E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
325i oil change
I just purchased a 325i (2002) with aprroximately 39,000 miles. It is going to need an oil change in about two months which I am going to try to change myself. How do you reset the odometer that monitors when the oil should be changed? Is a special tool required. I hear some people talking about lights on the display that have to be reset also, but haven't seen any lights. When do they come on, if my car has them?
Thanks for the info. if anyone can help. |
PLEASE Search the forum next time, this is asked about once every other week .RESETTING OIL SERVICE INDICATOR: If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again: A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory). B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done |
Procedure B above did not work for my 2006 325i. Here are the steps that actually worked (Thanks to RJ for original post over at FixYa.com):
1) Start the engine 2) Wait for the computer to get to normal 3) Press and hold the trip mileage reset button until a ! in a triangle appears. Your maintenance info will pop up. 4) Select the item to reset (not sure whether you select items with the trip mileage button or the scroll lever on the side wand--I only had one item to reset). 5) Press the side button on the wand attached to the steering wheel once. It will say "reset." This button is what you use to browse through your computer. 6) Press and hold it the second time for 5 seconds or so and it will show a check mark next to "reset" confirming it has reset. Hope that helps! I was getting tired of searching the forums for this answer and getting the SAME wrong instructions over and over! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| This Is The Official Hijack Thread... | Sabrina | Off-Topic | 146 | 05-21-2009 06:38 PM |
| First E60 Oil Change | lcc014 | 5 Series DIY | 1 | 12-18-2006 07:55 PM |
| Onboard computer says oil change at 9000miles, DEALER REFUSES! | vortex72 | E90/E91/E92/E93 (2006 - 2013) | 24 | 03-24-2006 10:06 AM |
