Lets try to hands free phone the coupe - Page 2 - Bimmerfest - BMW Forums
Old 04-21-2003, 03:11 PM
Ron Stygar's Avatar
19,585 Miles
Re: OK Heres another couple questions for you
Originally posted by rexconde
Have you ever installed two phone kits in one car? I have one work and one personal phone and I want kits for each of them.
I suppose I could place a simple switch to change between the two systems? The switch could be a manual throw, but if I'm going to do this I have to do it right. . .
Would you know if the Radio Mute wire is it a voltage throw or simple closure loop? I was planning to use a couple relays to accomplish the automated switching, but I guess I dont know if there will be enough power to throw the relays and trigger the radio mute button, thus going with an extra power supply.
You said above that 13 and 14 were the Phone inputs for the Phone ... shouldnt there be four wires -/+ for right and left? Or is there a common ground? Are you splitting the mono signal from the j-box to each of the speaker inputs. Or is 13 and 14 a dedicated input for the phone and the internal system does it for you?
NB, I have the T720 kit coming in a week or so, and I just recieved my Motorola Bluetooth Car kit today. . .
I'm working on getting the housing and the pins today to connecto to the X400.
A ground supplied to the radio mute line mutes the radio.
Pin 13 and 14 are for the HK Traffic Pro NAV system radio. It's a mono input. 13 Low frequency input. 14 Ground.
Old 04-21-2003, 06:05 PM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
On a related note, you guys might want to check out this site, dedicated to i-bus and related projects:
OpenBMW
Old 08-06-2003, 09:53 PM
TxnBluDvl TxnBluDvl is offline
Mein Auto: 98 M Roadster
Originally Posted by Ron Stygar
Received the BMW microphone cover today.
As mentioned, I have the BMWNA Traffic Pro. My friend Jim has the HK Traffic Pro.
Mine will control the BMW or Becker changer.
His will only control the Becker changer.
My phone input pins 13 & 14 went to the CD changer. I have come up with no reason why. There is no measured resistance or signal there. I cut these lines and used them for my phone input.
His phone input connector pins 13 & 14 have no pins in it.
HK states the phone input feature, yet there are no pins in the connector to accommodate it. There is no way to get the pins either.
Does that make sense? It doesn't to me.
I assume that everything is a secret, or that the accessible people just don't know.
I have no idea why Becker NA/AG does this. You would think that they would want to make it easy for you to enjoy their product.
That is not the case.
More to come.
For all, I have more information re the HK Traffic Pro and pins 13 and 14. There is a special part that needs to be ordered. It includes the pins and ends in one RCA out. All of this comes with the Aux in kit. The two pins somehow turn into one RCA out, I'm not sure how. I wonder if I'll just have to hack off the RCA input or if there's a convenient radio shack way to mate to this RCA input...
As an aside, I plan on putting a hands free kit for the v60 (basically same kit at the T720 kit) in my m roadster. I've read this thread, but I'm a little confused. The antenna/telephone amp -- where is it? Does it use the standard antenna or do I need to order a different one? I imagine this replaces my standard antenna out back.
Are the pins that go into the 8 pin mating connector the same ones that go you order for the back of the radio or is it a different part number?
Old 08-06-2003, 09:54 PM
Originally Posted by TxnBluDvl
Ron,
I have more information re the HK Traffic Pro and pins 13 and 14. There is a special part that needs to be ordered. It includes the pins and ends in one RCA out. All of this comes with the Aux in kit. The two pins somehow turn into one RCA out, I'm not sure how. Does the Motorola Kit come with a + and - out?
As an aside, I plan on putting a hands free kit for the v60 (basically same kit at the T70 kit) in my m roadster. I've read this thread, but I'm a little confused. The antenna/telephone amp -- where is it? Does it use the standard antenna or do I need to order a different one? I imagine this replaces my standard antenna out back.
Got the part number. Becker part number 1319.116-276. Good luck to all.
Old 08-06-2003, 10:10 PM
Ron Stygar's Avatar
19,585 Miles
>>>My coupe came with the telephone antenna. The connector is in the console area. Not sure what the roadster has.
Are the pins that go into the 8 pin mating connector the same ones that go you order for the back of the radio or is it a different part number?[/QUOTE]
>>>Same pins male and female.
Old 08-07-2003, 04:29 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Have any of your looked into Bluetooth phones?
Sony Ericsson (and several others) have hands free aftermarket kits that will radio mute, amoung other things.
The S-E kit has a small controller you can mount to the steering wheel (no wire due to Bluetooth) that controls the phone for answer, hangup, or scrolling through the phone numbers programmed into the phone.
The S-E T68i phone which I have also supports voice prompt dialing of numbers in the phone.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 04-22-2007, 07:30 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
[quote=Ron Stygar;224906]
Originally Posted by Ron Stygar View Post
As mentioned above the eight pin connector provoides power and access to the radio mute line. This is in your car. The mating connector is 61 13 1 378 116.
I installed the phone kit module under the dash on the drivers side.
RON WHAT IS THE MATING PIN NUMBER FOR THIS CONNECTOR?
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 04-22-2007, 03:24 PM
Ron Stygar's Avatar
19,585 Miles
[QUOTE=bob lindquist;2324418]
Old 04-22-2007, 03:42 PM
A Clean Windshield
[quote=Ron Stygar;2325113]
Originally Posted by bob lindquist View Post
do they come terminated?
the cell connector down in the console is a great place to tap switched and always-on power. if you tap the console bulb line you also have dimmed power.
Old 04-22-2007, 03:44 PM
Ron Stygar's Avatar
19,585 Miles
[QUOTE=bob lindquist;2325127]
With wire attached.
Old 04-22-2007, 03:48 PM
A Clean Windshield
[quote=Ron Stygar;2325130]
With wire attached.
yes. I find its hard to beat a factory crimp. I'm better with solder and shrink
Old 04-22-2007, 03:54 PM
Ron Stygar's Avatar
19,585 Miles
[QUOTE=bob lindquist;2325135]
61 13 0 007 452/3 S/L
Old 04-22-2007, 03:59 PM
A Clean Windshield
[quote=Ron Stygar;2325139]
61 13 0 007 452 S/L
61 13 0 007 453 S/L (LARGER GAUGE)
WHATS THE S/L STAND FOR?
Old 04-22-2007, 04:06 PM
Ron Stygar's Avatar
19,585 Miles
[QUOTE=bob lindquist;2325151]
61 13 0 007 452 S/L
452 = small pin
453 = large pin
Old 04-22-2007, 04:09 PM
A Clean Windshield
[quote=Ron Stygar;2325154]
452 = small pin
453 = large pin
THANKS. WHAT YA WORKIN ON?
Old 04-22-2007, 04:12 PM
Ron Stygar's Avatar
19,585 Miles
[QUOTE=bob lindquist;2325160]
Right now I'm checking my 318ti for the emissions readiness bit.
Will be taking it for emissions check next week.
Old 04-22-2007, 04:24 PM
A Clean Windshield
Now I'm back workin in aerospace I have weekends off. yippe. I'm starting to get back into the mods.
Old 05-31-2007, 04:42 PM
A Clean Windshield
which BMW tool do we use to remove these pins.
Old 05-31-2007, 04:47 PM
Ron Stygar's Avatar
19,585 Miles
See post #13.
Old 06-01-2007, 08:37 AM
A Clean Windshield
See post #13.
OH GOODY, SAME PINS AS THE SUNROOF SWITCH. I HAVE THAT TOOL
Old 01-05-2013, 07:51 AM
Sammy Sandbag Sammy Sandbag is offline
Hoverbuggy Operator
Mein Auto: '02 M Coupe
Ron,
Great write up, motivated me to do the same. I have all the parts on hand, though I'll be using a Grom adapter for the Bluetooth operation with my Business CD. One question though, do you have a measurement from a point of reference for the cut you made in the headliner? The template you show will be useful, just not sure exactly where to place it so that the screw hole lines up properly. Something like a measurement from the cabin light. Hope that makes sense.
