Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 01-13-2007, 11:28 AM
tony837 tony837 is offline
Mein Auto: bmw m3
Help Hesitation/Misfire M3 E36 1994
I have hesitation/mis-firing at 2000rpm. Doesn't happen all the time, happens more if driven sensibly and can happen if the car is cold or hot. I have changed the 6 coil packs, plugs, o2 sensors, air flow meter, fuel pump, fuel filter, and have most recently taken the injectors out and had them cleaned and flow tested and all is well with them. Can anyone suggest anything as I have run out of ideas. If driven hard it doesn't appear to be so bad. Taken car to main dealer and they say there isn't anything wrong with it even though the technician test drove it with me and felt the hesitation himself!!!
Old 02-17-2007, 02:08 PM
gaz m3 gaz m3 is offline
Mein Auto: e36 m3
hi mate,i was just wondering if you have sorted out your missfire problem,my m3 does the same thing
Old 02-20-2007, 08:36 AM
Fast1 Fast1 is offline
Mein Auto: 97' Estoril M3 Saloon
If it's a misfire first thing you should do a compression leak down test. I am just gonna guess on this one but seems like the good ole #4 has a problem. I have heard about a problem a couple times already where during compression testing bubbles will be seen in the coolant reservoir. The bad news is that either the head gasket is leaking internally or the head is cracked. Sometimes this is visible by inspecting the spark plugs and seeing which one has been getting coolant on it.
If it's just hesitation check the operation of the throttle position sensor. Good luck
Old 02-20-2007, 11:22 AM
Bruce Bruce is offline
Mein Auto: 88 E30 M3.2, 08 451
He has a different motor than you do.
Old 02-20-2007, 11:59 AM
95M3CSL 95M3CSL is offline
Mein Auto: E36M3
Holes in any of the rubber hoses that provide air to the engine (intake tract)?
Crank position sensor? Does this motor have it?
Regards,
Marc
95M3
Old 10-24-2009, 10:28 AM
Wizwam Wizwam is offline
Mein Auto: E36 M3 3.0 Saloon
I have been chasing this on my E36 3.0 Saloon for a while ( I am a BMW Technician).
Does the hesitation occur mainly between 1800 - 2200 RPM, mainly under light to moderate throttle and worse during warm up ?
Also, does your engine pink under moderate load in warm weather (ie above 22 deg C) ?
Old 11-15-2010, 10:16 AM
Sapiroci Sapiroci is offline
Mein Auto: BMW M3
Same problem
Hi,
I have the same problem you described on my BMW M3 3.0, could you tell me how did you solve this problem, please?
Thank you for your help!
Old 12-02-2010, 10:58 AM
bmw m3 1995 bmw m3 1995 is offline
Mein Auto: m3
i have the same problem,any clues yet
Old 04-22-2011, 03:14 PM
crook crook is offline
Mein Auto: e36 m3
Hi,
I have a similar issue. The car had a few niggles when I bought it including a bad petrol (gas) smell, very lumpy idle, rough running when cold on a constant throttle.
Took it to a good 'M' specialist to give it a good looking over who cured the petrol smell (leaky fuel pipe in engine bay) and the lumpy idle (bung/rubber cover missing off throttle body) and all seemed well.
After driving it in town in heavy traffic in hot weather the car started being hesitant on constant throttle on the motorway and even a bit when accelerating.
When it had been to the specialist the only code that came up was because of the bung missing. Vanos was fine. New fuel filter fitted. Car drives fine otherwise. Happily pulls to 7k on a daily basis
Has anyone got any ideas before I go through the plugs/leads/coil packs route?
Many thanks in advance.
Oh, it's an E36 M3 3.0L '94.
Old 05-02-2011, 11:26 AM
jpgerner jpgerner is offline
Mein Auto: 99 M3
Had the same problem, replaced 6 coils (with BavAuto HP) replaced O2 sensors, replaced fuel filter. Car ran fine wide open but stumbled in mid-range. I can't believe it myself, but I replaced the plugs and it is fixed. When I replaced the coils (I thought I was making an upgrade) I put in new plugs, but I chose the two prong Bosch instead of the four. The recent replacement was back to a set of four prongs, which is what were in the car to begin with. I still can't believe it, but it's fixed. (I've seen since on other posts that the NGK iridium IX plugs are highly recomended.)
Old 05-02-2011, 12:19 PM
Mein Auto: e36 m3
Thanks for the reply. I'll look into the history and see when the plugs were last done and what they used and maybe get a set of new ones ordered up.
Old 05-05-2011, 06:07 AM
Don't put the Bosch 4 prongs in, they are known to be fragile and lose tips.
Old 05-18-2011, 01:34 PM
Mein Auto: e36 m3
That doesn't sound very good.
Old 06-05-2011, 10:51 PM
chrisria chrisria is offline
BMW FANMAN!
Mein Auto: 1999 M3
Got the same issue! New coils ordered today along with NGK two prong copper plugs...wish me luck!
Sent from my PC36100 using Bimmer App
Old 11-24-2011, 12:37 PM
shiga shiga is offline
Mein Auto: e36 325i
So, it's my first post here (HI EVERYONE! ) and I've been looking for a solution to this problem for a few months now. Changed coil pack, spark plugs, fuel pump, fuel filter, crankshaft position sensor, camshaft position sensor, fuel pressure regulator and cleaned up fuel injectors to no avail. Did anyone find other solution besides changing the spark plugs??? Pleeeease
Old 11-29-2011, 01:04 PM
Mein Auto: e36 325i
Helloooo!
Old 01-06-2012, 10:46 AM
Mein Auto: e36 325i
bump
Old 01-12-2012, 12:43 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
You might try making a new post in the plain E36 forum (this is the E36 M3 forum).
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 03-09-2012, 11:44 AM
Nircom Nircom is offline
Mein Auto: 2008 E92 330i
Same issue with my 94 m3 3.0L euro.
Replaced tps, fuel filter, manifold rubber o rings, cleaned icv, checked for leaks andfound none, and i am wondering what to do next.
Oh, and plugs were replaced two and a half years ago with bosch cdd5y.
any one here as the magic solution?
Old 03-10-2012, 09:20 PM
VANNYBABY VANNYBABY is offline
///M POWER
Mein Auto: 1999 BMW ///M3
I've had Bosh Platinum Plus 4's in my M3 since 2006. They seem to work fine for me. Just a note!!!
Old 06-14-2013, 02:47 AM
bussinessacc bussinessacc is offline
Mein Auto: 323
constant throttle hesitations
I used to run iwhtout o2 sensors on mine 256s3 m52b25 and was fine .
One day decide to connect the o2 sensors and this hesitations start to manifest .
My recomandations is to disconect the precat o2 sensor and test if the hesitations disapear , if so new sensors needed .
sorry for my english .
regards
Old 06-14-2013, 06:35 AM
Mein Auto: e36 325i
regards
I had this same tip at bimmerforums uk some time ago, changed the O2 and got it solved.
Similar Threads
E36 M3 or E46 M3? IndyMike General BMW Questions 18 10-16-2010 09:25 AM
e36 m3 vs e46 m3 saint166 E46 M3 (2001-2006) 4 03-19-2006 03:34 AM
E46 330Ci ZHP or E36 M3? MCoupeD E46 (1999 - 2006) 37 05-30-2005 06:28 PM
FS: Brembo e46 m3, e46 non m, e39 m5 14" and e36 m3 kit BRAND NEW berman66 Classifieds 0 06-25-2003 07:01 PM
New 330P Vs. M3 E36? rd3 3 Series & 4 Series 0 12-27-2002 02:32 AM
