. I'll be needing this upgrade pretty soon. I'm about 10 minutes away from you guys.
_____________________SOLD_____________________
Old 01-02-2007, 09:58 PM
synergy synergy is offline
Mein Auto: 06 997S, 03 745I
Ahhh looks so familiar
"Keep it Real, Drive German Steel!
Old 02-22-2007, 12:44 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
Old 02-22-2007, 02:17 PM
JA 7's Avatar
JA 7 JA 7 is offline
Master of the Universe
Mein Auto: 2004 745Li
Im telling you. I don't think it requires the additional harness. Just spice the resistors onto the factory wiring. I'd put money on it.
When called an idiot sometimes it is better to be quiet, than open mouth and remove all doubt.
Old 02-23-2007, 01:05 PM
WaynesNside WaynesNside is offline
Mein Auto: 2002 745Li
Looks real good.
I just did an HID kit on myGiSXr thou and I love it.
www.customoffset.com
facebook.com/customoffsets
Old 03-26-2007, 10:11 AM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
Well, your car was "special" - we've done 3 745s since them - 02, 03, and 04 (coincidence) and not one could go without the resistors AND the harness
Old 03-26-2007, 03:22 PM
JA 7's Avatar
Yes, special....haha. Did you actually try it w/o the harness. I know the resistor is a must. The problem was still evident after putting on the harness and then worked with the resistor. Try crimping the resistor first and let me know. I have a feeling you will be in for a surprise.
Old 03-26-2007, 03:27 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
Indeed, I did. the fogs didn't want to turn consistently.
Old 03-26-2007, 06:02 PM
JA 7's Avatar
turn?
Old 03-26-2007, 06:09 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
turn on.
Old 10-16-2007, 01:11 PM
tinab2580 tinab2580 is offline
Mein Auto: bmw 7 series
is there an easier way to do this...
Old 10-16-2007, 01:19 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
yes, we just got the parts that will eliminate the need for the harness.
Old 10-16-2007, 01:25 PM
really what is it and how much is it....and how would i connect it..btw nice job and that bmw... tight work
Old 10-19-2007, 07:17 AM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
they just arrived. we need a car to test it on.
Old 10-20-2007, 12:03 AM
AZIPOD AZIPOD is offline
Mein Auto: E66,E90,W211,NSX,E39,E38
I just installed the Prolumens H3 kit. I have PDC. Unfortunately, with the lights on, the PDC in the front goes crazy as if I am about to smack the car in front. The PDC crazyness goes away if the lights are turned off. I believe it's some sort of electrical or signal interference.
Are there any solutions? I'm not happy with the results.
Old 10-20-2007, 09:13 AM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
Mounting the ballasts near the PDC will cause this. Please mount them in an area where they are not near the PDC and ensure the connections are tight with no bleed-out.
We have had this a few times on E65/6 cars and each time it had to do with remounting the ballast in a different location.
Old 10-20-2007, 09:53 AM
Thanks! I'll try to remount the ballasts. Will post updated results soon. Thanks.
Old 01-11-2008, 04:28 PM
joebmwe65 joebmwe65 is offline
BMW E65 730D
Send a message via MSN to joebmwe65
Mein Auto: bmw 730d sport
hey do you take the cover off to gain access to fog lights. as you have in step 1. i tried this and its to hard and imafriad i might break it whats the best way to do it
Old 01-11-2008, 04:41 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
http://www.umnitza.com/gallery/hidinstall?page=2
Old 01-11-2008, 05:06 PM
BMW E65 730D
that helps but sorry its just in removeing the cover to unsrew the screw so you can take foglight out
Old 01-11-2008, 06:21 PM
78mphgpr 78mphgpr is offline
Mein Auto: 745LI
How much is the fog hid kit? Discount if we get the fog and angel eye kits together?
Old 01-11-2008, 06:35 PM
umnitza's Avatar
• www.umnitza.com •
Mein Auto: ///M
yes a bit of one We have ones starting at $150.
Give us a call.
  #25
Old 01-11-2008, 07:00 PM
blk45's Avatar
blk45 blk45 is offline
Mein Auto: E65
You need the ICE kit T. It looks much better!
Closed Thread
HTML code is Off
Similar Threads
••ü•• E65 HID Fogs Installation Guide umnitza E60 (2004 - 2010) 2 02-22-2008 02:33 AM
Jlevi SW | Free Predator ICE Installation Guide Now Available Jlevi SW Do-It-Yourself H.Q. 7 10-03-2007 02:00 PM
••ü•• E65 HID Fogs Installation Guide umnitza 7 Series / 8 Series 3 01-03-2007 10:06 AM
Anybody do an HID Fog installation? ArCaDe E39 (1997 - 2003) 1 06-22-2006 07:04 PM
