E46 (1999 - 2006)
Old 01-06-2007, 02:18 PM
ranz_killa ranz_killa is offline
Mein Auto: BMW 318iSE V reg
What is this light on my Dashboard?
Hey,
As i was driving, this light came on my car. (See Image Attachment). It is the yellow light above the red air bag light, which i am worried about.
The links is: http://www.bimmerwerkz.com/forum/att...-dashboard.jpg
I have a 318iSE v, 1999. (E46).
Was also hoping, if someone could send me the link / image or document, which shows what all icons on the dashboard represent?
Thanks in advance,.
Old 01-06-2007, 02:53 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Nice photo....I feel like I`m drunk.... :-)
That light means your brake pads have worn to the point that the sensor was tripped.... have them checked ASAP. (Oh yeah, an owner`s manual will answer many of your questions)
Regards,
Bob
Old 01-06-2007, 07:49 PM
bmf bmf is offline
Mein Auto: bmw
if your not going to the dealer for the brake job make sure you replace the brake pad sensor.if not the light will stay on.
Old 01-06-2007, 07:55 PM
mauijim3 mauijim3 is offline
Mein Auto: 2007 328xi
Regards,
Bob
I agree with Bob, and the bottom image is the "Don't chew bubble gum while driving a BMW" warning....
Old 01-07-2007, 07:43 AM
BMWROCK BMWROCK is offline
Mein Auto: BMW 323i
What others have already pointed out, it's warning light stating your brake pad is worn well within it's limits. It's a safe bet that your pad needs changing, however, just to be sure check both of your brake pad sensors wire for any signs of frayed or cut from possible tire rub (one sensor wire in front left, and the other one situated on the right rear)
My light came on last week as well and come to find out it was just my sensor wire that was badly frayed result of tire rub. There's a humor side to this story which I have posted called "lesson learned" on brake pads.
My point is, check the obvious items first such as brake pad thickness and sensor wires before tearing into (If you're going to DIY) or take it to the dealer.
If it's only a sensor wire that needs changing it's very easy DIY and you can buy one at about $18-20 dollars for one sensor wire.
Old 01-07-2007, 02:35 PM
ozcot ozcot is offline
Mein Auto: 2009 328i
Keep expecting my brake wear Light to come on as well. Words of wisdom when at the dealer and they say your brakes are close to hitting the sensor take that with a grain of salt.. Replaced a set of pads the first time they informed me I had less than 1,000 miles figured it was here may as well save me a trip the next month. Last time I had my oil changed they said the same thing diffrent set of coarse. Figured I would wait till the light came on this time since I needed tires soon. Been over 3,000 and still no light To give them the benefit of doubt I do alot of highway driving so that will effect the wear. When the light comes on you have about 250 to 500 miles left at least that is what I was told by the dealer if I am wrong let me know.. Figure the light should come on soon if not may just change them at my next oil change in 3,000 miles. There is no problem with the light not coming on when you actually need brakes is there Read on some posts some have lasted upwards of 70,000 I am just at 50,000. Had this set changed around 25,000 miles or so when the light came on, they are the front set they must wear faster... That or the sensor was bad and they decided to give me a new set of brakes since I would not know any diffrence (LOL)...
Old 11-26-2007, 07:28 PM
cookie725 cookie725 is offline
Mein Auto: BMW
We have a 2000 BMW 323i and the yellow light which is an exclamation point in a triangle with a circle around it stays on all the time and i want to know what it is and how do i fix it
Old 11-26-2007, 10:29 PM
geeek204 geeek204 is offline
Mein Auto: e46 325i, Audi A7 & R8
This is your DSC (or is it ASC, no sure about the 2000's) warning light, either you are pressing the DSC/ASC button every time you drive, or you have a problem in the system. Most likely the latter. Have it checked as soon as possible by a mechanic.
Old 11-27-2007, 08:01 AM
iskoos's Avatar
iskoos iskoos is offline
Coupe OR Never
Mein Auto: '02 - 325ci
Does the brake pad warning lights standard for all E46 models. I have it on my dashboard but I would think my car is not equiped with the sensors. I was more like thinking that this is an option that you can add or a feature that comes standard with higher models. Mine is '02 325.
Old 11-27-2007, 08:08 AM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Standard. My 1988 325is had the same light and the same sensors even.
Old 11-28-2007, 11:48 AM
triggs's Avatar
triggs triggs is offline
Gadget freak
Mein Auto: .02.330i.aw.
Originally Posted by ranz_killa View Post
Hey,
Thanks in advance,.
What's the meaning of the brake light and airbag light comes on at the same time?
Old 02-03-2008, 03:54 PM
clintb111 clintb111 is offline
Mein Auto: 330 cic
brakepad light
Don't feel stupid, I just bought a used 330cic and no manual was included. I searched for 20 minutes to find the answer for my same question. If you can buy a bimmer I'm sure you're competent enough to check your owners manual first before going to the trouble of posting your question and uploading an image!
Old 02-19-2008, 10:58 AM
amet amet is offline
Mein Auto: 2000 BMW 323i
I was driving my 2000 323i and yesterday the same red light of airbag popped and now its ON. Can anyone tell me what it is for ? is it a sensor?
Old 02-21-2008, 01:04 PM
BmwMoose BmwMoose is offline
Mein Auto: 2000 328ci
First check that the wires underneath your seats haven't come unplugged (this happened to me) - do your power seats still work? Anything else you'll probably have inspected by a mechanic (could be just your seatbelts malfunctioning or actually your airbag system).
Old 02-21-2008, 01:18 PM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
Yes, it's probably one of the seat sensors. Unfortunately you'll need a Peake SRS light reset tool to get the light to shut off even after the problem is fixed. Best to find an independent mechanic to read the SRS code and figure out what made it come on.
Old 02-21-2008, 01:21 PM
My airbag light turned off shortly after I reconnected the wires on my passenger side seat.
Old 02-21-2008, 01:24 PM
matador matador is offline
Mein Auto: 328i
My Car is showing the same light.. and I just install new pads.. is weird..
Old 08-05-2008, 02:37 PM
carlandsandy carlandsandy is offline
Mein Auto: X3
Bmw dashboard lights
Old 08-05-2008, 09:24 PM
Alex D Alex D is offline
Aus Hamburg
Mein Auto: 2001 BMW 330 CiC 5-speed
Actually ... it means "Drive carefully ... pregnant woman on board"
2007 335i Convertible - Karmesinrot/Korallrot, 6-speed, Sport, Premium, Cold Weather, i-Drive/Nav w/iPod/Sirius
2008 Infiniti G35S Journey - Obsidian Black/Stone, Premium/Sport Packages
2006 Saab 9-3 2.0T SportCombi - Steel Gray Met./Grey, Sentronic, Premium/Premium-Sound/Cold Weather Packages, Xenons
BMWCCA #407025
My Retired Bimmers:
2001 E46 330CiC
1990 E30 325iC
1982 E28 525iA
1980 E21 320/6
Old 08-07-2008, 01:05 AM
triggs's Avatar
Gadget freak
better not be the pregnant man. =)
02.330i.aw
| H&R Springs | K&N Cold Air Intake | Borla Catback exhaust | JL Stealth | Kenwood KVT |
Old 04-20-2010, 05:15 PM
teedub86 teedub86 is offline
Mein Auto: 325i
i see the light!
I recently bought an 05 325i and have had a few issues. The DSC came on after i got the car out of the shop and i dont remember it being on before, does anybody know if this suppose to be on or is the car F'ed?
Old 12-06-2010, 09:29 AM
jolvigil jolvigil is offline
Mein Auto: BMW 330i
Help....I own a BMW 330i and this morning I noticed a red lamp light symbol on. It is on the picture of the car to warn you when you have a door open or the tailgate open; however, no doors are open nor the trunk but a red lamp is on. I hope I explained this well...what does this mean?
Old 12-06-2010, 09:39 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
You are responding to a 3 year old thread. Besides you have to be a little more specific about what warning light is on. Scroll up in this old thread and you'll see a variety of diagrams. Pick one and continue.
PT
___________________________________
Old 12-06-2010, 07:51 PM
Bavar1 Bavar1 is offline
Mein Auto: bmw 325i
yellow circle with exclamation mark
its your DSC, dynamic stability control. if you did not manually disengaged it. you have a problem with your traction control. you need to get it check by a good mechanic that deals with BMW cars, you will not get a OBDc code it needs a special code reader. most likely you have a problem with your steering sensor if not your speed sensor which you have on 1 each wheel. Steering sensor needs to be calibrated also upon replacement. Costly repair!
Old 09-21-2014, 07:59 AM
wilt wilt is offline
Mein Auto: 2011 328i
Brake PAD indication...see page 22 and page 121 of your owner manual! (post 18 shows the same symbol = brake pads, although page numbering is different than on my copy of the manual)
"If the warning lamp for the brake
pads lights up:
The brake pads have reached
their minimum pad thickness. Proceed
to the nearest BMW center as soon as
possible to have the pads replaced."
Similar Threads
'1 Brake Light Failure' Weird Situation hunt1200 E36 (1991 - 1999) 20 05-20-2011 05:54 PM
My ABS, ASC+T, brake warning light & automatic transmission lights came on together! Pijal9110 E46 (1999 - 2006) 23 08-10-2008 11:56 AM
Check Engine Light bbrg86 E30 (1982 - 1993) 7 04-19-2006 08:17 PM
Dashboard Light Icon's articgrave39 3 Series & 4 Series 2 03-24-2004 02:11 PM
How many...? The Roadstergal Off-Topic 9 08-15-2003 07:58 AM
