Old 01-19-2007, 12:32 PM
petren petren is offline
Mein Auto: 04 X3 3.0i
Resetting the service lights
Can anyone give out the procedure to reset the service lights after changing oil? My car just had the first oil change out of normal covered BMW maintenance and the BMW shop I went to did reset the light by using a combination of instrument clustor buttons and ignition key. Obviously they did not want to give it away but managed to get the first few steps like turn the ignition key with a button pressed and the reset shows up on the dash but after that I could not see the next steps.
I guess I need it for next time when I will be changing the oil myself.
Thanks In advance,
Nick
Old 01-19-2007, 07:43 PM
Ishniknork's Avatar
Ishniknork Ishniknork is offline
I hate doing dishes
Mein Auto: '05 X3 3.0i
Are you saying your X3 is out of warranty (over 50K miles)?
'05 X3 3.0i Alpine White/Gray Leather/Alum. Trim
Sport/Steptronic/Servotronic/Panoramic
Premium Sound/Staggered Style 114 18"ers
Old 01-20-2007, 04:50 PM
Yes, I have 72k km on the odometer.
Old 01-20-2007, 04:51 PM
The dealer asked $275 for oil and filter change... I told them to get lost...
Old 01-20-2007, 04:56 PM
bouncer163 bouncer163 is offline
Solid
Mein Auto: dinan 535i
http://www.autoshoppingcenter.com/se...ights/Bmw.html
Old 01-20-2007, 05:08 PM
Andre Andre is offline
Resu Deretsiger
Mein Auto: 2007 335i E90 AW CA ZSP
That seems excessive. My dealer charges about $75 for oil & filter.
Old 01-20-2007, 05:09 PM
Solid
http://forums.bimmerforums.com/forum...d.php?t=672691
Old 01-20-2007, 05:10 PM
Solid
you could it yourself for about half that
Old 01-21-2007, 12:22 PM
bobotski bobotski is offline
Mein Auto: X3 3.0si
From x3world... posted for an X5 though, but may be similar for an X3...
http://www.x3world.com/articles/x5/e...ts-bmw-x5.html
Old 01-22-2007, 06:38 AM
Thank you all, the one that worked was this one:
http://www.autoshoppingcenter.com/se...ghts/Bmw1.html
Procedure:
Ignition key must be off
Press and hold the trip odometer reset button in the instrument cluster (left button), and turn the ignition key to the first position.
Keep the button pressed for approx. 5 seconds until one of the following words appear in the display: "Oil Service" or "Inspection", with "Reset".
The service due is shown with "reset" if the coded minimum consumption limit has been reached and resetting is possible. If "reset" is not shown, the minimum limit has not been reached and resetting is not possible.
Press and hold the reset button again until the word "Reset" begins to flash.
While the display is flashing, press the left button briefly to reset the service interval. After the display has shown the new interval the following will appear: "End SIA".
The system can only be reset again after 2.5 gal (10 liters) of fuel have been consumed
Old 03-24-2010, 08:01 PM
Jedi54 Jedi54 is offline
Mein Auto: 2005 X3
petren: thank you!
I just had the service done earlier today at an independent shop and they forgot to reset the schedule. Instead of bothering them, I just did it myself.
Old 11-25-2012, 11:39 PM
Brynderwyn Brynderwyn is offline
Mein Auto: 2006 X3 diesel
Hello,
I tried the above reset procedure, but now it shows -4400. Any suggestions on why or what I do now?
Old 11-26-2012, 06:00 AM
al_macaroni al_macaroni is offline
Mein Auto: BMW X5
Try the procedure again. But, in the last step, when you press the Reset button, hold it down a few seconds longer than you did on the first try. I think I had to hold mine down a good 5 - 10 seconds for it to reset.
I had to perform the Reset procedure a few times before I got the button timing correct.
Good luck
2016 X5 35d | Mineral White | Terra
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80
retired - 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog
1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb
BMW CCA #422951
Similar Threads
Two extremes of service & my CPO nightmare. jpwhite BMW Dealer Ratings and Feedback Forum 31 11-15-2008 10:28 AM
Service Engine Soon and Brake lights on hadam E46 (1999 - 2006) 5 05-23-2005 10:07 PM
Service info needed for 60k mile interval Maximus 3 Series & 4 Series 5 04-04-2004 05:53 PM
How to reset oil service lights in '95 E34 paul330ci 5 Series 2 08-31-2002 08:57 PM
resetting service light dukez 3 Series & 4 Series 2 08-16-2002 07:59 PM
