E30 (1982 - 1993)
Old 04-09-2008, 10:53 AM
Airetime Airetime is offline
Mein Auto: 2001 325ci and 1989 325i
Did I studder??
1989 BMW 325i, 115,000 miles, major tuneup including plugs, wires, cap rotor etc. at 100,000 miles. I have developed a studder when I am driving and take my foot of the gas pedal.
For instance, if I am in 4th gear cruising along and take my foot off of the pedal it will studder, apply just a little pressure on the pedal and it goes away. The only recent work that I did was to clean the heater control coils under the firewall cover. Anyone ever experienced that? Vaccum leak?
Old 04-09-2008, 12:02 PM
E30bimmer E30bimmer is offline
Mein Auto: 86 325e, 95 m3
check for vaccum leaks, also try cleaning your ICV...that might help
Old 04-09-2008, 03:42 PM
Found the Problem!
Seems though I have burned the coil wire where the terminal tip connects to the wire. This is the 2nd time this has happened. Any ideas? Coil need to be replaced?
Old 04-12-2008, 12:07 AM
Mike_Check Mike_Check is offline
Account close at users request
Mein Auto: .
Coil is getting too hot. Time for a new one.
Old 10-09-2010, 09:41 AM
Did I studder? No More
OK, here was the problem. Seems as though I had a bad coil wire and resistance was burning the connector. New (slightly used) coil wire and all was well. TCan't remember who here had an extra wire that he let me have for a few bucks but thanks, it solved the problem without breaking the bank
